mkatychev@pm.me
Wed, Jan 22, 2025 10:37 PM
Hi everyone,
I've been working on my own formatter for OpenSCAD after feeling there was a lack of good formatters out there that meshed well with [openscad-LSP](https://github.com/Leathong/openscad-LSP/pull/33 "openscad-LSP
(https://github.com/Leathong/openscad-LSP/pull/33)"). I’ve since implemented my own OpenSCAD formatter using [Topiary](https://topiary.tweag.io/ "Topiary
(https://topiary.tweag.io/)").
Topiary is a language agnostic formatter that uses ASTs generated by [tree-sitter](https://tree-sitter.github.io/tree-sitter/ "tree-sitter
(https://tree-sitter.github.io/tree-sitter/)") combined with [lisp-like s-expressions](https://tree-sitter.github.io/tree-sitter/using-parsers/queries/1-syntax.html "lisp-like s-expressions
(https://tree-sitter.github.io/tree-sitter/using-parsers/queries/1-syntax.html)") that determine the formatting output: https://github.com/tweag/topiary/pull/845 Check it out and let me know what you think. You'll need to install cargo/rustup to get the rust toolchain (for now), please submit any issues/inconsistencies with formatting [here](https://github.com/mkatychev/topiary/issues "here
(https://github.com/mkatychev/topiary/issues)"):
Setup
Install the rust toolchain, this set you up with rustup, cargo and rustc: https://www.rust-lang.org/learn/get-started
Installation
cargo install --git https://github.com/mkatychev/topiary topiary-cli --no-default-features --features=openscad
Format
topiary format path/to/my_openscad_file.scad
Notes
You can see the [before](https://github.com/tweag/topiary/blob/7afe496065b18c12dff8631e8e6a5e94979e19f4/topiary-cli/tests/samples/input/openscad.scad "before
(https://github.com/tweag/topiary/blob/7afe496065b18c12dff8631e8e6a5e94979e19f4/topiary-cli/tests/samples/input/openscad.scad)") and [after](https://github.com/tweag/topiary/blob/7afe496065b18c12dff8631e8e6a5e94979e19f4/topiary-cli/tests/samples/expected/openscad.scad "after
(https://github.com/tweag/topiary/blob/7afe496065b18c12dff8631e8e6a5e94979e19f4/topiary-cli/tests/samples/expected/openscad.scad)") inside the pull request linked above to see the stylistic choices and and edge cases covered. Keep in mind that topiary is in active development so there are some features that are still not covered/implemented such as:
Hi everyone, \
(https://topiary.tweag.io/)"). \
(https://tree-sitter.github.io/tree-sitter/using-parsers/queries/1-syntax.html)") that determine the formatting output: [https://github.com/tweag/topiary/pull/845](https://github.com/tweag/topiary/pull/845 "https://github.com/tweag/topiary/pull/845") Check it out and let me know what you think. You'll need to install `cargo`/`rustup` to get the rust toolchain (for now), please submit any issues/inconsistencies with formatting [here](https://github.com/mkatychev/topiary/issues "here
## **Setup**
Install the rust toolchain, this set you up with `rustup`, `cargo` and `rustc`: [https://www.rust-lang.org/learn/get-started](https://www.rust-lang.org/learn/get-started "https://www.rust-lang.org/learn/get-started")
## **Installation**
## **Format**
## **Notes**
* alternate configurations (ex: curly braces on separate line)
* alignment of fields
* alignment of list elements
TS
Tim Schmidt
Thu, Jan 23, 2025 4:44 AM
This is really cool!
I've recently been working on a little rusty CAD kernel (
https://crates.io/crates/csgrs) that works well with the
https://www.dimforge.com/ libraries for physical simulation.
I've started a little OpenSCAD -> AST -> csgrs parser as well, using the
OpenSCAD tree-sitter grammar, but it is much less functional than csgrs at
the moment: https://github.com/timschmidt/openscad_to_csgrs
Awesome to see some similar work!
On Wed, Jan 22, 2025 at 9:54 PM mkatychev--- via Discuss <
> Hi everyone,
> a lack of good formatters out there that meshed well with openscad-LSP
> <https://github.com/Leathong/openscad-LSP/pull/33>. I’ve since
> implemented my own OpenSCAD formatter using Topiary
> <https://topiary.tweag.io/>.
> tree-sitter <https://tree-sitter.github.io/tree-sitter/> combined with lisp-like
> s-expressions
> <https://tree-sitter.github.io/tree-sitter/using-parsers/queries/1-syntax.html>
> formatting here <https://github.com/mkatychev/topiary/issues>:
> *Setup*
> *Installation*
> *Format*
> *Notes*
> You can see the before
> <https://github.com/tweag/topiary/blob/7afe496065b18c12dff8631e8e6a5e94979e19f4/topiary-cli/tests/samples/input/openscad.scad>
> and after
> <https://github.com/tweag/topiary/blob/7afe496065b18c12dff8631e8e6a5e94979e19f4/topiary-cli/tests/samples/expected/openscad.scad>
> alignment of fields
Timothy Schmidt
(517) 292-4030
timschmidt@gmail.com
https://wiki.replimat.org
mkatychev
Thu, Jan 23, 2025 5:03 AM
That's also very interesting, Tim! fornjot is another b-rep CAD Kernel I've been following, it could provide some inspiration.
As for the lack of functionality, check out my fork of tree-sitter-openscad:
https://github.com/mkatychev/tree-sitter-openscad/blob/master/CHANGELOG.md#version-060
My fork covers many more cases than the main repo, I used it to build the aforementioned formatter and tested many popular libraries such as BOSL2 and relativity.scad to ensure it can parse/tokenize the most common grammar variations.
tree-sitter parser/Combinator is a largely inert AST generator (tokens hold minimal/no metadata ) so it may still not fit your use-case even if it handles many more edge cases than the main repo.
Mikhail
-------- Original Message --------
On 2025-01-22 22:44, Tim Schmidt wrote:
Hi everyone,
I've been working on my own formatter for OpenSCAD after feeling there was a lack of good formatters out there that meshed well with openscad-LSP. I’ve since implemented my own OpenSCAD formatter using Topiary.
Topiary is a language agnostic formatter that uses ASTs generated by tree-sitter combined with lisp-like s-expressions that determine the formatting output: https://github.com/tweag/topiary/pull/845 Check it out and let me know what you think. You'll need to install cargo/rustup to get the rust toolchain (for now), please submit any issues/inconsistencies with formatting here:
Setup
Installation
cargo install --git
Format
Notes
You can see the before and after inside the pull request linked above to see the stylistic choices and and edge cases covered. Keep in mind that topiary is in active development so there are some features that are still not covered/implemented such as:
alignment of fields
Mikhail
> I've recently been working on a little rusty CAD kernel (https://crates.io/crates/csgrs) that works well with the https://www.dimforge.com/ libraries for physical simulation.
> I've started a little OpenSCAD -> AST -> csgrs parser as well, using the OpenSCAD tree-sitter grammar, but it is much less functional than csgrs at the moment: https://github.com/timschmidt/openscad_to_csgrs
> On Wed, Jan 22, 2025 at 9:54 PM mkatychev--- via Discuss <discuss@lists.openscad.org> wrote:
>> Hi everyone,
>> I've been working on my own formatter for OpenSCAD after feeling there was a lack of good formatters out there that meshed well with [openscad-LSP](https://github.com/Leathong/openscad-LSP/pull/33). I’ve since implemented my own OpenSCAD formatter using [Topiary](https://topiary.tweag.io/).
>> Topiary is a language agnostic formatter that uses ASTs generated by [tree-sitter](https://tree-sitter.github.io/tree-sitter/) combined with [lisp-like s-expressions](https://tree-sitter.github.io/tree-sitter/using-parsers/queries/1-syntax.html) that determine the formatting output: https://github.com/tweag/topiary/pull/845 Check it out and let me know what you think. You'll need to install cargo/rustup to get the rust toolchain (for now), please submit any issues/inconsistencies with formatting [here](https://github.com/mkatychev/topiary/issues):
>> Setup
>> Installation
>> cargo install --git
>> Format
>> Notes
>> You can see the [before](https://github.com/tweag/topiary/blob/7afe496065b18c12dff8631e8e6a5e94979e19f4/topiary-cli/tests/samples/input/openscad.scad) and [after](https://github.com/tweag/topiary/blob/7afe496065b18c12dff8631e8e6a5e94979e19f4/topiary-cli/tests/samples/expected/openscad.scad) inside the pull request linked above to see the stylistic choices and and edge cases covered. Keep in mind that topiary is in active development so there are some features that are still not covered/implemented such as:
>> alignment of fields
> Timothy Schmidt
> (517) 292-4030
TS
Tim Schmidt
Thu, Jan 23, 2025 5:26 AM
Thanks for the pointer! I'll add it to the todo and definitely put it to
use!
I'm aware of fornjot and truck, but just wanted something fast and simple
built around polygons and lines. Cavalier contours, which I am using for
2d offsetting, does have some curve support which is currently going unused
in csgrs. The binary space partitioning trees at the heart of csgrs
probably don't lend themselves well to curves anyway. But it is good
enough for polygons, and very small and fast and relatively simple.
I recently landed per-csg object and per-polygon generic metadata storage,
which should enable color, material type, texture graphics, physical
simulation data, even game engine object handles to be stored alongside the
appropriate polygons in the BSP datastructure. Should enable CAD for
multi-material printing, and generative designs evolved from physical
constraints among other things.
variations.
Mikhail
use!
> variations.
> Mikhail
>> Hi everyone,
>> openscad-LSP <https://github.com/Leathong/openscad-LSP/pull/33>. I’ve
>> s-expressions
>> *Setup*
>> *Installation*
>> *Format*
>> *Notes*
>> and after
>> alignment of fields
> Timothy Schmidt
> (517) 292-4030
Timothy Schmidt
(517) 292-4030
TS
Tim Schmidt
Thu, Jan 23, 2025 5:56 AM
Also, Dimforge just deals in triangle meshes, basic shapes, and voxels. So
my focus has been on supporting CSG on those to facilitate easy interaction
with the API.
use!
variations.
Mikhail
with the API.
> use!
>> variations.
>> Mikhail
>>> Hi everyone,
>>> s-expressions
>>> *Setup*
>>> *Installation*
>>> *Format*
>>> *Notes*
>>> and after
>>> alignment of fields
>> Timothy Schmidt
>> (517) 292-4030
> Timothy Schmidt
> (517) 292-4030
Timothy Schmidt
(517) 292-4030
GS
Guenther Sohler
Thu, Jan 23, 2025 10:18 AM
Instead of parsing AST it's way easier just to output the AST in a
different format.
Maybe we could develop versatile modules to output the AST in other
languages next to OpenSCAD
On Thu, Jan 23, 2025 at 5:45 AM Tim Schmidt via Discuss <
different format.
>> Hi everyone,
>> s-expressions
>> *Setup*
>> *Installation*
>> *Format*
>> *Notes*
>> and after
>> alignment of fields
> Timothy Schmidt
> (517) 292-4030
