Re: [OpenSCAD] text on stars
Fri, Jun 17, 2016 1:47 AM
Lucy wrote
Hi there! Quick openscad question: When placing text on a solid, how can
you control the location? This code works for a different solid but not
this one. Any suggestions are helpful. Here's what I've got:
// LetterBlock.scad - Basic usage of text() and linear_extrude()
// Module instantiation
LetterBlock("proxima centauri");
// Module definition.
// size=30 defines an optional parameter with a default value.
module LetterBlock(letter, size=1000) {
hull(){ translate([95.0,-163.904109589,151.164383562])cube(0.1,0.1,0.1);
translate([74.4927536232,-15.5072463768,158.043478261])cube(0.1,0.1,0.1);
translate([95.0,5.0,35.0])cube(0.1,0.1,0.1);
translate([95.0,-25.4301075269,171.935483871])cube(0.1,0.1,0.1);
translate([68.0,-22.0,-149.6])cube(0.1,0.1,0.1);
translate([95.0,5.0,-137.0])cube(0.1,0.1,0.1);
translate([39.2764397906,-161.705759162,-188.248167539])cube(0.1,0.1,0.1);
translate([95.0,-247.647058824,-158.235294118])cube(0.1,0.1,0.1);
translate([59.9502982107,-110.546719682,-180.188866799])cube(0.1,0.1,0.1);
translate([95.0,-77.6,-164.533333333])cube(0.1,0.1,0.1);
translate([95.0,-254.594594595,-151.891891892])cube(0.1,0.1,0.1);
translate([95.0,-270.688622754,121.706586826])cube(0.1,0.1,0.1);
translate([63.2793546108,-274.709103757,110.753150395])cube(0.1,0.1,0.1);
translate([-4.26742331864,-281.601632117,59.0591876935])cube(0.1,0.1,0.1);
translate([10.2365415987,-272.349102773,-61.9738988581])cube(0.1,0.1,0.1);
translate([-53.1773399015,-143.177339901,43.1403940887])cube(0.1,0.1,0.1);
translate([-34.5580110497,-124.55801105,-129.08839779])cube(0.1,0.1,0.1);
translate([-23.0774962742,-148.90461997,-145.715350224])cube(0.1,0.1,0.1);
}      translate([-80,40,0])
// convexity is needed for correct preview
// since characters can be highly concave
linear_extrude(height=size, convexity=4)
text(letter,
size=size*3/30,
font="Bitstream Vera Sans",
halign="center",
valign="center");
Hi Lucy, welcome to the forum.
Firstly, your post is still flagged as "This post has NOT been accepted by
the mailing list yet", so nobody gets it unless they look.
You need to subscribe to the  mailing list
http://forum.openscad.org/mailing_list/MailingListOptions.jtp?forum=1  ,
Re positioning text, you use either rotate() and/or translate() to position
the text.
In your code you don't see the text because it is beside the solid. Add a
'#' at the front of the linear_extrude, ie #linear_extrude(height=size,
convexity=4), and you will see the text. It is way to big ATM.
So you need
translate([n,n,n])
rotate([a,a,a])
#linear_extrude(...)
Play with the numbers to move it around.
View this message in context: http://forum.openscad.org/text-on-stars-tp17722p17727.html
Lucy wrote > Hi there! Quick openscad question: When placing text on a solid, how can > you control the location? This code works for a different solid but not > this one. Any suggestions are helpful. Here's what I've got: > > // LetterBlock.scad - Basic usage of text() and linear_extrude() > > // Module instantiation > LetterBlock("proxima centauri"); > > // Module definition. > // size=30 defines an optional parameter with a default value. > module LetterBlock(letter, size=1000) { > difference() { > hull(){ translate([95.0,-163.904109589,151.164383562])cube(0.1,0.1,0.1); > translate([74.4927536232,-15.5072463768,158.043478261])cube(0.1,0.1,0.1); > translate([95.0,5.0,35.0])cube(0.1,0.1,0.1); > translate([95.0,-25.4301075269,171.935483871])cube(0.1,0.1,0.1); > translate([68.0,-22.0,-149.6])cube(0.1,0.1,0.1); > translate([95.0,5.0,-137.0])cube(0.1,0.1,0.1); > translate([39.2764397906,-161.705759162,-188.248167539])cube(0.1,0.1,0.1); > translate([95.0,-247.647058824,-158.235294118])cube(0.1,0.1,0.1); > translate([59.9502982107,-110.546719682,-180.188866799])cube(0.1,0.1,0.1); > translate([95.0,-77.6,-164.533333333])cube(0.1,0.1,0.1); > translate([95.0,-254.594594595,-151.891891892])cube(0.1,0.1,0.1); > translate([95.0,-270.688622754,121.706586826])cube(0.1,0.1,0.1); > translate([63.2793546108,-274.709103757,110.753150395])cube(0.1,0.1,0.1); > translate([-4.26742331864,-281.601632117,59.0591876935])cube(0.1,0.1,0.1); > translate([10.2365415987,-272.349102773,-61.9738988581])cube(0.1,0.1,0.1); > translate([-53.1773399015,-143.177339901,43.1403940887])cube(0.1,0.1,0.1); > translate([-34.5580110497,-124.55801105,-129.08839779])cube(0.1,0.1,0.1); > translate([-23.0774962742,-148.90461997,-145.715350224])cube(0.1,0.1,0.1); > } translate([-80,40,0]) > > { > // convexity is needed for correct preview > // since characters can be highly concave > linear_extrude(height=size, convexity=4) > text(letter, > size=size*3/30, > font="Bitstream Vera Sans", > halign="center", > valign="center"); > } > } > } Hi Lucy, welcome to the forum. Firstly, your post is still flagged as "This post has NOT been accepted by the mailing list yet", so nobody gets it unless they look. You need to subscribe to the mailing list <http://forum.openscad.org/mailing_list/MailingListOptions.jtp?forum=1> , and respond to the registration email. Re positioning text, you use either rotate() and/or translate() to position the text. In your code you don't see the text because it is beside the solid. Add a '#' at the front of the linear_extrude, ie #linear_extrude(height=size, convexity=4), and you will see the text. It is way to big ATM. So you need translate([n,n,n]) rotate([a,a,a]) #linear_extrude(...) ... Play with the numbers to move it around. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/text-on-stars-tp17722p17727.html Sent from the OpenSCAD mailing list archive at Nabble.com.
