kintel wrote
..it could be easier to use than doing a sweep.
This heavily depends on what kind of sweep() or skin() you use. Don't know
whether you have looked at the code
http://forum.openscad.org/Rendering-fails-difference-between-F5-and-F6-tp15041p15100.html
I am using an own version from NacaSweep.scad described here
http://www.thingiverse.com/thing:900137 , which is much more basic than
the "official" one you might know, as it knits just a matrix (a vector of
vectors describing a series of non-intersecting polygons already placed in
3D space) into a polyhedron.
Before I decided to implement this version, I tried out the "official" one
and found it too complicated and restricted for my purposes - beside the
lack of documentation also in code.
Rudolf
View this message in context: http://forum.openscad.org/Rendering-fails-difference-between-F5-and-F6-tp15041p15150.html
Nice - I’ll try to have a look.
The purpose of the “official” sweep and skin is to explore the functionality and interface of such functions, in order to make better decision when eventually creating built-in and long-term supported implementations of it.
If you could provide some insights into what you need, what was missing in the original implementation etc., that would be very helpful.
I never played around with skin(). But as far as I remember, I didn't like
the interface of sweep(), as its prototyp was too restricting. I'm talking
about this one
module sweep(shape, path_transforms, closed=false)
So I decided to reimplement it, just demanding a regular matrix - which
represents a series of polygons in 3D-space as already mentioned. This
series may be freely composed: using any kind of transformations, finite and
non-linear in any order, interpolation schemes (e.g. nSpline()) and
unlimitedly parametrized shapes (e.g. airfoils with non-linear transitions
along the path).
See my example of a loop propeller (also just a fast scetch for this post),
using a 7D interpolation. I guess you can read my shortcuts: R, Rx, Tx and
so on operate over objects, Rx_ Tz_ and so operate over vectors (shapes)
http://forum.openscad.org/file/n15160/showcase3.png
and without interpolation
C = gen_dat(A, 100); // generate data
you'll still get this
http://forum.openscad.org/file/n15160/showcase4.png
View this message in context: http://forum.openscad.org/Rendering-fails-difference-between-F5-and-F6-tp15041p15160.html
This sounds exactly like skin(), as used here:
https://github.com/openscad/list-comprehension-demos#forma-candle-holderscad
Does that differ in any way, if so, what are you missing from skin()?
(I didn’t have the chance to read your code yet)
Hi
Maybe you are interested in this:
https://www.youtube.com/watch?v=MWa8sEgpOrM
View this message in context: http://forum.openscad.org/Rendering-fails-difference-between-F5-and-F6-tp15041p15164.html
Meanwhile I had a look at your skin() example. You are right, obviously
skin() and my sweep() are at least syntactically interchangeable and give
the same results on my examples - however the implementations differ a lot.
Is/was it part of any libary? Anyway, in environments without debugging
facilities I always prefer to use my own code :-)
@jpmendes
Hey, this film shows only E-guitars. No 3D-acoustics involved :-(
View this message in context: http://forum.openscad.org/Rendering-fails-difference-between-F5-and-F6-tp15041p15165.html
Thanks jpmendes, most impressive demonstration.
While I can see a lot of debate goes into refining the power of the
openSCAD programming language and how it is rendered, I am also
privileged to observe the evolution of extremely powerful design tools
that smart people will apply to solve many problems. Creating a really
good musical instrument in conventional materials is very hard, and not
to be dismissed lightly, but, when design software, for example
openSCAD, and material improvements are accumulated over time, then the
gap will be gradually closed. I hope the conventional instruments
continue to be made, but I think the understanding of how what makes a
good instrument 'good' will be understood so much better when 3-D
productions tools allow experimentation inside well defined parameters
to be made reliably.
The idea of creating the "formula" for a bell horn of a bass clarinet is
a step in that direction.
I am sure if there was time, the "back-end" stories to most of the
openSCAD forum discussions, would be equally inspiring.
Cheers, Rob
On 15/12/15 06:54, jpmendes wrote:
Hi
@jpmendes
Thingiverse user mechadense has done some great work on horns.
http://www.thingiverse.com/thing:218241
Just needs a bit mor ework to finish it up for general OpenSCAD use... (hint
View this message in context: http://forum.openscad.org/Rendering-fails-difference-between-F5-and-F6-tp15041p15168.html
On Dec 14, 2015, at 15:53 PM, Parkinbot rudolf@parkinbot.com wrote:
Meanwhile I had a look at your skin() example. […]
It’s part of the exploration of new functionality. I’m interested in whether this is a good function to offer, what sort of added/changed features are needed and interface ideas.
kintel wrote
.... I’m interested in whether this is a good function to offer,
I guess you know that my answer will be yes. Connected with an interpolation
scheme it is really powerful.
I just had a look, how skin() behaves when it has to connect polygons with
different number of points (mine doesn't do that at all for a good reason).
The result is somehow unexpected.
use
scad-utils/transformations.scad
use
scad-utils/lists.scad
use
scad-utils/shapes.scad
use
<skin.scad>
r=50;
height=140;
layers = 2;
skin([for (i=[0:layers-1])
transform(translation([0,0,iheight/layers]) * rotation([0,0,-0i]),
circle($fn=6+2*i,r=r))]);
http://forum.openscad.org/file/n15170/showcase5.png
Why would one split the lines of a polygon? Is this semantics a hack? I'd
expect unpaired triangles as natural semantics. And I would also expect the
result to be convex (at least in this case).
And an immediate feature request would be: adding furcations like a
bifurcation and an inverse (anastomosis) to it.
a bifurcation matrix would be
and the inverse:
It is easy to calculate furcations, but hard to connect them in a proper way
using OpenSCAD language means.
View this message in context: http://forum.openscad.org/Rendering-fails-difference-between-F5-and-F6-tp15041p15170.html
