Ovals
ER
Ezra Reynolds
Wed, Sep 5, 2018 3:56 PM
In the past I have used TinkerCAD to help with problematic models that don't open in OpenScad.  Open the model in tinkercad, make a tiny change (union with a small sphere) then export as a new STL.  Some of the files are produced this way I have been more palatable to openscad.
On Sep 5, 2018, at 11:47 AM, nop head nop.head@gmail.com wrote:
But a render, which you would think uses the same process fails.
No preview is a totally different process to render. Preview just draws all the triangles in the correct order to show a pixel representation of the object. render calculates the geometry if there are any CSG ops (including the implict union) and then draws that. It uses the GCAL library and that expects it to be 2-manifold, without degenerate triangles.
The grid is defined here: https://github.com/openscad/openscad/blob/c6a485651fa29f1a878ea454558192492f7467ec/src/grid.h#L14
I have never had much success with other people's STLs for 3D printing. Even if they are manifold they are often not correct for 3D printing on my machines. I mostly design everything I print from scratch in OpenSCAD.
On 5 September 2018 at 16:28, FourthDr who_doctor@hotmail.com wrote:
NopHead:
You've mentioned OpenSCAD's grid a few times before. But is that actually
documented anywhere? For example, if the designer of a model was made aware
that any export to stl needed to have triangles of a specific maximum size
there would be one less problem to deal with.
That is exactly what's needed, guide lines. Any shared stl should have the
following traits. Right now you have no idea what program the stl was
originally exported from or what settings where used.
If some one could document exact minimum traits an stl file needs to be
successfully imported, manipulated, and then exported from OpenSCAD that
would be very helpful.
In the past I have used TinkerCAD to help with problematic models that don't open in OpenScad. Open the model in tinkercad, make a tiny change (union with a small sphere) then export as a new STL. Some of the files are produced this way I have been more palatable to openscad. > On Sep 5, 2018, at 11:47 AM, nop head <nop.head@gmail.com> wrote: > > >But a render, which you would think uses the same process fails. > > No preview is a totally different process to render. Preview just draws all the triangles in the correct order to show a pixel representation of the object. render calculates the geometry if there are any CSG ops (including the implict union) and then draws that. It uses the GCAL library and that expects it to be 2-manifold, without degenerate triangles. > > The grid is defined here: https://github.com/openscad/openscad/blob/c6a485651fa29f1a878ea454558192492f7467ec/src/grid.h#L14 > > I have never had much success with other people's STLs for 3D printing. Even if they are manifold they are often not correct for 3D printing on my machines. I mostly design everything I print from scratch in OpenSCAD. > >> On 5 September 2018 at 16:28, FourthDr <who_doctor@hotmail.com> wrote: >> NopHead: >> >> You've mentioned OpenSCAD's grid a few times before. But is that actually >> documented anywhere? For example, if the designer of a model was made aware >> that any export to stl needed to have triangles of a specific maximum size >> there would be one less problem to deal with. >> >> That is exactly what's needed, guide lines. Any shared stl should have the >> following traits. Right now you have no idea what program the stl was >> originally exported from or what settings where used. >> >> If some one could document exact minimum traits an stl file needs to be >> successfully imported, manipulated, and then exported from OpenSCAD that >> would be very helpful. >> >> >> >> -- >> Sent from: http://forum.openscad.org/ >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
CA
Wed, Sep 5, 2018 6:55 PM
Le mer. 5 sept. 2018 à 03:03, FourthDr who_doctor@hotmail.com a écrit :
I'm trying to get these two attached stl files split by tomorrow. I've been
tinkering with them for months. So far without success. Any one interested
in seeing if they can find and correct the two files for me? And maybe give
some tips and or suggest some software tools I have not already tried?
Cryptic CGAL errors don't really help me find and fix what OpenSCAD is
complaining about.
back-cover-no-stand-2.stl
http://forum.openscad.org/file/t1425/back-cover-no-stand-2.stl
LCD_face_plate_LCD_hole_open(repaired).stl
http://forum.openscad.org/file/t1425/_LCD_face_plate_LCD_hole_open_%28repaired%29.stl
puzzlecutlib3.scad http://forum.openscad.org/file/t1425/puzzlecutlib3.scad
Thanks for all the help.
For the fun of it, I checked your files in my own tool. The first one
(back-cover-no-stand-2.stl) reports no problems.
The second "repaired" _LCD_face_plate... reports numerous problems and a
fix is attempted (seems better although not 100% clean)
Here is a link to the fixed file (link will expire in 2 days). I don't
know if it works any better than what you had, but you can try.
https://www.expirebox.com/download/050b8ca1679fcea5bfa17ea49aa6fc21.html
What is reported is for example
  • many collapsed/zero area faces
  • many duplicated faces
  • many non-manifold faces
It should be said that STL contains zero topology, so any claim of
non-manifoldness is a subjective interpretation of the data. For
exchanging between applications if would have been better to use a
format with explicit topology e.g. Wavefront OBJ. But STL is indeed very
common with all its issues.
Below is the log from my tool showing iterative attempts to fix your
file. The approach taken when interpreting the STL is quite different
from OpenSCADs "grid" approach so the result is likely not going to be
the same, but perhaps OpenSCAD likes the result better.
In iteration 0, the STL "polygon soup" is read. The high number of
initial non-manifold edges is normal for STL since it is a polygon soup
with no connectivity at all. From iteration 1, connectivity is
interpreted by merging vertices (with distance < dtol), and thus the
number of non-manifold edges is much reduced.
The vertex merging process leaves some zero area faces (with area <
atol) that are subsequently removed. Also, duplicate faces are removed.
After 6 iterations the only remaining issues are a few non-manifold
edges remain which cannot easily be resolved.
However, the resulting file is likely more usable in other programs,
maybe also in OpenSCAD. I could not test it in OpenSCAD since I am on
Kubuntu 18.04 and apparently there is no usable binary for 18.04.
Parameters:
input_file = LCD_face_plate_LCD_hole_open(repaired).stl
polyhedron 0 ================= volume=35242.9, dtol=0.01, atol=1e-06,
maxiter=10
iteration 0: vertices=43758 faces=14586
warning: 1 zero area faces.
warning: nonmanifold edges: uc(1)=43758
merged 38113 vertices
removed 2612 collapsed or zero area faces
split 32 faces
removed 366 duplicate faces
removed 161 nonmanifold faces
removed 29 zero area faces
total changes=41313
warning: nonmanifold edges: uc(1)=61 uc(3)=71 uc(4)=57
uc(5)=1
iteration 1: vertices=5645 faces=11515
uc(5)=1
          removed 6 unused vertices
          merged 434 vertices
          removed 790 collapsed or zero area faces
          split 8 faces
          removed 145 duplicate faces
          removed 71 nonmanifold faces
          removed 8 zero area faces
          total changes=1462
          warning: nonmanifold edges: uc(1)=26 uc(3)=27 uc(4)=37
uc(6)=1 uc(7)=1
iteration 2: vertices=5205 faces=10514
uc(6)=1 uc(7)=1
removed 5 unused vertices
merged 114 vertices
removed 227 collapsed or zero area faces
split 2 faces
removed 42 duplicate faces
removed 30 nonmanifold faces
removed 4 zero area faces
total changes=424
warning: nonmanifold edges: uc(1)=9 uc(3)=6 uc(4)=19
iteration 3: vertices=5086 faces=10213
removed 4 unused vertices
merged 19 vertices
removed 40 collapsed or zero area faces
split 6 faces
removed 5 duplicate faces
removed 2 nonmanifold faces
removed 6 zero area faces
total changes=82
warning: nonmanifold edges: uc(1)=4 uc(3)=12 uc(4)=15
iteration 4: vertices=5063 faces=10172
removed 1 unused vertex
split 2 faces
removed 1 duplicate face
total changes=10
warning: nonmanifold edges: uc(1)=1 uc(3)=7 uc(4)=15
iteration 5: vertices=5062 faces=10168
total changes=1
iteration 6: vertices=5061 faces=10168
total changes=0
Summary:
polyhedron 0: vertices=5061 faces=10168 : warning:
Writing: LCD_face_plate_LCD_hole_open(repaired)_polyfix.stl
... abm_polyfix finished, time used: 0d 00h 00m 01s
When you have as many issues as in this example, you cannot expect
import + booleans will work very well, if at all. Even my attempted fix
may still be problematic, but you can try.
It could be that the "repaired" version you provided has more problems
than the original. With such issues it isn't a surprise that using it in
OpenSCAD was a problem.
> Le mer. 5 sept. 2018 à 03:03, FourthDr <who_doctor@hotmail.com> a écrit : >> I'm trying to get these two attached stl files split by tomorrow. I've been >> tinkering with them for months. So far without success. Any one interested >> in seeing if they can find and correct the two files for me? And maybe give >> some tips and or suggest some software tools I have not already tried? >> Cryptic CGAL errors don't really help me find and fix what OpenSCAD is >> complaining about. >> >> back-cover-no-stand-2.stl >> <http://forum.openscad.org/file/t1425/back-cover-no-stand-2.stl> >> _LCD_face_plate_LCD_hole_open_(repaired).stl >> <http://forum.openscad.org/file/t1425/_LCD_face_plate_LCD_hole_open_%28repaired%29.stl> >> puzzlecutlib3.scad <http://forum.openscad.org/file/t1425/puzzlecutlib3.scad> >> >> Thanks for all the help. For the fun of it, I checked your files in my own tool. The first one (back-cover-no-stand-2.stl) reports no problems. The second "repaired" _LCD_face_plate... reports numerous problems and a fix is attempted (seems better although not 100% clean) Here is a link to the fixed file (link will expire in 2 days). I don't know if it works any better than what you had, but you can try. https://www.expirebox.com/download/050b8ca1679fcea5bfa17ea49aa6fc21.html What is reported is for example - many collapsed/zero area faces - many duplicated faces - many non-manifold faces It should be said that STL contains zero topology, so any claim of non-manifoldness is a subjective interpretation of the data. For exchanging between applications if would have been better to use a format with explicit topology e.g. Wavefront OBJ. But STL is indeed very common with all its issues. Below is the log from my tool showing iterative attempts to fix your file. The approach taken when interpreting the STL is quite different from OpenSCADs "grid" approach so the result is likely not going to be the same, but perhaps OpenSCAD likes the result better. In iteration 0, the STL "polygon soup" is read. The high number of initial non-manifold edges is normal for STL since it is a polygon soup with no connectivity at all. From iteration 1, connectivity is interpreted by merging vertices (with distance < dtol), and thus the number of non-manifold edges is much reduced. The vertex merging process leaves some zero area faces (with area < atol) that are subsequently removed. Also, duplicate faces are removed. After 6 iterations the only remaining issues are a few non-manifold edges remain which cannot easily be resolved. However, the resulting file is likely more usable in other programs, maybe also in OpenSCAD. I could not test it in OpenSCAD since I am on Kubuntu 18.04 and apparently there is no usable binary for 18.04. ------ Parameters: input_file = _LCD_face_plate_LCD_hole_open_(repaired).stl polyhedron 0 ================= volume=35242.9, dtol=0.01, atol=1e-06, maxiter=10 iteration 0: vertices=43758 faces=14586 warning: 1 zero area faces. warning: nonmanifold edges: uc(1)=43758 merged 38113 vertices removed 2612 collapsed or zero area faces split 32 faces removed 366 duplicate faces removed 161 nonmanifold faces removed 29 zero area faces total changes=41313 warning: nonmanifold edges: uc(1)=61 uc(3)=71 uc(4)=57 uc(5)=1 iteration 1: vertices=5645 faces=11515 warning: nonmanifold edges: uc(1)=61 uc(3)=71 uc(4)=57 uc(5)=1 removed 6 unused vertices merged 434 vertices removed 790 collapsed or zero area faces split 8 faces removed 145 duplicate faces removed 71 nonmanifold faces removed 8 zero area faces total changes=1462 warning: nonmanifold edges: uc(1)=26 uc(3)=27 uc(4)=37 uc(6)=1 uc(7)=1 iteration 2: vertices=5205 faces=10514 warning: nonmanifold edges: uc(1)=26 uc(3)=27 uc(4)=37 uc(6)=1 uc(7)=1 removed 5 unused vertices merged 114 vertices removed 227 collapsed or zero area faces split 2 faces removed 42 duplicate faces removed 30 nonmanifold faces removed 4 zero area faces total changes=424 warning: nonmanifold edges: uc(1)=9 uc(3)=6 uc(4)=19 iteration 3: vertices=5086 faces=10213 warning: nonmanifold edges: uc(1)=9 uc(3)=6 uc(4)=19 removed 4 unused vertices merged 19 vertices removed 40 collapsed or zero area faces split 6 faces removed 5 duplicate faces removed 2 nonmanifold faces removed 6 zero area faces total changes=82 warning: nonmanifold edges: uc(1)=4 uc(3)=12 uc(4)=15 iteration 4: vertices=5063 faces=10172 warning: nonmanifold edges: uc(1)=4 uc(3)=12 uc(4)=15 removed 1 unused vertex split 2 faces removed 1 duplicate face removed 2 nonmanifold faces removed 4 zero area faces total changes=10 warning: nonmanifold edges: uc(1)=1 uc(3)=7 uc(4)=15 iteration 5: vertices=5062 faces=10168 warning: nonmanifold edges: uc(1)=1 uc(3)=7 uc(4)=15 removed 1 unused vertex total changes=1 warning: nonmanifold edges: uc(1)=1 uc(3)=7 uc(4)=15 iteration 6: vertices=5061 faces=10168 warning: nonmanifold edges: uc(1)=1 uc(3)=7 uc(4)=15 total changes=0 warning: nonmanifold edges: uc(1)=1 uc(3)=7 uc(4)=15 Summary: polyhedron 0: vertices=5061 faces=10168 : warning: nonmanifold edges: uc(1)=1 uc(3)=7 uc(4)=15 Writing: _LCD_face_plate_LCD_hole_open_(repaired)_polyfix.stl ... abm_polyfix finished, time used: 0d 00h 00m 01s ----- When you have as many issues as in this example, you cannot expect import + booleans will work very well, if at all. Even my attempted fix may still be problematic, but you can try. It could be that the "repaired" version you provided has more problems than the original. With such issues it isn't a surprise that using it in OpenSCAD was a problem. Carsten Arnholm
F
FourthDr
Wed, Sep 5, 2018 8:27 PM
NopHead:
What do you mean by "2-manifold"? I thought manifold was well, manifold.
There is some other type of manifold?
NopHead: What do you mean by "2-manifold"? I thought manifold was well, manifold. There is some other type of manifold? -- Sent from: http://forum.openscad.org/
Wed, Sep 5, 2018 8:58 PM
It is the technical term for the topology of the bounding surface of a
three dimensional shape, I think.
There are other degrees of manifoldness for other dimensions but it is
beyond my knowledge of maths.
On 5 September 2018 at 21:27, FourthDr who_doctor@hotmail.com wrote:
NopHead:
It is the technical term for the topology of the bounding surface of a three dimensional shape, I think. There are other degrees of manifoldness for other dimensions but it is beyond my knowledge of maths. On 5 September 2018 at 21:27, FourthDr <who_doctor@hotmail.com> wrote: > NopHead: > > What do you mean by "2-manifold"? I thought manifold was well, manifold. > There is some other type of manifold? > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
F
FourthDr
Wed, Sep 5, 2018 9:15 PM
Cacb:
Very interesting. What tool are you using? I tried the ployfixed LCD file
and OpenSCAD is still throwing a CGAL error. I did fix the back cover part
so I know it is manifold. That's why I don't understand why OpenSCAD doesn't
work. The preview works fine. But when I click render I get a blank screen
and this message:
Geometries in cache: 33
Geometry cache size in bytes: 3560328
CGAL Polyhedrons in cache: 32
CGAL cache size in bytes: 1232672
Total rendering time: 0 hours, 0 minutes, 0 seconds
Rendering finished.
OpenSCAD appears to just ignore the file and render nothing. What's going on
there? I'm stumped. Please see attached unaltered LCD stl below. The file
was collected from Thingiverse thing #1922863 here:
https://www.thingiverse.com/thing:1922863
_LCD_face_plate_LCD_hole_open.STL
http://forum.openscad.org/file/t1425/_LCD_face_plate_LCD_hole_open.STL
Cacb: Very interesting. What tool are you using? I tried the ployfixed LCD file and OpenSCAD is still throwing a CGAL error. I did fix the back cover part so I know it is manifold. That's why I don't understand why OpenSCAD doesn't work. The preview works fine. But when I click render I get a blank screen and this message: Compiling design (CSG Tree generation)... Rendering Polygon Mesh using CGAL... Geometries in cache: 33 Geometry cache size in bytes: 3560328 CGAL Polyhedrons in cache: 32 CGAL cache size in bytes: 1232672 Total rendering time: 0 hours, 0 minutes, 0 seconds Rendering finished. OpenSCAD appears to just ignore the file and render nothing. What's going on there? I'm stumped. Please see attached unaltered LCD stl below. The file was collected from Thingiverse thing #1922863 here: https://www.thingiverse.com/thing:1922863 <https://www.thingiverse.com/thing:1922863> _LCD_face_plate_LCD_hole_open.STL <http://forum.openscad.org/file/t1425/_LCD_face_plate_LCD_hole_open.STL> -- Sent from: http://forum.openscad.org/
F
FourthDr
Thu, Sep 6, 2018 4:35 AM
Cacb:
Here is the top half of that bottom that doesn't render, even though it is
manifold and appears to have no problems. Since we are taking about the
bottom half already. This one has a major problem.  I just tried to open it
in Tinkercad, and once I finished importing it the whole top part vanished.
Looks like some one made the top half of bits and pieces but didn't fuse
them together properly. I can't figure out how to fix it either. Case to
take a swipe?
FRONT_COVER.stl http://forum.openscad.org/file/t1425/FRONT_COVER.stl
Cacb: Here is the top half of that bottom that doesn't render, even though it is manifold and appears to have no problems. Since we are taking about the bottom half already. This one has a major problem. I just tried to open it in Tinkercad, and once I finished importing it the whole top part vanished. Looks like some one made the top half of bits and pieces but didn't fuse them together properly. I can't figure out how to fix it either. Case to take a swipe? FRONT_COVER.stl <http://forum.openscad.org/file/t1425/FRONT_COVER.stl> -- Sent from: http://forum.openscad.org/
arnholm@arnholm.org
Thu, Sep 6, 2018 6:55 AM
manifold.
2-manifold edge means that edge is referenced by exactly 2 faces.
1-manifold edge means it is referenced by exactly 1 face and that face
is then obviously not contributing to a closed volume boundary. In
general, an edge being N-manifold means the edge is referenced by N
faces. In loose language you could say a face is non-manifold if it
refers to at least one edge that is not 2-manifold.
In 3d-printing it is common to require all edges to be 2-manifold,
because the faces will then unambiguously define one or more closed
volumes. If you had a more sophisticated representation of volumes with
sub-volumes using e.g. different materials, it would make a lot of sense
to allow N-manifold edges for N>2, but it is not possible within a
single STL.
An STL file contains disconnected triangles ("polygon soup"), i.e. faces
with exactly 3 edges. An edge runs between 2 vertices. A vertex has XYZ
coordinates.  Strictly speaking, in STL files all edges are 1-manifold,
because there is no concept of edge or vertex sharing, all vertices (and
coordinates) are repeated for every triangle, hence it is a "polygon
soup". It is up to the software reading the STL file to have a guess at
what matches what and which manifoldness it is supposed to represent,
and this often leads to conflicting interpretations. STL is (somewhat)
OK for slicer programs, but not really a good choice for import to CAD
programs, due to the interpretation issues mentioned. As mentioned,
there are other formats that are less ambiguous, including WaveFront
OBJ.
On 2018-09-05 22:27, FourthDr wrote: > What do you mean by "2-manifold"? I thought manifold was well, > manifold. > There is some other type of manifold? 2-manifold edge means that edge is referenced by exactly 2 faces. 1-manifold edge means it is referenced by exactly 1 face and that face is then obviously not contributing to a closed volume boundary. In general, an edge being N-manifold means the edge is referenced by N faces. In loose language you could say a face is non-manifold if it refers to at least one edge that is not 2-manifold. In 3d-printing it is common to require all edges to be 2-manifold, because the faces will then unambiguously define one or more closed volumes. If you had a more sophisticated representation of volumes with sub-volumes using e.g. different materials, it would make a lot of sense to allow N-manifold edges for N>2, but it is not possible within a single STL. An STL file contains disconnected triangles ("polygon soup"), i.e. faces with exactly 3 edges. An edge runs between 2 vertices. A vertex has XYZ coordinates. Strictly speaking, in STL files all edges are 1-manifold, because there is no concept of edge or vertex sharing, all vertices (and coordinates) are repeated for every triangle, hence it is a "polygon soup". It is up to the software reading the STL file to have a guess at what matches what and which manifoldness it is supposed to represent, and this often leads to conflicting interpretations. STL is (somewhat) OK for slicer programs, but not really a good choice for import to CAD programs, due to the interpretation issues mentioned. As mentioned, there are other formats that are less ambiguous, including WaveFront OBJ. Carsten Arnholm
Thu, Sep 6, 2018 10:09 AM
For SOME stuff I import "their" STL and add the things I need for
printing on my printer. I think "brim" is overrated. It adds material
where the object doesn't need it and not enough where it does.
For stuff that is high and long, and tends to pull the ends off the
bed, I now add a half cone of a few layers high to the ends. Works
great. Except when there end up being STL errors.
**    Delftechpark 26 2628 XH  Delft, The Netherlands. KVK: 27239233    **
On Wed, Sep 05, 2018 at 04:47:07PM +0100, nop head wrote: > I have never had much success with other people's STLs for 3D > printing. Even if they are manifold they are often not correct for > 3D printing on my machines. I mostly design everything I print from > scratch in OpenSCAD. For SOME stuff I import "their" STL and add the things I need for printing on my printer. I think "brim" is overrated. It adds material where the object doesn't need it and not enough where it does. For stuff that is high and long, and tends to pull the ends off the bed, I now add a half cone of a few layers high to the ends. Works great. Except when there end up being STL errors. Roger. -- ** R.E.Wolff@BitWizard.nl ** http://www.BitWizard.nl/ ** +31-15-2600998 ** ** Delftechpark 26 2628 XH Delft, The Netherlands. KVK: 27239233 ** *-- BitWizard writes Linux device drivers for any device you may have! --* The plan was simple, like my brother-in-law Phil. But unlike Phil, this plan just might work.
Thu, Sep 6, 2018 10:22 AM
Yes but brim adds just more outlines that can be removed easily. If you add
it to the model it will be fully incorporated, how do you remove it from
the print?
Yes but brim adds just more outlines that can be removed easily. If you add it to the model it will be fully incorporated, how do you remove it from the print? On 6 September 2018 at 11:09, Rogier Wolff <R.E.Wolff@bitwizard.nl> wrote: > On Wed, Sep 05, 2018 at 04:47:07PM +0100, nop head wrote: > > > I have never had much success with other people's STLs for 3D > > printing. Even if they are manifold they are often not correct for > > 3D printing on my machines. I mostly design everything I print from > > scratch in OpenSCAD. > > For SOME stuff I import "their" STL and add the things I need for > printing on my printer. I think "brim" is overrated. It adds material > where the object doesn't need it and not enough where it does. > > For stuff that is high and long, and tends to pull the ends off the > bed, I now add a half cone of a few layers high to the ends. Works > great. Except when there end up being STL errors. > > Roger. > > -- > ** R.E.Wolff@BitWizard.nl ** http://www.BitWizard.nl/ ** +31-15-2600998 ** > ** Delftechpark 26 2628 XH Delft, The Netherlands. KVK: 27239233 ** > *-- BitWizard writes Linux device drivers for any device you may have! --* > The plan was simple, like my brother-in-law Phil. But unlike > Phil, this plan just might work. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
EN
Ed Nisley
Thu, Sep 6, 2018 12:43 PM
The inside surface of the lid is oriented incorrectly (there's no
"inside") and the outside surface has a bunch of self-intersecting
triangles. Slic3r's auto-repair algorithm gets it mostly right, although
the rectangular openings seem covered with Z-fighting membranes.
It's a wonder 3D printing works at all ...
Ed
https://softsolder.com
On 09/06/2018 12:35 AM, FourthDr wrote: > the whole top part vanished The inside surface of the lid is oriented incorrectly (there's no "inside") and the outside surface has a bunch of self-intersecting triangles. Slic3r's auto-repair algorithm gets it mostly right, although the rectangular openings seem covered with Z-fighting membranes. It's a wonder 3D printing works at all ... -- Ed https://softsolder.com
