Calendar
F
fractorr@gmail.com
Wed, Jul 28, 2021 3:11 PM
I decided to try to make a calendar generator in OpenSCAD, this is what I came up with.  Why make one?  Just to see if I could since I was not able to find one.  There are a couple of work arounds I had to do and borrowed the first day of month formula.  It seems to work fine now.
What do you think?  Use however you like if you want to.
I decided to try to make a calendar generator in OpenSCAD, this is what I came up with. Why make one? Just to see if I could since I was not able to find one. There are a couple of work arounds I had to do and borrowed the first day of month formula. It seems to work fine now. What do you think? Use however you like if you want to.
F
fred
Wed, Jul 28, 2021 4:20 PM
The calendar is an interesting project. Most people will use 01 for January. Why the non-standard configuration for the months?
On Wednesday, July 28, 2021, 11:12:21 AM EDT, fractorr@gmail.com <fractorr@gmail.com> wrote:
The calendar is an interesting project. Most people will use 01 for January. Why the non-standard configuration for the months? On Wednesday, July 28, 2021, 11:12:21 AM EDT, fractorr@gmail.com <fractorr@gmail.com> wrote: I decided to try to make a calendar generator in OpenSCAD, this is what I came up with. Why make one? Just to see if I could since I was not able to find one. There are a couple of work arounds I had to do and borrowed the first day of month formula. It seems to work fine now. What do you think? Use however you like if you want to. _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to discuss-leave@lists.openscad.org
F
fractorr@gmail.com
Wed, Jul 28, 2021 4:50 PM
Not sure about the non standard config for the months, that was the way the formula was setup ( I borrowed the formula ) for the calculation to get the first day of the month for a given year.  Seems odd to me as well but it seems to work and that was one of the odd things I had to make a work around for.
I have several ideas for the calendar already, mainly going to use it to export as a svg file for laser engraving.
Not sure about the non standard config for the months, that was the way the formula was setup ( I borrowed the formula ) for the calculation to get the first day of the month for a given year. Seems odd to me as well but it seems to work and that was one of the odd things I had to make a work around for. I have several ideas for the calendar already, mainly going to use it to export as a svg file for laser engraving.
BR
Bob Roos
Wed, Jul 28, 2021 11:45 PM
I would guess that starting the year in March as #1 is because of February irregularities with leap year and non leap centuries.
Thu, Jul 29, 2021 3:49 AM
OK, but that didn't really pan out.... See attached.
I know it was a leap year because I missed beinf born on the 29th by
about 1.5 hrs.
On Wed, 2021-07-28 at 19:45 -0400, Bob Roos wrote: > I would guess that starting the year in March as #1 is because of > February irregularities with leap year and non leap centuries. OK, but that didn't really pan out.... See attached. I know it was a leap year because I missed beinf born on the 29th by about 1.5 hrs.
F
fractorr@gmail.com
Thu, Jul 29, 2021 2:02 PM
Oops, I guess I forgot to add the leap year check in.  Here is the updated version.
Thu, Jul 29, 2021 5:32 PM
updated version.
MUCH better!
Only one other thing, really a minor point, and I doubt anyone will try
to 3D-print one for September, 1752 or before. The earliest calendar
that will be correct is October, 1752
I probably wouldn't even bother doing it, but it's your choice.
Gives me the result: attached.
Should be (view with monospaced font. The 1st was on Tuesday):
September 1752
Su Mo Tu We Th Fr Sa
1  2 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
On Thu, 2021-07-29 at 14:02 +0000, fractorr@gmail.com wrote: > Oops, I guess I forgot to add the leap year check in. Here is the > updated version. MUCH better! Only one other thing, really a minor point, and I doubt anyone will try to 3D-print one for September, 1752 or before. The earliest calendar that will be correct is October, 1752 I probably wouldn't even bother doing it, but it's your choice. Gives me the result: attached. Should be (view with monospaced font. The 1st was on Tuesday): September 1752 Su Mo Tu We Th Fr Sa 1 2 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
F
fractorr@gmail.com
Thu, Jul 29, 2021 10:25 PM
Good to hear it works now. If someone wants to generate calendar’s going back to 1752 they are more than welcome to update the code. :)
