So, I have been working on a way to apply top and bottom fillets/chamfers to
complex solids for about 3 days now. After probably 20 hours, I am finally
ready to show it off (Not sure if someone else has done it like this, but I
have not seen anyone try this approach).
This module takes slices of the model at even intervals and offsets them by
the trig functions of a circle. It produces fillets that when sized to match
a 3D print layer height come out great on my 3D printer.
You can see the library and some examples of it in use on thingiverse:
https://www.thingiverse.com/thing:2461392
My only grip with it is each layer is flat. I tried and tried to figure out
a way to "connect" the layers of the fillet but could never come to a
solution. If anyone has any ideas on how to "connect" the layers of the
fillet, I would be very grateful.
I was thinking about what could be implemented in OpenSCAD itself to
accomplish this, and I came up with the following idea:
Add "offset" to linear_extrude. It would work almost exactly the same way as
scale, but instead of scaling, it would use the same "math" as offset. This
way I could extrude from layer to layer and offset as I work up. That would
allow for perfectly smooth edges and would reduce the number of edges by at
least a factor of 2.
View this message in context: http://forum.openscad.org/My-take-on-a-fillets-solution-in-3D-and-a-possible-feature-suggestion-tp21971.html
