I also tried filteringe the STL- files in Meshlab with the Remove T-vertices
etc.
That worked in that way that the error message changes into this:
S/aved backup file: C:/Users/Eigenaar/Documents/OpenSCAD/backups/basklarinet
alles-backup-aOk10684.scad
ERROR: CGAL error in CGALUtils::applyBinaryOperator difference: CGAL ERROR:
assertion violation! Expr: itl != it->second.end() File:
/data/OpenSCAD/libraries-mingw64-master/mxe-w64/usr/x86_64-w64-mingw32.static/include/CGAL/Nef_3/SNC_external_structure.h
Line: 1102
Geometries in cache: 3637
Geometry cache size in bytes: 41353920
CGAL Polyhedrons in cache: 7
CGAL cache size in bytes: 82756208
Total rendering time: 0 hours, 2 minutes, 43 seconds
Simple: yes
Vertices: 16551
Halfedges: 98478
Edges: 49239
Halffacets: 65382
Facets: 32691
Volumes: 2
Rendering finished./
View this message in context: http://forum.openscad.org/Rendering-fails-difference-between-F5-and-F6-tp15041p15072.html
On Dec 9, 2015, at 17:31 PM, Johan Jonker johangjonker@zonnet.nl wrote:
The first file is the Openscad file producing the outside en inside of the
bell.
I got a 404 on the first file.
Are you saying that the STL files are modelled and exported from OpenSCAD as well?
The STL files are fine. no problem with them.
This suggests the load is causng a problem.
E.g. There are many very small step-like ridges around the flare of the
bell.
Its probable that the decimal points are being truncated and the vertices
that are very close together are not staying unique.
View this message in context: http://forum.openscad.org/Rendering-fails-difference-between-F5-and-F6-tp15041p15078.html
@ Kintel
Oh I am sorry, a type in the filename. It is modified now.
Because rendering became too slow i modelled the outside and inside in
OpenSCAD and used the difference function of the import of them in a
separate OpenSCAD file.
View this message in context: http://forum.openscad.org/Rendering-fails-difference-between-F5-and-F6-tp15041p15080.html
@neon,
That is interesting. What tool do you use to visualize that?
The only reason can be the thickness of the cylinders I use for the top and
bottom of the segments of the bell. I changed it into a very small value. In
MeshLab that looks better, but I can't see it as clear as in your picture.
module cylinder_pie(angle1, angle2, dx1,dx2,dy1,dy2,r1,r2,top,dr)
// draw top and bottom cylinders
// rotate the cylinder
// hull the cylinders
// trick: draw an extra thick and large cylinder when the top is
reached and
d=0.00001;
hull()
translate([ 0,dx1,dy1])
rotate( angle1, ([1,0,0]))
translate([0,0,-d])
cylinder(d,r1, r1, center=false);
echo("top:", dx1,dy1,angle1,d,r1);
translate([ 0,dx2,dy2])
rotate( angle2, ([1,0,0]))
translate([0,0,d])
cylinder(d+top,r2, r2, center=false);
echo("bottom:", dx2,dy2,angle2,d+top,r2);
if (top > 0)
translate([0,0,d])
cylinder(d+top,r2+dr, r2+dr, center=false);
View this message in context: http://forum.openscad.org/Rendering-fails-difference-between-F5-and-F6-tp15041p15081.html
This is the result now: a lot of non-manifold edges detected in MeshLab.
Later this day I will see how to fix that. Suggestions are welcome (I am new
to Meshlab).
http://forum.openscad.org/file/n15082/manifold.jpg
View this message in context: http://forum.openscad.org/Rendering-fails-difference-between-F5-and-F6-tp15041p15082.html
OK problem appears to definately be caused by the way you're hulling.
What's happening is the very small slices (0.01 or smaller) are creating
artifacts.
Ideally you should be able to use a value of 0.1 (say) for thickness and not
see much visual difference.
The trick to make this happen is to step through the loop in a different
way.
You want the parameterization to be by looping through i, i+1 and hulling
between them.
IMHO This means altering your entire procedure of calculating. You're using
separate calcs for dx, dx2 (etc) pairs of all your variables.
These do not always overlap - so you get cracks.
Ideally re-parameterize so that each time through the loop the same value is
calculated.
Basically drop the second calc entirely and just make one. Increment your
index to get each profile.
So form of result could be something like this but does not have to be in
list form. (I'm just trying to make code clear)...
diameters = list_of_inner_diameters(); // a list generated somehow
radii = list_of_radii(); // a list generated somehow - same length
positions = list_of_translations(); // - same length
angles = list_of_rotations(); // - same length
for (i=[0:1:len(diameters)-1])
hull() {
translate(positions[i])
rotate(angles[i])
cylinder(diameters[i], r=radii[i], center=false);
// next step
translate(positions[i+1])
rotate(angles[i+1])
cylinder(diameters[i+1], r=radii[i+1], center=false);
You can see what's wrong if you change the following to larger numbers like
these
// object: bass clarinet bell
// version: 4
// design: J.G.Jonker
// website: sax.jonker.co
// date: 7-12-2015
$fn=14;
maxheight = 160; // Height
d_btm_inside = 25; // dia at base
d_btm_wall = 10; // outer base dia (added to d_btm_inside)
d_top_inside = 144; // dia of flare
d_top_wall = 16; // notional thickness...
rotatie_top = 65; // angle of flare
mildfactor = 0.25; // Z-move at middle
astraal = maxheight/sin(rotatie_top);
// rotate([180-rotatie_top,0,0])
// translate([0,0,-150]) calyx(buiten=true);
translate([0,0,-150]) calyx(buiten=false);
// translate([0,0,-maxheight/2])
// cube(size=[20,60,maxheight*2], center=true);
module calyx(buiten) {
delta = 16;
delta2 = delta/2;
delta3 = delta2/2;
delta4 = delta3/2;
// Main body of bell
for (height = [0:delta:maxheight-4delta])
calyx_segment(height, delta, buiten,0);
// start lip curve
for (height = [maxheight-8delta2:delta2:maxheight-4delta2])
calyx_segment(height, delta2, buiten,0);
// mid lip curve
for (height = [maxheight-7delta3:delta3:maxheight-4delta3])
calyx_segment(height, delta3, buiten,0);
// end lip curve
for (height = [maxheight-7delta4:delta4:maxheight-2*delta4])
calyx_segment(height, delta4, buiten,0);
// final flare
for (height = [maxheight-delta4:delta4:maxheight-delta4])
calyx_segment(height, delta4, buiten,d_top_wall);
module calyx_segment(height, delta, buiten, top) {
percentage = height/maxheight;
percentage2 = (height+delta)/maxheight;
d_inside = d_top_inside - pow((1-percentage),0.25) * (d_top_inside -
d_btm_inside);
d_inside2 = d_top_inside - pow((1-percentage2),0.25) * (d_top_inside -
d_btm_inside);
rc = atan(4maxheightpow((d_top_inside - d_btm_inside),-4) *
pow(d_top_inside - d_inside,3));
rc2 = atan(4maxheightpow((d_top_inside - d_btm_inside),-4) *
pow(d_top_inside-d_inside2,3));
// determine wall thickness
// keep the outside straight until d_top_wall is reached
d_wall = ((d_inside + d_top_wall) < (d_btm_inside+d_btm_wall) ?
(d_btm_inside+d_btm_wall - d_inside):
d_top_wall)/2;
d_wall2 = ((d_inside2 + d_top_wall) < (d_btm_inside+d_btm_wall) ?
(d_btm_inside+d_btm_wall - d_inside2):
d_top_wall)/2;
dx_raw = (d_inside2-d_inside)/2;
s_raw = sqrt(dx_raw*dx_raw+delta*delta);
dx1 = d_wall * sin(rc);
dx2 = d_wall2 * sin(rc2);
dy1 = d_wall * cos(rc);
dy2 = d_wall2 * cos(rc2);
// echo("delta's", rc,rc2,dx1,dx2,dy1,dy2);
// echo("y x", d_inside, d_inside2, height, height+delta);
// echo("hoek", hoek, hoek2);
hoek = rotatie_top*percentage;
hoek2 = rotatie_top*percentage2;
if (buiten == true) {
cylinder_pie(hoek, hoek2,
-astraal*(1-cos(hoek*percentage))*mildfactor,
-astraal*(1-cos(hoek2*percentage2))*mildfactor,
height-dy1, height+delta-dy2, d_inside/2+dx1, d_inside2/2+dx2, top, 0);
} else {
height, height+delta, d_inside/2, d_inside2/2, top, 10);
module cylinder_pie(angle1, angle2, dx1,dx2,dy1,dy2,r1,r2,top,dr) {
// the top is reached and
d=1;
//echo("top", top,dr);
hull() {
translate([0,0,-d])
translate([0,0,d])
if (top > 0) {
translate([0,0,d])
View this message in context: http://forum.openscad.org/Rendering-fails-difference-between-F5-and-F6-tp15041p15083.html
great Neon22, many thanks!!!
I modified the code according to your suggestions. Only I could not find a
way to fill a list, but it could be all done by functions. The result was
the rendering went much faster. Maybe that is already a sign that there are
no very complex things anymore. F6 rendering
The code is now as follows:
// bass clarinet bell
// version 6
// J.G.Jonker
// date: 10-12-2015
$fn=80;
maxheight = 160;
d_btm_inside = 41; // binnendiameter onderzjde
d_btm_wall =17.5; // dubbele van wanddikte onderzijde
d_top_inside = 138; // binnendiameter bovenzijde
d_top_wall = 4; // dubbele van wanddikte bovenzijde
t_top = 60;
rotatie_top = 45;
mildfactor = 0.5;
h_tenon = 5;
outside = true;
both = false;
// functions
function height(i) = imaxheight/100;
function d_inside(i) = d_top_inside
- pow((1-i/100),0.25) (d_top_inside - d_btm_inside);
function rc(i) = atan(4maxheightpow((d_top_inside - d_btm_inside),-4)*
pow(d_top_inside - d_inside(i),3));
function d_wall(i) = (d_inside(i) + d_top_wall) < (d_btm_inside+d_btm_wall)
(d_btm_inside+d_btm_wall - d_inside(i))/2:
(d_top_wall)/2;
function dx(i) = d_wall(i)* sin(rc(i));
function dy(i) = d_wall(i) * cos(rc(i));
function rotation(i) = rotatie_top*i/100;
function shift(i) = height(i) < h_tenon? 0
:-((height(i)-h_tenon)/maxheight)10;
function cshift(i) =
-astraal(1-cos(rotation(i)*i/100))*mildfactor+shift(i);
delta = 4; //
delta2 = delta/2;
delta3 = delta2/2;
delta4 = delta3/2;
delta5 = delta4/2;
union()
calyx_segments(0, delta, 100 - 4delta); // moet veelvoud van delta
zijn
calyx_segments(100-3delta, delta2, 100-4delta2);
calyx_segments(100-3delta2, delta3, 100-4delta3);
calyx_segments(100-3delta3, delta4, 100-4delta4);
calyx_segments(100-3delta4, delta5, 100-delta5);
// add the tenon to connect to the bow
if (outside==true)
translate([0,0,-5])
cylinder(5.1,(d_btm_inside +d_btm_wall/2)/2, (d_btm_inside
+d_btm_wall/2)/2);
else
translate([0,0,-10]) cylinder(11,d_btm_inside/2,
d_btm_inside/2);
module calyx_segments(i_start, delta,i_end)
echo(";;", i_start, delta, i_end);
if (outside == false)
for (i=[i_start:delta:i_end])
top_d = ((i+delta)==100)? 4:0;
echo("in i:",i, delta, i+delta, top_d);
hull()
translate([0,cshift(i),height(i)])
rotate(rotation(i), ([1,0,0]) )
cylinder(0.1, d_inside(i)/2,d_inside(i)/2, center=false);
// next step
translate([0,cshift(i+delta),height(i+delta)])
rotate(rotation(i+delta), ([1,0,0]) )
cylinder(0.1+top_d, d_inside(i+delta)/2,d_inside(i+delta)/2,
center=false);
else
echo("out i:",i, delta, i+delta);
hull()
translate([0,cshift(i),height(i)-dy(i)])
rotate(rotation(i), ([1,0,0]))
cylinder(0.1, d_inside(i)/2+d_wall(i),d_inside(i)/2+d_wall(i),
center=false);
// next step
translate([0,cshift(i+delta),height(i+delta)-dy(i+delta)])
cylinder(0.1+top_d,
d_inside(i+delta)/2+d_wall(i+delta),d_inside(i+delta)/2+d_wall(i+delta),
center=false);
View this message in context: http://forum.openscad.org/Rendering-fails-difference-between-F5-and-F6-tp15041p15093.html
Johan Jonker wrote
@neon,
It looks like Netfabb http://www.netfabb.com/downloadcenter.php?basic=1
to me.
View this message in context: http://forum.openscad.org/Rendering-fails-difference-between-F5-and-F6-tp15041p15097.html
sorry - its the last version of Deep Exploration which got sold to SAP and
therefore is no longer available to mere mortals. I don't like to tell
people what it is because they just can't get it anymore :(
For polygonal 3D modelling I prefer wings3d as it produces watertight models
by default. Its internal structure is edge based and not face based like
most modellers.
View this message in context: http://forum.openscad.org/Rendering-fails-difference-between-F5-and-F6-tp15041p15099.html
