Crash while render surface with CGAL on 2015.3
G
glebkudr
Mon, Mar 23, 2015 8:52 AM
  1. I have a png file with the height map, 500x500 pixels.
  2. I load this png as a surface.
  3. I intersect or union or diff this surface with simple cylinder.
  4. I refresh the view in F5 mode and all is ok.
  5. I press F6 button to create stl representation and my Openscad windows
    process starts consume all memory until the computer crashes.
If I miss the 3 step and export the surface 'as is' than everything is all
right.
Could you give me some advice, how to use the surface in my model?
View this message in context: http://forum.openscad.org/Crash-while-render-surface-with-CGAL-on-2015-3-tp12148.html
1. I have a png file with the height map, 500x500 pixels. 2. I load this png as a surface. 3. I intersect or union or diff this surface with simple cylinder. 4. I refresh the view in F5 mode and all is ok. 5. I press F6 button to create stl representation and my Openscad windows process starts consume all memory until the computer crashes. If I miss the 3 step and export the surface 'as is' than everything is all right. Could you give me some advice, how to use the surface in my model? -- View this message in context: http://forum.openscad.org/Crash-while-render-surface-with-CGAL-on-2015-3-tp12148.html Sent from the OpenSCAD mailing list archive at Nabble.com.
EN
Ed Nisley
Mon, Mar 23, 2015 12:56 PM
Each of those quarter-million pixels produces at least half a dozen
triangular faces, so that simple model might have a million surfaces,
each with three vertexes. Each vertex requires a handful of floating
point numbers, so ...
For my 3D printed cookie presses and chocolate molds, I set the image
resolution to 4 pixel/mm for molds around 40 mm. The 17 March 2015
version of OpenSCAD turns a 160x176 pixel image into an STL file in
about 100 seconds.
If you reduce your height map to 250x250 pixels, it might start working...
Ed
softsolder.com
On 03/23/2015 04:52 AM, glebkudr wrote: > the height map, 500x500 pixels. Each of those quarter-million pixels produces at least half a dozen triangular faces, so that simple model might have a million surfaces, each with three vertexes. Each vertex requires a handful of floating point numbers, so ... For my 3D printed cookie presses and chocolate molds, I set the image resolution to 4 pixel/mm for molds around 40 mm. The 17 March 2015 version of OpenSCAD turns a 160x176 pixel image into an STL file in about 100 seconds. If you reduce your height map to 250x250 pixels, it *might* start working... -- Ed softsolder.com
