how to create a gaudi' arch (a catenary arch)?
the formula should be:
y=a cosh(x/a)= (a/2)*[e^(x/a)+e^(-x/a)]
Thank you in advance,
OdaepO
This might help
https://github.com/nophead/NopSCADlib?tab=readme-ov-file#catenary.
On Wed, 17 Jan 2024 at 23:21, oda via Discuss discuss@lists.openscad.org
OdaepO
Maybe something like this?
a = 5;
function y(x) = (a/2)*(exp(x/a)+exp(-x/a));
points = [for (x = [-10 : 0.1 : 10]) [x,y(x)]];
linear_extrude(10) polygon(points);
Cheers,
Steve
OdaepO
I did a catenary arch thing (probably not as good as the other posters)
sometime before 2018. You will probably need to watch out for floating
point math snafus. I was doing large elongated catenary domes and the
points got too close to each other. I could render my dome complex but
when I joined it with other structures it disappeared (which at the time
was typical for a poorly formed solid unioning with another)
On Wed, Jan 17, 2024 at 6:22 PM oda via Discuss discuss@lists.openscad.org
OdaepO
