OpenSCAD and data flow languages
Mon, Oct 3, 2016 6:36 PM
Richard Urwin wrote:
Have you considered that OpenSCAD is to all external purposes a Data Flow
language that bears striking similarities to languages such as SISAL? (In
fact making OpenSCAD more like SISAL would be wonderful -- there's more
orthogonality and more powerful structures there,
I'm wondering what it would mean to "make OpenSCAD more like SISAL".
Wikipedia describes SISAL as a "single assignment functional programming
language with strict semantics", and that also describes OpenSCAD.
We've had discussions in the past about making OpenSCAD more like a
functional language. This would entail making functions, modules and
geometric shapes into first class values. We could also add pattern
matching, a module system (namespaces) and a record type.
But you said Data Flow language, not functional language. I have no
experience with data flow languages, and I wonder how they are different
from functional languages? As far as I can tell, the language feature that
distinguishes SISAL as a data flow language is the loop syntax,
specifically the "for" expression.
Richard Urwin wrote: > Have you considered that OpenSCAD is to all external purposes a Data Flow > language that bears striking similarities to languages such as SISAL? (In > fact making OpenSCAD more like SISAL would be wonderful -- there's more > orthogonality and more powerful structures there, > I'm wondering what it would mean to "make OpenSCAD more like SISAL". Wikipedia describes SISAL as a "single assignment functional programming language with strict semantics", and that also describes OpenSCAD. We've had discussions in the past about making OpenSCAD more like a functional language. This would entail making functions, modules and geometric shapes into first class values. We could also add pattern matching, a module system (namespaces) and a record type. But you said Data Flow language, not functional language. I have no experience with data flow languages, and I wonder how they are different from functional languages? As far as I can tell, the language feature that distinguishes SISAL as a data flow language is the loop syntax, specifically the "for" expression.
RU
Richard Urwin
Tue, Oct 4, 2016 10:17 AM
I don't know anything about how OpenSCAD works internally, but it seems to me
that you need to generate a tree of objects to be created. A functional
programming language can be represented as such a tree and is therefore a
good fit to your needs. However you have other needs that are not well
represented by the functional model. For example is in not required that a
functional program is parallelizable but such would be of great use to
OpenSCAD with its extended execution time and the prelevence of
multiple-processor architectures. Language structures that OpenSCAD needs
such as the union and difference constructs with their code bodies bend the
functional paradigm. (They are special case lambda expressions but the user
cannot create such things.) OpenSCAD's dependence on recursion to support
certain programming needs creates a barrier to entry for newbies and an
optimization issue for developers. Other functional languages either provide
structures that bend the functional paradigm or put major effort into
optimization. Neither of which approaches solve both of the issues that
OpenSCAD has.
A Data Flow language represents its program as a directed graph of
operations. The nodes represent operations and the edges between nodes
represent variables.
http://forum.openscad.org/file/n18526/graph.png
The graph on the left represents the program:
A = 2;
B = 3;
C = 5;
D = 1.2;
cylinder(r=A+B, h=CD);
When a node has all the inputs it needs it is free to execute. So the values
2 and 3 flow to the "+" node which then executes and passes the "radius"
value to the "cylinder" node. Simultaneously, the "
" node receives its
inputs and also executes, passing the result to the "cylinder" node as its
"height" argument. The "cylinder" node now has all of its data and can
execute in its turn.
A data-flow program is inherently parallelizable on common-memory
multi-processor architectures; the graph can be partitioned easily. But to
maintain that flexibility it has precisely the same requirement that
OpenSCAD has that variables don't change etc.
The graph on the right is for the example in the OpenSCAD README:
cylinder(h = 30, r = 8);
translate([0, 0, 40]) sphere(20);
I imagine that this is identical to the tree that OpenSCAD produces for the
same code, maybe with more nodes and you may be more used to seeing it
upside-down. The Data Flow representation is precisely the same as the tree
form that OpenSCAD requires. Even if their execution dynamics are different,
their needs coincide. Which is why I said that "OpenSCAD is to all
external purposes a Data Flow language".
SISAL offers a richer programming environment than OpenSCAD. It has
aggregate data types and more powerful array handling in addition to its for
loops which provide an alternative to recursion in most cases. It is an old
language with an out-dated syntax however it has solved many of the issues
that OpenSCAD has still to address. An investigation into its source code
may benefit OpenSCAD. (There's a modern implementation on SourceForge.)
In addition, the redefinition of OpenSCAD as a data flow language could
clean up its syntax in other ways, such as the removal of unnecessary
parentheses on union, difference and for statements. Adopting SISAL's
approach of everything being an expression rather than everything being a
function would allow clearer syntax such as an if statement rather than the
?: trinary. The somewhat odd structures in OpenSCAD where a function
invocation (such as union) has a code body would make sense. Such changes
could easily be made backwards compatible.
In summary, a data-flow paradigm fits OpenSCAD's requirements better than a
functional model does and there are resources out there that would benefit
the OpenSCAD project.
View this message in context: http://forum.openscad.org/OpenSCAD-and-data-flow-languages-tp18521p18526.html
I don't know anything about how OpenSCAD works internally, but it seems to me that you need to generate a tree of objects to be created. A functional programming language can be represented as such a tree and is therefore a good fit to your needs. However you have other needs that are not well represented by the functional model. For example is in not required that a functional program is parallelizable but such would be of great use to OpenSCAD with its extended execution time and the prelevence of multiple-processor architectures. Language structures that OpenSCAD needs such as the union and difference constructs with their code bodies bend the functional paradigm. (They are special case lambda expressions but the user cannot create such things.) OpenSCAD's dependence on recursion to support certain programming needs creates a barrier to entry for newbies and an optimization issue for developers. Other functional languages either provide structures that bend the functional paradigm or put major effort into optimization. Neither of which approaches solve both of the issues that OpenSCAD has. A Data Flow language represents its program as a directed graph of operations. The nodes represent operations and the edges between nodes represent variables. <http://forum.openscad.org/file/n18526/graph.png> The graph on the left represents the program: A = 2; B = 3; C = 5; D = 1.2; cylinder(r=A+B, h=C*D); When a node has all the inputs it needs it is free to execute. So the values 2 and 3 flow to the "+" node which then executes and passes the "radius" value to the "cylinder" node. Simultaneously, the "*" node receives its inputs and also executes, passing the result to the "cylinder" node as its "height" argument. The "cylinder" node now has all of its data and can execute in its turn. A data-flow program is inherently parallelizable on common-memory multi-processor architectures; the graph can be partitioned easily. But to maintain that flexibility it has precisely the same requirement that OpenSCAD has that variables don't change etc. The graph on the right is for the example in the OpenSCAD README: union() { cylinder(h = 30, r = 8); translate([0, 0, 40]) sphere(20); } I imagine that this is identical to the tree that OpenSCAD produces for the same code, maybe with more nodes and you may be more used to seeing it upside-down. The Data Flow representation is precisely the same as the tree form that OpenSCAD requires. Even if their execution dynamics are different, their needs coincide. Which is why I said that "OpenSCAD is to all *external* purposes a Data Flow language". SISAL offers a richer programming environment than OpenSCAD. It has aggregate data types and more powerful array handling in addition to its for loops which provide an alternative to recursion in most cases. It is an old language with an out-dated syntax however it has solved many of the issues that OpenSCAD has still to address. An investigation into its source code may benefit OpenSCAD. (There's a modern implementation on SourceForge.) In addition, the redefinition of OpenSCAD as a data flow language could clean up its syntax in other ways, such as the removal of unnecessary parentheses on union, difference and for statements. Adopting SISAL's approach of everything being an expression rather than everything being a function would allow clearer syntax such as an if statement rather than the ?: trinary. The somewhat odd structures in OpenSCAD where a function invocation (such as union) has a code body would make sense. Such changes could easily be made backwards compatible. In summary, a data-flow paradigm fits OpenSCAD's requirements better than a functional model does and there are resources out there that would benefit the OpenSCAD project. -- View this message in context: http://forum.openscad.org/OpenSCAD-and-data-flow-languages-tp18521p18526.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Oct 4, 2016 9:50 PM
Thanks for the detailed response, Richard. Some good ideas to think about.
On 4 October 2016 at 06:17, Richard Urwin soronlin+openscad@googlemail.com
me
provide
OpenSCAD has.
A = 2;
B = 3;
C = 5;
D = 1.2;
values
" node receives its
different,
for
Thanks for the detailed response, Richard. Some good ideas to think about. On 4 October 2016 at 06:17, Richard Urwin <soronlin+openscad@googlemail.com> wrote: > I don't know anything about how OpenSCAD works internally, but it seems to > me > that you need to generate a tree of objects to be created. A functional > programming language can be represented as such a tree and is therefore a > good fit to your needs. However you have other needs that are not well > represented by the functional model. For example is in not required that a > functional program is parallelizable but such would be of great use to > OpenSCAD with its extended execution time and the prelevence of > multiple-processor architectures. Language structures that OpenSCAD needs > such as the union and difference constructs with their code bodies bend the > functional paradigm. (They are special case lambda expressions but the user > cannot create such things.) OpenSCAD's dependence on recursion to support > certain programming needs creates a barrier to entry for newbies and an > optimization issue for developers. Other functional languages either > provide > structures that bend the functional paradigm or put major effort into > optimization. Neither of which approaches solve both of the issues that > OpenSCAD has. > > A Data Flow language represents its program as a directed graph of > operations. The nodes represent operations and the edges between nodes > represent variables. > <http://forum.openscad.org/file/n18526/graph.png> > The graph on the left represents the program: > A = 2; > B = 3; > C = 5; > D = 1.2; > cylinder(r=A+B, h=C*D); > When a node has all the inputs it needs it is free to execute. So the > values > 2 and 3 flow to the "+" node which then executes and passes the "radius" > value to the "cylinder" node. Simultaneously, the "*" node receives its > inputs and also executes, passing the result to the "cylinder" node as its > "height" argument. The "cylinder" node now has all of its data and can > execute in its turn. > > A data-flow program is inherently parallelizable on common-memory > multi-processor architectures; the graph can be partitioned easily. But to > maintain that flexibility it has precisely the same requirement that > OpenSCAD has that variables don't change etc. > > The graph on the right is for the example in the OpenSCAD README: > union() { > cylinder(h = 30, r = 8); > translate([0, 0, 40]) sphere(20); > } > I imagine that this is identical to the tree that OpenSCAD produces for the > same code, maybe with more nodes and you may be more used to seeing it > upside-down. The Data Flow representation is precisely the same as the tree > form that OpenSCAD requires. Even if their execution dynamics are > different, > their needs coincide. Which is why I said that "OpenSCAD is to all > *external* purposes a Data Flow language". > > SISAL offers a richer programming environment than OpenSCAD. It has > aggregate data types and more powerful array handling in addition to its > for > loops which provide an alternative to recursion in most cases. It is an old > language with an out-dated syntax however it has solved many of the issues > that OpenSCAD has still to address. An investigation into its source code > may benefit OpenSCAD. (There's a modern implementation on SourceForge.) > > In addition, the redefinition of OpenSCAD as a data flow language could > clean up its syntax in other ways, such as the removal of unnecessary > parentheses on union, difference and for statements. Adopting SISAL's > approach of everything being an expression rather than everything being a > function would allow clearer syntax such as an if statement rather than the > ?: trinary. The somewhat odd structures in OpenSCAD where a function > invocation (such as union) has a code body would make sense. Such changes > could easily be made backwards compatible. > > In summary, a data-flow paradigm fits OpenSCAD's requirements better than a > functional model does and there are resources out there that would benefit > the OpenSCAD project. > > > > > -- > View this message in context: http://forum.openscad.org/ > OpenSCAD-and-data-flow-languages-tp18521p18526.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > >
RU
Richard Urwin
Tue, Oct 25, 2016 12:31 PM
Rather than tie up the Plogon thread any more, I'll drop this here.
I was considering for loops and functional language last night.
Consider:
What about adding some more parameter passing like this:
Then we need a little more syntax:
for x in list
initially
y = 0
y = old y + 1
"y" refers to the parameter that is to be handed off to the next recursion
and "old y" refers to the parameter that was passed to this recursion.
View this message in context: http://forum.openscad.org/OpenSCAD-and-data-flow-languages-tp18521p18797.html
Rather than tie up the Plogon thread any more, I'll drop this here. I was considering for loops and functional language last night. Consider: What about adding some more parameter passing like this: Then we need a little more syntax: for x in list initially { y = 0 } { y = old y + 1 ... } "y" refers to the parameter that is to be handed off to the next recursion and "old y" refers to the parameter that was passed to this recursion. -- View this message in context: http://forum.openscad.org/OpenSCAD-and-data-flow-languages-tp18521p18797.html Sent from the OpenSCAD mailing list archive at Nabble.com.
RU
Richard Urwin
Tue, Oct 25, 2016 1:05 PM
(mailing list still doesn't like raw text.)
Rather than tie up the Polygon thread any more, I'll drop this here.
Consider:
for x in list
body
That can be seen as an anonymous function something like:
function anon(list)
if len(list) > 0 then
x = head(list)
body
anon(tail(list));
anon(list);
function anon(list, local definitions)
x = head(list)
body
anon(tail(list), local definitions);
anon(list, initial definitions);
for x in list
initially
y = 0
y = old y + 1
So that would convert to:
function anon(list, old_y)
x = head(list)
y = old_y + 1
anon(tail(list), y);
anon (list, 0);
View this message in context: http://forum.openscad.org/OpenSCAD-and-data-flow-languages-tp18521p18798.html
(mailing list still doesn't like raw text.) Rather than tie up the Polygon thread any more, I'll drop this here. I was considering for loops and functional language last night. Consider: for x in list body That can be seen as an anonymous function something like: function anon(list) { if len(list) > 0 then { x = head(list) body anon(tail(list)); } } anon(list); What about adding some more parameter passing like this: function anon(list, local definitions) { if len(list) > 0 then { x = head(list) body anon(tail(list), local definitions); } } anon(list, initial definitions); Then we need a little more syntax: for x in list initially { y = 0 } { y = old y + 1 ... } "y" refers to the parameter that is to be handed off to the next recursion and "old y" refers to the parameter that was passed to this recursion. So that would convert to: function anon(list, old_y) { if len(list) > 0 then { x = head(list) y = old_y + 1 ... anon(tail(list), y); } } anon (list, 0); -- View this message in context: http://forum.openscad.org/OpenSCAD-and-data-flow-languages-tp18521p18798.html Sent from the OpenSCAD mailing list archive at Nabble.com.
