Third Skew on a Cube
ats3788
Mon, Dec 31, 2018 3:15 PM
Hello I have this Cube and it has two skew side but I have no Idea to get a
third shew and the forth should be in a perfect 90 degree angle.
My code so far.
$fn=200;
Radius = 10;
dRadius = 2 * Radius;
Length = 45 - dRadius;
WidthD = 75 - dRadius;
Width  =  WidthD - dRadius * 2;
Height = 75;
cornerRadius = 10;
inRedBox(0,0,0);
//inRedBox(0,50,0);
module inRedBox(x,y,z)
translate([x, y, z]){
squerefunel(Length, WidthD , Height);
translate([3,-3,3]) squerefunel(Length - 6, WidthD - 6 , Height +100);
module squerefunel(x, y, z ) {
Skew1 = 5;
Skew2 = 10;
//translate([x + 140 , - y - Radius , 0]) cube ([ dRadius ,  y + dRadius,
z]);
minkowski(){
  rotate([90,0,0]) linear_extrude(height = x )
polygon(points=[[0,0],[-Skew1, z],[y+Skew2, z],[y  , 0]]);
  translate([ Width-dRadius,-Radius,0]) {
     cylinder(r=Radius, h=0.01);
Hello I have this Cube and it has two skew side but I have no Idea to get a third shew and the forth should be in a perfect 90 degree angle. My code so far. $fn=200; Radius = 10; dRadius = 2 * Radius; Length = 45 - dRadius; WidthD = 75 - dRadius; Width = WidthD - dRadius * 2; Height = 75; cornerRadius = 10; inRedBox(0,0,0); //inRedBox(0,50,0); module inRedBox(x,y,z) { union() { translate([x, y, z]){ difference() { squerefunel(Length, WidthD , Height); translate([3,-3,3]) squerefunel(Length - 6, WidthD - 6 , Height +100); } } } } module squerefunel(x, y, z ) { Skew1 = 5; Skew2 = 10; //translate([x + 140 , - y - Radius , 0]) cube ([ dRadius , y + dRadius, z]); minkowski(){ rotate([90,0,0]) linear_extrude(height = x ) polygon(points=[[0,0],[-Skew1, z],[y+Skew2, z],[y , 0]]); translate([ Width-dRadius,-Radius,0]) { cylinder(r=Radius, h=0.01); } } } -- Sent from: http://forum.openscad.org/
ats3788
Tue, Jan 1, 2019 6:34 PM
I got it by myself. I thought I hate this polyhedron lets give it a chance
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Primitive_Solids#polyhedron
this make it real easy to understand
so that is my code
$fn=200;
Radius = 10;
Height = 75;
cornerRadius = 10;
inRedBox(0,0,0);
// inRedBox(0,50,0);
CubeFaces = [
[0,1,2,3],  // bottom
[4,5,1,0],  // front
[7,6,5,4],  // top
[5,6,2,1],  // right
[6,7,3,2],  // back
[7,4,0,3]]; // left
translate([3,3,3]) squerefunel(Length - 6, WidthD - 6 , Height +100);
CubePoints = [
[ 0 ,  0,  0 ],  //0
[ x ,  0,  0 ],  //1
[ x,  y,  0 ],  //2
[ 0,  y,  0 ],  //3
[-2.5,  0,  z ],  //4
[ x+2.5,  0,  z ],  //5
[ x+2.5,  y+5,  z ],  //6
[-2.5,  y+5,  z ]]; //7
minkowski(){
  polyhedron(CubePoints, CubeFaces);
I think the polyhedron will be pretty helpful in the future
I got it by myself. I thought I hate this polyhedron lets give it a chance https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Primitive_Solids#polyhedron this make it real easy to understand so that is my code $fn=200; Radius = 10; dRadius = 2 * Radius; Length = 45 - dRadius; WidthD = 75 - dRadius; Width = WidthD - dRadius * 2; Height = 75; cornerRadius = 10; inRedBox(0,0,0); // inRedBox(0,50,0); CubeFaces = [ [0,1,2,3], // bottom [4,5,1,0], // front [7,6,5,4], // top [5,6,2,1], // right [6,7,3,2], // back [7,4,0,3]]; // left module inRedBox(x,y,z) { union() { translate([x, y, z]){ difference() { squerefunel(Length, WidthD , Height); translate([3,3,3]) squerefunel(Length - 6, WidthD - 6 , Height +100); } } } } module squerefunel(x, y, z ) { CubePoints = [ [ 0 , 0, 0 ], //0 [ x , 0, 0 ], //1 [ x, y, 0 ], //2 [ 0, y, 0 ], //3 [-2.5, 0, z ], //4 [ x+2.5, 0, z ], //5 [ x+2.5, y+5, z ], //6 [-2.5, y+5, z ]]; //7 minkowski(){ polyhedron(CubePoints, CubeFaces); cylinder(r=Radius, h=0.01); } } I think the polyhedron will be pretty helpful in the future -- Sent from: http://forum.openscad.org/
Ronaldo
Thu, Jan 3, 2019 2:28 PM
You could avoid polyhedron and minkowski in your model. Just do a shallow
linear_extrude() of an offseting of a rectangle for each top and bottom
surfaces and hull() them.
You could avoid polyhedron and minkowski in your model. Just do a shallow linear_extrude() of an offseting of a rectangle for each top and bottom surfaces and hull() them. -- Sent from: http://forum.openscad.org/
