Terry
Sun, Feb 6, 2022 4:33 PM
We've somehow lost one of the four knobs on our 30 year old Candy gas hob. I'm
not surprised there's no match from the Candy site's (expensive) 13 offerings.
Ebay have sets of four which are more sensibly priced but I'm going to make my
own button. However I'm immersed in another (non-OpenSCAD) project, so although
I'd ideally like to try making it from scratch myself, as a refresher exercise
after a long gap, I've instead found this handy parameterised design.
https://www.thingiverse.com/thing:54024
That made it trivially simple to get to the first draft I've shown. But I'm
struggling with the next steps, to get the interior 'recessed' and looking
roughly like the original.
https://www.dropbox.com/s/8h6dt9sylmijjxh/ButtonGroup.jpg?raw=1
The bottom of the spindle hole is 5mm above the bottom of the button. When in
place the button is about 3mm above the surface, and has to be pressed before
turning. The original button has a small metal insert which flexes, so the
button be pulled off for cleaning. But I may simply use a screw against the flat
spindle section instead, and avoid a D shaped spindle hole,
Meanwhile I'm using a temporary fix from my shed workshop 'old knobs' box. But
any help in getting the button printed quickly would be much appreciated please.
Terry
Terry
DS
David Schooley
Sun, Feb 6, 2022 7:19 PM
I’ve done a few things similar to this where I took the outer part, which you have done, and then subtract off a slightly smaller version to get the interior. You would then have to go back and add the center section back to the model. It might be easier to do a 2D drawing of the overall shape and do a rotate_extrude to get the button. You could do the slotted hole two ways. The first is incorporate the round hole into the 2D drawing, so you get it by default with the rotation. Then you just add the slot. The other is to a simpler 2D drawing and subtract the round hole and the slot at the end.
Terry
> Terry
Terry Pinnell
Sun, Feb 6, 2022 7:33 PM
Thanks David, I’ll investigate those helpful suggestions. Meanwhile I printed that first draft and it looks reasonable, but hole is a tad too small.
Terry, East Grinstead, UK
Terry
>> Terry
Douglas Miller
Mon, Feb 7, 2022 3:25 PM
As a starter, try
// everything you have now
rotate_extrude() polygon([[0,0],[0,8],[14,8],[17,0]]);
adjusting corners of the polygon as needed.
Terry
As a starter, try
> Terry
BC
Bob Carlson
Mon, Feb 7, 2022 5:13 PM
This code previews fine with F5. However, it fails to render with F6. I added caps = true even though that is the default, but it did not help. On F6 I get the error message below. I can’t see from the error message what the problem might be.
Can someone point out my problem?
f(10, 8);
module f(w, r) {
shape = rect([6, 12], rounding = 2, anchor = LEFT);
path = semiCirclePath(radius = r, angle = 90, segments = 30);
path_sweep( shape, path, caps = true );
function semiCirclePath(radius, angle, segments) =
[for (i = [0:1:segments]) let(a = iangle/segments) [radiuscos(a), 0, radius*sin(a)]];
ERROR: CGAL error in CGAL_Nef_polyhedron3(): CGAL ERROR: assertion violation! Expr: ss_circle.has_on(sv_prev->point()) File: /Users/runner/work/openscad/openscad/../libraries/install/include/CGAL/Nef_3/polygon_mesh_to_nef_3.h Line: 265
Bob
Tucson AZ
f(10, 8);
module f(w, r) {
[for (i = [0:1:segments]) let(a = i*angle/segments) [radius*cos(a), 0, radius*sin(a)]];
Bob
Tucson AZ
Mon, Feb 7, 2022 6:35 PM
I don't really speak BOSL2, but it works OK for me once I add
to the top.
to the top.
BC
Bob Carlson
Mon, Feb 7, 2022 10:15 PM
I didn’t show it, but there is an include of BOSL2.
-Bob
Tucson AZ
to the top.
-Bob
Tucson AZ
On Feb 7, 2022, at 11:35, Jordan Brown <openscad@jordan.maileater.net> wrote:
to the top.
Mon, Feb 7, 2022 10:29 PM
Works for me too. You could try updating to the current BOSL2. There
was a bug sort of recently where some faces were reversed in polyhedra
that would lead to failed renders, though I don't know if it affected
sweeps.
-Bob
Tucson AZ
to the top.
sweeps.
> -Bob
> Tucson AZ
> include <BOSL2/std.scad>
> to the top.
BC
Bob Carlson
Tue, Feb 8, 2022 12:25 AM
That fixed it thanks. The behavior was quite bizarre in the old version. If I hit F6 with only 1 such object, it would render in BLUE, not the normal greenish, with no error message. The error messages would show up and there would be no render at all if there were 2 such objects.
-Bob
Tucson AZ
sweeps.
-Bob
Tucson AZ
to the top.
-Bob
Tucson AZ
sweeps.
> -Bob
> Tucson AZ
> to the top.
BC
Bob Carlson
Tue, Feb 8, 2022 12:28 AM
Having spent a LOT of time with the path_sweep documentation, I think it needs a lot of work. It needs to start with a much simpler explanation of simple cases before it dives into various normals and twisting and so on. It’s a maze of twisty little passages, all different.
-Bob
Tucson AZ
-Bob
Tucson AZ
sweeps.
-Bob
Tucson AZ
to the top.
-Bob
Tucson AZ
-Bob
Tucson AZ
sweeps.
> -Bob
> Tucson AZ
> to the top.
