A couple of questions for the development team please:
Q1a Can I build without running the test suite?
Q1b is it possible to build multiple versions of OpenSCAD for testing
without breaking a build using the normal debian repo?
rogerw@fj-e754:~$ !6859 sudo flatpak run org.openscad.OpenSCAD error:
app/org.openscad.OpenSCAD/x86_64/master not installed If I run the
flatpak using
rogerw@fj-e754:~$ flatpak run org.openscad.OpenSCAD Qt: Session
management error: Could not open network socket
I understand why the Qt error might happen, [its not running sudo], but
it does at least run, it is now at OpenSCAD
https://www.openscad.org/version 2026.04.26.fp (git b38f68881)
The normal System Update process breaks with the error ,
app/org.openscad.OpenSCAD/x86_64/master not installed. Can I fix this
problem or ignore it.
thanks in advance. Roger.
On 30.06.26 11:55, Roger Whiteley via Discuss wrote:
Catch2 should not be required, if it's missing, that will only
disable building the tests that are based on it.
There should not be any special things needed for building on
Debian12 (or Debian13). If there's something not covered by
default, it would be helpful to see a PR or issue as those
type of issues are easy to miss on a living dev machine.
Yes, use cmake argument -DENABLE_TESTS=OFF - this will disable
both the Catch2 based test and also the big test suite.
Yes, you don't need to install. OpenSCAD runs fine from the
build folder too, e.g. somethings like:
cmake -S . -B build -DEXPERIMENTAL=ON -DUSE_BUILTIN_OPENCSG=ON ...
cmake --build build
./build/openscad
I don't know what's broken with that flatpak stuff, if there's
no other app installed, maybe it's worth cleaning up everything
and using the fully non-root and non-system steps (= using the
--user flag) from
https://github.com/flathub/org.openscad.OpenSCAD
