Are All the Language Features in src/lexer.l and src/parsery.y
N
NateTG
Sun, Sep 2, 2018 9:58 PM
I've been wondering about the feasibility of writing an OpenSCAD converter or
interpreter so I've been looking through the source to for the specification
of the grammar and a comprehensive sense of built-in capabilities.  So far
I'm looking at:
/src/lexer.l
/src/parser.y
for the grammar
and
/src/scadlexer.cpp
for a list of "built-in" capabilities.
Is that enough to give me a reasonably comprehensive list of stuff that's in
the language?
Also, I'm wondering what keywordSet[2] is for.  Can anyone tell me?
I've been wondering about the feasibility of writing an OpenSCAD converter or interpreter so I've been looking through the source to for the specification of the grammar and a comprehensive sense of built-in capabilities. So far I'm looking at: /src/lexer.l /src/parser.y for the grammar and /src/scadlexer.cpp for a list of "built-in" capabilities. Is that enough to give me a reasonably comprehensive list of stuff that's in the language? Also, I'm wondering what keywordSet[2] is for. Can anyone tell me? -- Sent from: http://forum.openscad.org/
Sun, Sep 2, 2018 10:27 PM
On 09/02/2018 11:58 PM, NateTG wrote:
/src/lexer.l
/src/parser.y
Yep, that describes the full parser.
The actual built-ins can be found searching for Builtins::init(),
see:
https://github.com/openscad/openscad/blob/master/src/builtin.cc
/src/scadlexer.cpp > for a list of "built-in" capabilities.
That lexer is GUI only, it has no influence on the actual
language, but it should be in sync for most keywords.
On 09/02/2018 11:58 PM, NateTG wrote: > /src/lexer.l > /src/parser.y > Yep, that describes the full parser. The actual built-ins can be found searching for Builtins::init(), see: https://github.com/openscad/openscad/blob/master/src/builtin.cc > /src/scadlexer.cpp > for a list of "built-in" capabilities. > That lexer is GUI only, it has no influence on the actual language, but it *should* be in sync for most keywords. ciao, Torsten.
Sun, Sep 2, 2018 10:29 PM
scadlexer.cpp is not authoritative. I don't see "intersection_for", so at
least that is missing.
keywordSet[2] appears to be used for keywords used in doxygen comments, in
case you happen to process your openscad source code using doxygen. These
keywords are not part of openscad.
On 2 September 2018 at 17:58, NateTG nate-openscadforum@pedantic.org
or
specification
I'm looking at:
/src/lexer.l
/src/parser.y
for the grammar
and
/src/scadlexer.cpp
in
the language?
scadlexer.cpp is not authoritative. I don't see "intersection_for", so at least that is missing. keywordSet[2] appears to be used for keywords used in doxygen comments, in case you happen to process your openscad source code using doxygen. These keywords are not part of openscad. On 2 September 2018 at 17:58, NateTG <nate-openscadforum@pedantic.org> wrote: > I've been wondering about the feasibility of writing an OpenSCAD converter > or > interpreter so I've been looking through the source to for the > specification > of the grammar and a comprehensive sense of built-in capabilities. So far > I'm looking at: > > /src/lexer.l > > /src/parser.y > > for the grammar > > and > > /src/scadlexer.cpp > > for a list of "built-in" capabilities. > > Is that enough to give me a reasonably comprehensive list of stuff that's > in > the language? > > Also, I'm wondering what keywordSet[2] is for. Can anyone tell me? > > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
AB
Antonio Bueno
Sun, Sep 2, 2018 10:35 PM
I looked into this last february:
https://github.com/openscad/openscad/issues/2292 and scadlexer.cpp wasn't
enough
Maybe the first image in that link and the text below can help you.
El dom., 2 sept. 2018 a las 23:59, NateTG (nate-openscadforum@pedantic.org)
or
specification
I'm looking at:
/src/lexer.l
/src/parser.y
for the grammar
and
/src/scadlexer.cpp
in
the language?
Saludos,
Antonio
I looked into this last february: https://github.com/openscad/openscad/issues/2292 and scadlexer.cpp wasn't enough Maybe the first image in that link and the text below can help you. El dom., 2 sept. 2018 a las 23:59, NateTG (<nate-openscadforum@pedantic.org>) escribió: > I've been wondering about the feasibility of writing an OpenSCAD converter > or > interpreter so I've been looking through the source to for the > specification > of the grammar and a comprehensive sense of built-in capabilities. So far > I'm looking at: > > /src/lexer.l > > /src/parser.y > > for the grammar > > and > > /src/scadlexer.cpp > > for a list of "built-in" capabilities. > > Is that enough to give me a reasonably comprehensive list of stuff that's > in > the language? > > Also, I'm wondering what keywordSet[2] is for. Can anyone tell me? > > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > -- Saludos, Antonio
Sun, Sep 2, 2018 10:42 PM
Oops, my local repo was out of date. "intersection_for" is now mentioned in
scadlexer.cpp.
converter or
specification
I'm looking at:
/src/lexer.l
/src/parser.y
for the grammar
and
/src/scadlexer.cpp
in
the language?
Oops, my local repo was out of date. "intersection_for" is now mentioned in scadlexer.cpp. On 2 September 2018 at 18:29, doug moen <doug@moens.org> wrote: > scadlexer.cpp is not authoritative. I don't see "intersection_for", so at > least that is missing. > > keywordSet[2] appears to be used for keywords used in doxygen comments, in > case you happen to process your openscad source code using doxygen. These > keywords are not part of openscad. > > On 2 September 2018 at 17:58, NateTG <nate-openscadforum@pedantic.org> > wrote: > >> I've been wondering about the feasibility of writing an OpenSCAD >> converter or >> interpreter so I've been looking through the source to for the >> specification >> of the grammar and a comprehensive sense of built-in capabilities. So far >> I'm looking at: >> >> /src/lexer.l >> >> /src/parser.y >> >> for the grammar >> >> and >> >> /src/scadlexer.cpp >> >> for a list of "built-in" capabilities. >> >> Is that enough to give me a reasonably comprehensive list of stuff that's >> in >> the language? >> >> Also, I'm wondering what keywordSet[2] is for. Can anyone tell me? >> >> >> >> >> >> -- >> Sent from: http://forum.openscad.org/ >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > >
N
NateTG
Mon, Sep 3, 2018 12:50 AM
see:
That's exactly the info I was looking for.  Thanks.
tp3 wrote > ... > The actual built-ins can be found searching for Builtins::init(), > see: > > https://github.com/openscad/openscad/blob/master/src/builtin.cc > > ... > ciao, > Torsten. > ... That's exactly the info I was looking for. Thanks. -- Sent from: http://forum.openscad.org/
