Hello everybody,
is there a way to make curved sides to a cube?
i don't mean circulair but more or less hyperbolic curves.
something like giving 3 or more points and let the naturally curve between
the point be calculated
http://forum.openscad.org/file/t2834/curve.png
or a formula to calculate
grts
henk
There is a shape called a cuboid which is possibly something like what you
are describing. I wrote an openscad module for them (I should update it, as
I have better ways of doing it now)
https://www.thingiverse.com/thing:3408435
On Wed, 7 Oct 2020, 03:54 Kevig, Kevigsp@hotmail.com wrote:
Hello everybody,
grts
henk
Actually, I think it's called a super-ellipsoid. I guess it's still too
early for me. The parameters can be set to cover anything from a cube to a
sphere to some rather off hyperbolic shapes
Hello everybody,
grts
henk
you are describing. I wrote an openscad module for them (I should
update it, as I have better ways of doing it now)
That model has all the face normals pointing inwards....
For the 2d case possibly the smooth_path module from BOSL2 does what you
want:
https://github.com/revarbat/BOSL2/wiki/rounding.scad#smooth_path
It's based on beziers. BOSL2 supports 3d beziers, but you'd have to work
out how to make the curved "faces" yourself. I think it's not so easy to
make a general "polyhedron smoother".
Kevig wrote
Hello everybody,
<http://forum.openscad.org/file/t2834/curve.png>
grts
henk
Discuss@.openscad
It is not so difficult either although laborious. You may define a
trivariate polynomial deformation using Bezier and apply it to a refinement
of the polyhedron. To find the appropriate control points of the
deformation may be the painful step.
I suppose if you take each face of the polyhedron (assume a convex
polyhedron) you could find the centerpoint and shift it away from the face,
and then triangulate. This forms a pyramid. Then each triangle could be
replaced by a degenerate bezier patch. Presumably you'd want to match
derivatives along the edges, but it's not clear what boundary condition
would be desired at the base of the pyramid.
This is a pretty complex endeavor and I think qualifies as "difficult".
Maybe there's some way to keep things simpler?
refinement
thanks you all,
you give me a good couple of pointers in the right direction.
i am going to try them and hopefully it is goig to work.
i let you know how it worked out
grts
h
There is @adrianv. What I had suggested was a simple polyhedron
deformation: each point of the polyhedron is mapped to a 3d point by a
non-linear function. The non-linear function I propose is a trivariate
polynomial function expressed in its Bezier form - a natural extension of
the bivariate Bezier patch functions:
function Bezier_transform( cp, s, t, u) = ...
where the control point cp is a tridimensional array of 3d points and s, t,
u are numbers. To avoid extrapolations in the polynomial transform, we
should pre-apply a linear transform so that points in a domain of the 3d
space (the polyhedron bounding box, for instance) are mapped to a subset of
[0,1]X [0,1]X [0,1] . A simple form of it is just a scale:
function lmap(point, box) = ...
that maps points in a box = [[xmin,xmax], [ymin,ymax], [zmin,zmax]] to
points in [0,1]X [0,1]X [0,1].
Now, each vertex v of the polyhedron (supposed to be in a vnf form) is
transformed by the composition of lmap and Bezier_transform :
new_vertices =
[for( v = vertex(polyhedron) )
let( w = lmap(v, bbox(polyhedron))) )
Bezier_transform(cp, w[0], w[1], w[2])
The set of the previously refined polyhedron faces are kept unchanged.
That kind of deformation will in general produce smooth curved faces (for
the original polyhedron facet) and smooth curved edges (for the original
polyhedron edges) but will not have a smooth transition from a curved face
to an adjacent one. The new shape will have wrinkles at the edges.
I don't expect a very fast processing with that but it is simple to code
and very general.
I suspect that most readers would not consider this approach "simple". As
far as I can tell, it is also not general. That is, it would work ok to
producing a bulging cube (which satisfies the original query), but that's
all. Suppose that the cube is simply the cube occupying [0,1]^3. Then it
is clear how to choose the control points to result in the desired bulge:
You create a 3x3x3 array of control points marking the corners of the cube
and the edge and face centers, and then you shift out the face centers.
Sampling the resulting bezier on the cube faces should produce the desired
bulging cube, where the original cube edges are preserved but the faces
bulge.
I found it easier to think about this in 2d for the square (where
implementations exist). And then it is easy so see the struggle that
arises: if I wish to produce a bulging triangle or bulging pentagon, now
what? The triangle can perhaps be achieved using a degenerate patch or a
triangular bezier patch. But how can one approach the pentagon or hexagon?
I'm not sure how to preserve the vertices of the original shape because the
bezier map only has 4 points that actually map to the control points. In
3-space if I want to create a bulging octahedron or dodecahedron, it is not
at all clear how to select control points that might do the job for the same
reason. How can I preserve the original polyhedron edges? It seems like I
can only produce a cube-style inflation that moves the shape outwards from
its center in each of the coordinate axis directions. This will break the
symmetry of the original polyhedron and it will not preserve edges. Have I
overlooked a simple answer?
face,
t,
of
new_vertices =
and very general.
Discuss@.openscad
