I am fooling around with creating my own spheres from a points array, so I
took a look at the performance of sphere() with "show edges" turned on. I
noticed that it doesn't show edges for the top and bottom of the sphere...
so then I took a look at the output of cylinder() and cube() modules.
However if you create the same object with linear_extrude() using either
circle() or square() as the primitive, the display in F5 shows all the
triangles of the mesh.
This inconsistency isn't really a big thing to me, but it doesn't give me
much insight into how a sphere is formed... specifically how is the diameter
for the top and bottom of the sphere determined? I had thought that a sphere
might be topped and bottomed by a cone construction, but that doesn't seem
to be the case.
If you superimpose a cube over a sphere of the same size, you can also see
that there is inaccuracy at the top and bottom of the sphere which only
becomes more pronounced if you scale a sphere (i.e. construct spheres at the
size you ultimately require, don't scale).
So I'm thinking that the sphere generator I create should go for the cone
top and bottom so that the tip of the cone lies exactly on the measurement
specified, or do you folks think that's being overly picky? If I don't go
for the cone, then where should the truncation of the height dimension fall?
Just wanted the thoughts of the community on this.
Here's some code that displays the behaviour I've been talking about (just
remember to turn on "show edges")
$fn = 30;
cylinder(r = 5, h = 5);
translate([15,0,0])
linear_extrude(5)
circle(5);
translate([0,15,0]) {
cube([10,10,10], center = true);
translate([15,0,0])
linear_extrude(10)
square([10,10], center = true);
translate([35,10,0]) {
sphere(10);
#cube([20,20,20], center = true);
You can look at:
https://github.com/thehans/FunctionalOpenSCAD/blob/master/functional.scad
For a sphere construction. It matches up pretty well to the one in
OpenSCAD.
There are some drawbacks to that approach - the same project has some
alternative sphere constructions.
You can look at:
OpenSCAD.
The same project has some alternative sphere constructions.
Isn't it simpler to simply add more polygons to the sphere?
sphere(100,$fn=10); //Looks like crap
translate([240,0,0])
sphere(100,$fn=50); //Looks pretty good
translate([480,0,0])
sphere(100,$fn=500); //Looks smooth
OpenSCAD internally generates polyhedrons for those primitives and obviously
uses the rule that each vertex v satisfies the respective equation. Thus all
other points on the 2-manifold don't.
You can see this by
circle(5, $fn=4);
#square(10, center = true);
From an approximation error point of view this might not be the best
solution, but it is how it is.
There's this: https://www.thingiverse.com/thing:1484333
obviously
all
You can see this by
circle(5, $fn=4);
Gary A. Crowell Sr., P.E. http://www.ipels.idaho.gov/, CID+
http://dc.ipc.org/html/default.htm
Linkedin http://www.linkedin.com/in/garyacrowellsr Elance
http://www.linkedin.com/redirect?url=http%3A%2F%2Fgaryacrowellsr%2Eelance%2Ecom&urlhash=kJm9
KE7FIZ http://www.arrl.org Things
http://www.thingiverse.com/garyacrowellsr/designs RocketryCNC
https://www.etsy.com/shop/RocketryCNC?ref=l2-shopheader-name
The sphere polyhedral model in OpenSCAD is based on a subdivision by
meridians and parallels. The number of adjacencies of a vertex in that
subdivision (in quads) is four except for the top vertex of the cones at
the top and bottom of the polyhedron. For high values of $fn, two vertices
have high number of adjacencies, the adjacent triangles are narrow and with
about the same normal. This may cause inaccuracies and issues on boolean
operations. Other sphere subdivisions, like the geodesic one, would be
preferable: they have low number of adjacencies, a few "fat" triangle
shapes and a better vertex distribution on the sphere surface. However,
some people argue that this should be done in user space.
It tends to be important that spheres have vertices spot on the six 90
degree points so that when you hull them to make rounded cubes they have
the correct dimensions.
On 20 February 2018 at 16:41, Ronaldo Persiano rcmpersiano@gmail.com
Ideally they also have seams that correspond to octahedron edges. Then you
can use the octahedron/cube duality for the edges of the rounded cube as
well.
Hey, thanks to all of you for your input on this… clearly nothing is simple… I guess life would be a lot easier if we lived in flatland.
I hadn’t thought of the value of hulling spheres so I can see how a ‘proper’ sphere with cone caps would make that problematic.
I was hoping to craft a sphere module that could be used with more versatility, but it’s obvious that objects need to be crafted with more specificity for the context.
On Feb 20, 2018, at 11:48 AM, nop head nop.head@gmail.com wrote:
It tends to be important that spheres have vertices spot on the six 90 degree points so that when you hull them to make rounded cubes they have the correct dimensions.
On 20 February 2018 at 16:41, Ronaldo Persiano <rcmpersiano@gmail.com mailto:rcmpersiano@gmail.com> wrote:
The sphere polyhedral model in OpenSCAD is based on a subdivision by meridians and parallels. The number of adjacencies of a vertex in that subdivision (in quads) is four except for the top vertex of the cones at the top and bottom of the polyhedron. For high values of $fn, two vertices have high number of adjacencies, the adjacent triangles are narrow and with about the same normal. This may cause inaccuracies and issues on boolean operations. Other sphere subdivisions, like the geodesic one, would be preferable: they have low number of adjacencies, a few "fat" triangle shapes and a better vertex distribution on the sphere surface. However, some people argue that this should be done in user space.
