I am trying to make a shape/model which is comprised of a few other shapes
added and subtracted from each other. When I did this using Fusion 360, I
used a transparency setting which allowed me to visually confirm that I was
achieving my aim. Unfortunately, the alpha setting for the color command
doesn't seem to have the same effect - it doesn't allow me to see the inside
of my shape. Is there some way I can get to see the inside of my shape from
the outside, as I can in other software (e.g. Google Sketchup, Fusion 360
and 123Design)?
http://forum.openscad.org/file/t2755/openscad.png
http://forum.openscad.org/file/t2755/fusion.png
Not within an object. you have to cut them open, e.g.
module cut(s=10000) {
translate([-s/2,0,0])
cube(s);
cut()
cylinder(20,20,20,center=true);
cylinder(16,16,16,center=true);
and 123Design)?
I assume that center part is hollow?
You might be able to see something useful using View/Wireframe. Looks
like that requires an F6 render first.
I'm a little surprised that the # and % modifiers don't help, but they
don't.
It's a little surprising that View/Show Edges doesn't combine with an
alpha setting to show the edges inside the object, but I wouldn't say
it's wrong.
On further tries, I'm not seeing the requirement for F6 that I thought I
saw.
In OpenSCAD the order of objects plays a role, whether a look inside into a
transparent object (alpha<1) is presented or not. Thus this object must be
evaluated last.
See this codes:
color("yellow",.5)cube (20, center =true); // transparent only for objects
already displayed
color("green",1) cube (10, center =true); // not visible
vs.
color("green",1) cube (10, center =true); // visible
color("yellow",.5)cube (20, center =true); // transparent only objects
already displayed
the problem is, you can't change the order in cases like the following
my trick to look through all coats in such a case is the temporal
redefinition of difference() into a union having the right order.
cube (5, center =true);
module difference()
color("green",.3)
children([1:$children-1]);
children(0);
