Tail recursion
Ronaldo
Mon, Apr 11, 2016 5:49 PM
OpenSCAD can do simple tail recursion elimination, so if the
function is matching the simple "cond ? result : recurse()"
it will not be limited by stack (there's still a loop limit
but that's much higher... a million, I think?).
However, not all recursive functions that match the model "cond ? result :
recurse()" are interpreted to tail recursion by OpenSCAD. For instance:
function test_one(p,i) = (p[i]>=0);
// iteractive version
function test_all_0(p) = [ for(i=[0:len(p)-1]) if( ! test_one(p,i) ) 0] ==
function test_all_1(p, i=0) =  // tail recursion
i >= len(p) || ! test_one(p,i) ?
i >= len(p) :
test_all_1(p, i+1);
function test_all_2(p, i=0) = // no tail recursion: overflow for
len(p)>=8000
i >= len(p)? true : ! test_one(p,i) ?
false :
test_all_2(p, i+1);
So, the question is: which expressions cond are allowed in "cond ? result :
recurse()" to get tail recursion?
View this message in context: http://forum.openscad.org/Tail-recursion-tp17040.html
In another thread <http://forum.openscad.org/Simple-polygon-triangulation-tp16755.html> , Torsten said: > OpenSCAD can do simple tail recursion elimination, so if the > function is matching the simple "cond ? result : recurse()" > it will not be limited by stack (there's still a loop limit > but that's much higher... a million, I think?). However, not all recursive functions that match the model "cond ? result : recurse()" are interpreted to tail recursion by OpenSCAD. For instance: > function test_one(p,i) = (p[i]>=0); > // iteractive version > function test_all_0(p) = [ for(i=[0:len(p)-1]) if( ! test_one(p,i) ) 0] == > []; > > function test_all_1(p, i=0) = // tail recursion > i >= len(p) || ! test_one(p,i) ? > i >= len(p) : > test_all_1(p, i+1); > > function test_all_2(p, i=0) = // no tail recursion: overflow for > len(p)>=8000 > i >= len(p)? true : ! test_one(p,i) ? > false : > test_all_2(p, i+1); So, the question is: which expressions cond are allowed in "cond ? result : recurse()" to get tail recursion? -- View this message in context: http://forum.openscad.org/Tail-recursion-tp17040.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Apr 11, 2016 5:59 PM
len(p)>=8000
false :
test_all_2(p, i+1);
Exactly those that match this pattern. The test_all_2() example
does not match, it has a second condition instead of the direct
recursive call.
On 04/11/2016 07:49 PM, Ronaldo wrote: >> function test_all_2(p, i=0) = // no tail recursion: overflow for >> len(p)>=8000 >> i >= len(p)? true : ! test_one(p,i) ? >> false : >> test_all_2(p, i+1); > > So, the question is: which expressions cond are allowed in "cond ? result : > recurse()" to get tail recursion? > Exactly those that match this pattern. The test_all_2() example does not match, it has a second condition instead of the direct recursive call. ciao, Torsten.
Ronaldo
Mon, Apr 11, 2016 6:11 PM
Transcription mistake:  test_all_2 should be written as:
i >= len(p) :
test_all_2(p, i+1);
May be I got an answer to my own question. The following function seems to
be a tail recursion:
function test_all_3(p, i=0) =
( i >= len(p)? true : ! test_one(p,i)  ) ?
i >= len(p) :
test_all_3(p, i+1);
A few parenthesis made the difference.
View this message in context: http://forum.openscad.org/Tail-recursion-tp17040p17042.html
Transcription mistake: test_all_2 should be written as: > function test_all_2(p, i=0) = > i >= len(p)? true : ! test_one(p,i) ? > i >= len(p) : > test_all_2(p, i+1); May be I got an answer to my own question. The following function seems to be a tail recursion: > function test_all_3(p, i=0) = > ( i >= len(p)? true : ! test_one(p,i) ) ? > i >= len(p) : > test_all_3(p, i+1); A few parenthesis made the difference. -- View this message in context: http://forum.openscad.org/Tail-recursion-tp17040p17042.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Apr 11, 2016 6:14 PM
Indeed, as they change the top level expression to the
structure which is currently the only supported case
for tail recursion elimination.
If someone has pointers for how to implement better
solutions, please post those. Searching for this so
far mainly returns documentation about how to use
it.
On 04/11/2016 08:11 PM, Ronaldo wrote: > A few parenthesis made the difference. > Indeed, as they change the top level expression to the structure which is currently the only supported case for tail recursion elimination. If someone has pointers for how to implement better solutions, please post those. Searching for this so far mainly returns documentation about how to _use_ it. ciao, Torsten.
Tue, Apr 12, 2016 1:35 AM
My plan for implementing tail recursion is to compile OpenSCAD into byte
codes, and write a byte code interpreter with an explicitly managed stack.
(Maybe separate data and control stacks.) This should run a lot faster than
the current parse tree interpreter.
While compiling the function 'g', if the compiler detects a tail call to a
user defined function 'f(x)', such that the value returned by 'f(x)' is
immediately returned as the result of 'g', then instead of emitting a CALL
instruction, it instead emits a TAIL_CALL instruction, which basically
fixes up the stack so that the activation record for 'g' is replaced by the
arguments to 'f', and then it jumps to 'f'. As a special case, if 'g'
recursively calls itself in tail position, that is also handled as a jump,
without any stack growth.
I don't know an easy way to implement generalized tail recursion
elimination for a parse tree interpreter. There is a technique called a
'trampoline' that might be applicable, but that's probably more trouble
than it is worth.
it.
My plan for implementing tail recursion is to compile OpenSCAD into byte codes, and write a byte code interpreter with an explicitly managed stack. (Maybe separate data and control stacks.) This should run a lot faster than the current parse tree interpreter. While compiling the function 'g', if the compiler detects a tail call to a user defined function 'f(x)', such that the value returned by 'f(x)' is immediately returned as the result of 'g', then instead of emitting a CALL instruction, it instead emits a TAIL_CALL instruction, which basically fixes up the stack so that the activation record for 'g' is replaced by the arguments to 'f', and then it jumps to 'f'. As a special case, if 'g' recursively calls itself in tail position, that is also handled as a jump, without any stack growth. I don't know an easy way to implement generalized tail recursion elimination for a parse tree interpreter. There is a technique called a 'trampoline' that might be applicable, but that's probably more trouble than it is worth. On 11 April 2016 at 14:14, Torsten Paul <Torsten.Paul@gmx.de> wrote: > On 04/11/2016 08:11 PM, Ronaldo wrote: > > A few parenthesis made the difference. > > > Indeed, as they change the top level expression to the > structure which is currently the only supported case > for tail recursion elimination. > > If someone has pointers for how to implement better > solutions, please post those. Searching for this so > far mainly returns documentation about how to _use_ > it. > > ciao, > Torsten. > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > >
Tue, Apr 12, 2016 1:38 AM
Ronaldo: test_all_2 does not match the pattern, because the body of the
function is
i >= len(p)
? true
: (! test_one(p,i)
? false
: test_all_2(p, i+1))
The body is X ? Y : Z where neither Y nor Z is a call to test_all_2. In
this case, Z is (! test_one(p,i)
? false
i >= len(p) :
test_all_1(p, i+1);
len(p)>=8000
false :
test_all_2(p, i+1);
Ronaldo: test_all_2 does not match the pattern, because the body of the function is i >= len(p) ? true : (! test_one(p,i) ? false : test_all_2(p, i+1)) The body is X ? Y : Z where neither Y nor Z is a call to test_all_2. In this case, Z is (! test_one(p,i) ? false : test_all_2(p, i+1) On 11 April 2016 at 13:49, Ronaldo <rcmpersiano@gmail.com> wrote: > In another thread > <http://forum.openscad.org/Simple-polygon-triangulation-tp16755.html> , > Torsten said: > > > OpenSCAD can do simple tail recursion elimination, so if the > > function is matching the simple "cond ? result : recurse()" > > it will not be limited by stack (there's still a loop limit > > but that's much higher... a million, I think?). > > However, not all recursive functions that match the model "cond ? result : > recurse()" are interpreted to tail recursion by OpenSCAD. For instance: > > > function test_one(p,i) = (p[i]>=0); > > // iteractive version > > function test_all_0(p) = [ for(i=[0:len(p)-1]) if( ! test_one(p,i) ) 0] > == > > []; > > > > function test_all_1(p, i=0) = // tail recursion > > i >= len(p) || ! test_one(p,i) ? > > i >= len(p) : > > test_all_1(p, i+1); > > > > function test_all_2(p, i=0) = // no tail recursion: overflow for > > len(p)>=8000 > > i >= len(p)? true : ! test_one(p,i) ? > > false : > > test_all_2(p, i+1); > > So, the question is: which expressions cond are allowed in "cond ? result : > recurse()" to get tail recursion? > > > > -- > View this message in context: > http://forum.openscad.org/Tail-recursion-tp17040.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > >
Ronaldo
Tue, Apr 12, 2016 2:13 AM
function is...
I understand that now. But I have another question. The code bellow is an
attempt to write a tail recursion version of quicksort. It seems to follow
the pattern you mentioned:
function qs(arr, arr_out=[]) =
!(len(arr)>0) ?
arr_out :
qs( arr    = high_part(arr),
arr_out = concat(qs( low_part(arr), arr_out ),
middle_part(arr)) );
function high_part  (arr) = [ for (y = arr) if (y >  pivot(arr)) y ];
function middle_part(arr) = [ for (y = arr) if (y == pivot(arr)) y ];
function low_part  (arr) = [ for (y = arr) if (y <  pivot(arr)) y ];
function pivot      (arr) = arr[floor(len(arr)/2)];
However, I have two recursive calls in the last line of qs(). Is it really a
tail recursion? How evaluator deal with it?
View this message in context: http://forum.openscad.org/Tail-recursion-tp17040p17052.html
doug.moen wrote > Ronaldo: test_all_2 does not match the pattern, because the body of the > function is... I understand that now. But I have another question. The code bellow is an attempt to write a tail recursion version of quicksort. It seems to follow the pattern you mentioned: > function qs(arr, arr_out=[]) = > !(len(arr)>0) ? > arr_out : > qs( arr = high_part(arr), > arr_out = concat(qs( low_part(arr), arr_out ), > middle_part(arr)) ); > > function high_part (arr) = [ for (y = arr) if (y > pivot(arr)) y ]; > function middle_part(arr) = [ for (y = arr) if (y == pivot(arr)) y ]; > function low_part (arr) = [ for (y = arr) if (y < pivot(arr)) y ]; > function pivot (arr) = arr[floor(len(arr)/2)]; However, I have two recursive calls in the last line of qs(). Is it really a tail recursion? How evaluator deal with it? -- View this message in context: http://forum.openscad.org/Tail-recursion-tp17040p17052.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Apr 12, 2016 2:34 AM
The innermost call to qs is not tail recursive, so the stack will grow
while evaluating nested calls to qs. Quicksort is inherently
non-tail-recursive in any language.
On 11 April 2016 at 22:13, Ronaldo rcmpersiano@gmail.com wrote:
function is...
!(len(arr)>0) ?
arr_out :
a
The innermost call to qs is not tail recursive, so the stack will grow while evaluating nested calls to qs. Quicksort is inherently non-tail-recursive in any language. On 11 April 2016 at 22:13, Ronaldo <rcmpersiano@gmail.com> wrote: > doug.moen wrote > > Ronaldo: test_all_2 does not match the pattern, because the body of the > > function is... > > I understand that now. But I have another question. The code bellow is an > attempt to write a tail recursion version of quicksort. It seems to follow > the pattern you mentioned: > > > function qs(arr, arr_out=[]) = > > !(len(arr)>0) ? > > arr_out : > > qs( arr = high_part(arr), > > arr_out = concat(qs( low_part(arr), arr_out ), > > middle_part(arr)) ); > > > > function high_part (arr) = [ for (y = arr) if (y > pivot(arr)) y ]; > > function middle_part(arr) = [ for (y = arr) if (y == pivot(arr)) y ]; > > function low_part (arr) = [ for (y = arr) if (y < pivot(arr)) y ]; > > function pivot (arr) = arr[floor(len(arr)/2)]; > > However, I have two recursive calls in the last line of qs(). Is it really > a > tail recursion? How evaluator deal with it? > > > > -- > View this message in context: > http://forum.openscad.org/Tail-recursion-tp17040p17052.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > >
Tue, Apr 12, 2016 6:47 AM
Tail recursion does not always have to happen in the tail.
It depends a bit on your definition of "tail recursion". But Tail
recursion can be said to happen when a function call is followed
immediately by a return-from-this-function.
This can happen in the middle of a function.
In the case of quicksort, there are two recursive calls to
quicksort. The first needs to allocate a stack frame, but the second
one can be optimized to a tail-recursion (i.e. jump (not call) to the
beginning of the function.)
In the implementation below, a concat operation needs to be done after
return from the second quicksort. That prevents tail-recursion. This
happens because the sort is not happening in-place.In a language where
it would happen in-place, like C quicksort can become tail-recursive.
function is...
!(len(arr)>0) ?
arr_out :
a
**    Delftechpark 26 2628 XH  Delft, The Netherlands. KVK: 27239233    **
On Mon, Apr 11, 2016 at 10:34:28PM -0400, doug moen wrote: > The innermost call to qs is not tail recursive, so the stack will grow > while evaluating nested calls to qs. Quicksort is inherently > non-tail-recursive in any language. Tail recursion does not always have to happen in the tail. It depends a bit on your definition of "tail recursion". But Tail recursion can be said to happen when a function call is followed immediately by a return-from-this-function. This can happen in the middle of a function. In the case of quicksort, there are two recursive calls to quicksort. The first needs to allocate a stack frame, but the second one can be optimized to a tail-recursion (i.e. jump (not call) to the beginning of the function.) In the implementation below, a concat operation needs to be done after return from the second quicksort. That prevents tail-recursion. This happens because the sort is not happening in-place.In a language where it would happen in-place, like C quicksort can become tail-recursive. Roger. > > On 11 April 2016 at 22:13, Ronaldo <rcmpersiano@gmail.com> wrote: > > > doug.moen wrote > > > Ronaldo: test_all_2 does not match the pattern, because the body of the > > > function is... > > > > I understand that now. But I have another question. The code bellow is an > > attempt to write a tail recursion version of quicksort. It seems to follow > > the pattern you mentioned: > > > > > function qs(arr, arr_out=[]) = > > > !(len(arr)>0) ? > > > arr_out : > > > qs( arr = high_part(arr), > > > arr_out = concat(qs( low_part(arr), arr_out ), > > > middle_part(arr)) ); > > > > > > function high_part (arr) = [ for (y = arr) if (y > pivot(arr)) y ]; > > > function middle_part(arr) = [ for (y = arr) if (y == pivot(arr)) y ]; > > > function low_part (arr) = [ for (y = arr) if (y < pivot(arr)) y ]; > > > function pivot (arr) = arr[floor(len(arr)/2)]; > > > > However, I have two recursive calls in the last line of qs(). Is it really > > a > > tail recursion? How evaluator deal with it? > > > > > > > > -- > > View this message in context: > > http://forum.openscad.org/Tail-recursion-tp17040p17052.html > > Sent from the OpenSCAD mailing list archive at Nabble.com. > > > > _______________________________________________ > > OpenSCAD mailing list > > Discuss@lists.openscad.org > > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org -- ** R.E.Wolff@BitWizard.nl ** http://www.BitWizard.nl/ ** +31-15-2600998 ** ** Delftechpark 26 2628 XH Delft, The Netherlands. KVK: 27239233 ** *-- BitWizard writes Linux device drivers for any device you may have! --* The plan was simple, like my brother-in-law Phil. But unlike Phil, this plan just might work.
Ronaldo
Tue, Apr 12, 2016 6:54 AM
So, the code of qs() uses tail recursion for the higher part and regular
recursion for the lower one. This agrees with some quicksort schemes I found
where they use "while" iteration instead of one of the recursions. Usually
the method iterates over the smaller partition. In qs(), I replaced the
iteration by a tail recursion.
I don't see how to implement in OpenSCAD language the full scheme where the
iteration (or tail recursion) operates over the smaller partition. If a
let() was allowed in tail recursion... it might be possible.
View this message in context: http://forum.openscad.org/Tail-recursion-tp17040p17061.html
So, the code of qs() uses tail recursion for the higher part and regular recursion for the lower one. This agrees with some quicksort schemes I found where they use "while" iteration instead of one of the recursions. Usually the method iterates over the smaller partition. In qs(), I replaced the iteration by a tail recursion. I don't see how to implement in OpenSCAD language the full scheme where the iteration (or tail recursion) operates over the smaller partition. If a let() was allowed in tail recursion... it might be possible. -- View this message in context: http://forum.openscad.org/Tail-recursion-tp17040p17061.html Sent from the OpenSCAD mailing list archive at Nabble.com.
