test_pretty_print.py no longer works on the MSYS2 build on Win7
Thu, Aug 23, 2018 4:31 PM
ctest fails over like this:
$ ctest -R nonascii
running 'C:/msys64/home/ChrisP/openscad/tests/../Release/openscad.exe
--info' to generate sysinfo.txt
Post test:C:/msys64/mingw64/bin/python.exe
"C:/msys64/home/ChrisP/openscad/tests/test_pretty_print.py"
--builddir=C:/msys64/home/ChrisP/openscad/tests
Test project C:/msys64/home/ChrisP/openscad/tests
Enforcing Default test configuration. Use ctest -C <config> to override
Start 1105: openscad-nonascii_sfære
1/1 Test #1105: openscad-nonascii_sfære .........***Failed    0.17 sec
0% tests passed, 1 tests failed out of 1
Total Test time (real) =  0.31 sec
The following tests FAILED:
1105 - openscad-nonascii_sfære (Failed)
Traceback (most recent call last):
File "C:/msys64/home/ChrisP/openscad/tests/test_pretty_print.py", line
532, in <module>
main()
497, in main
startdate, tests, enddate, imgcomparer = parselog(testlog)
187, in parselog
text = data.decode('utf-8')
File "C:/msys64/mingw64/lib/python2.7/encodings/utf_8.py", line 16, in
decode
return codecs.utf_8_decode(input, errors, True)
UnicodeDecodeError: 'utf8' codec can't decode byte 0xe6 in position 1071:
invalid continuation byte
Problem running command: C:/msys64/mingw64/bin/python.exe
Problem executing post-test command(s).
Errors while running CTest
This test has always failed for me but this change
https://github.com/openscad/openscad/commit/43c96c2b0b973cd58f9e0e85991a9bb1702c139d#diff-a8e90a51a93dfe54df9171c2cc591550
now makes the test system fail. I assume that the console output from
OpenSCAD is not utf-8 encoded in this environment but I don't really know
what the correct solution is.
ctest fails over like this: $ ctest -R nonascii running 'C:/msys64/home/ChrisP/openscad/tests/../Release/openscad.exe --info' to generate sysinfo.txt Post test:C:/msys64/mingw64/bin/python.exe "C:/msys64/home/ChrisP/openscad/tests/test_pretty_print.py" --builddir=C:/msys64/home/ChrisP/openscad/tests Test project C:/msys64/home/ChrisP/openscad/tests Enforcing Default test configuration. Use ctest -C <config> to override Start 1105: openscad-nonascii_sfære 1/1 Test #1105: openscad-nonascii_sfære .........***Failed 0.17 sec 0% tests passed, 1 tests failed out of 1 Total Test time (real) = 0.31 sec The following tests FAILED: 1105 - openscad-nonascii_sfære (Failed) Traceback (most recent call last): File "C:/msys64/home/ChrisP/openscad/tests/test_pretty_print.py", line 532, in <module> main() File "C:/msys64/home/ChrisP/openscad/tests/test_pretty_print.py", line 497, in main startdate, tests, enddate, imgcomparer = parselog(testlog) File "C:/msys64/home/ChrisP/openscad/tests/test_pretty_print.py", line 187, in parselog text = data.decode('utf-8') File "C:/msys64/mingw64/lib/python2.7/encodings/utf_8.py", line 16, in decode return codecs.utf_8_decode(input, errors, True) UnicodeDecodeError: 'utf8' codec can't decode byte 0xe6 in position 1071: invalid continuation byte Problem running command: C:/msys64/mingw64/bin/python.exe "C:/msys64/home/ChrisP/openscad/tests/test_pretty_print.py" --builddir=C:/msys64/home/ChrisP/openscad/tests Problem executing post-test command(s). Errors while running CTest This test has always failed for me but this change <https://github.com/openscad/openscad/commit/43c96c2b0b973cd58f9e0e85991a9bb1702c139d#diff-a8e90a51a93dfe54df9171c2cc591550> now makes the test system fail. I assume that the console output from OpenSCAD is not utf-8 encoded in this environment but I don't really know what the correct solution is.
Sat, Aug 25, 2018 11:06 AM
The main reason test_pretty_print.py falls over seems to be that the log it
receives has a mixture of latin1 and utf8 encoding so nothing can convert
it to unicode properly.
The log comes from test_cmdline_tool.py and that also falls over in
python2.7 due to this line:
https://github.com/openscad/openscad/blob/master/tests/test_cmdline_tool.py#L245
which adds an ascii string to a unicode string. Under Python3 both strings
are unicode so it will work.
So it looks like since I last used it mods have been made to make it
Python3 compatible. Is it still supposed to work on Python2?
One of the problems is sys.argv[] are ascii strings with latin encoding in
Python2 on Win7. Presumably they are already unicode in Python3 so I think
it would need code condition on the version just to handle the args. And on
Linux Python7 are they utf8?
Should I chase down the Python2 bugs or try to upgrade MSYS2 to Python3?
Having recently upgraded my native Python to 3 this is a whole world of
pain, manly because they changed the string type to unicode and you can no
longer use 8 bit ascii without encoding it.
$ ctest -R nonascii
532, in <module>
main()
497, in main
187, in parselog
decode
The main reason test_pretty_print.py falls over seems to be that the log it receives has a mixture of latin1 and utf8 encoding so nothing can convert it to unicode properly. The log comes from test_cmdline_tool.py and that also falls over in python2.7 due to this line: https://github.com/openscad/openscad/blob/master/tests/test_cmdline_tool.py#L245 which adds an ascii string to a unicode string. Under Python3 both strings are unicode so it will work. So it looks like since I last used it mods have been made to make it Python3 compatible. Is it still supposed to work on Python2? One of the problems is sys.argv[] are ascii strings with latin encoding in Python2 on Win7. Presumably they are already unicode in Python3 so I think it would need code condition on the version just to handle the args. And on Linux Python7 are they utf8? Should I chase down the Python2 bugs or try to upgrade MSYS2 to Python3? Having recently upgraded my native Python to 3 this is a whole world of pain, manly because they changed the string type to unicode and you can no longer use 8 bit ascii without encoding it. On 23 August 2018 at 17:31, nop head <nop.head@gmail.com> wrote: > ctest fails over like this: > > $ ctest -R nonascii > running 'C:/msys64/home/ChrisP/openscad/tests/../Release/openscad.exe > --info' to generate sysinfo.txt > Post test:C:/msys64/mingw64/bin/python.exe "C:/msys64/home/ChrisP/ > openscad/tests/test_pretty_print.py" --builddir=C:/msys64/home/ > ChrisP/openscad/tests > Test project C:/msys64/home/ChrisP/openscad/tests > Enforcing Default test configuration. Use ctest -C <config> to override > Start 1105: openscad-nonascii_sfære > 1/1 Test #1105: openscad-nonascii_sfære .........***Failed 0.17 sec > > 0% tests passed, 1 tests failed out of 1 > > Total Test time (real) = 0.31 sec > > The following tests FAILED: > 1105 - openscad-nonascii_sfære (Failed) > Traceback (most recent call last): > File "C:/msys64/home/ChrisP/openscad/tests/test_pretty_print.py", line > 532, in <module> > main() > File "C:/msys64/home/ChrisP/openscad/tests/test_pretty_print.py", line > 497, in main > startdate, tests, enddate, imgcomparer = parselog(testlog) > File "C:/msys64/home/ChrisP/openscad/tests/test_pretty_print.py", line > 187, in parselog > text = data.decode('utf-8') > File "C:/msys64/mingw64/lib/python2.7/encodings/utf_8.py", line 16, in > decode > return codecs.utf_8_decode(input, errors, True) > UnicodeDecodeError: 'utf8' codec can't decode byte 0xe6 in position 1071: > invalid continuation byte > Problem running command: C:/msys64/mingw64/bin/python.exe > "C:/msys64/home/ChrisP/openscad/tests/test_pretty_print.py" > --builddir=C:/msys64/home/ChrisP/openscad/tests > Problem executing post-test command(s). > Errors while running CTest > > This test has always failed for me but this change > <https://github.com/openscad/openscad/commit/43c96c2b0b973cd58f9e0e85991a9bb1702c139d#diff-a8e90a51a93dfe54df9171c2cc591550> > now makes the test system fail. I assume that the console output from > OpenSCAD is not utf-8 encoded in this environment but I don't really know > what the correct solution is. > >
Sat, Aug 25, 2018 12:55 PM
Python2?
I don't know if all the build environments that are in use
will support Python3. So Python2 support might still be
needed at this point.
I guess going forward by getting rid of Python2 is the
better option. Making the MSYS2 env work with Python3 would
be a step into that direction.
We don't have any automated builds for MSYS2, so issues
tend to be detected late. Are there any CI providers that
would allow running MSYS2 builds?
On 08/25/2018 01:06 PM, nop head wrote: > So it looks like since I last used it mods have been made to > make it Python3 compatible. Is it still supposed to work on > Python2? > I don't know if all the build environments that are in use will support Python3. So Python2 support might still be needed at this point. I guess going forward by getting rid of Python2 is the better option. Making the MSYS2 env work with Python3 would be a step into that direction. We don't have any automated builds for MSYS2, so issues tend to be detected late. Are there any CI providers that would allow running MSYS2 builds? ciao, Torsten.
Wed, Aug 29, 2018 10:58 AM
So I played around with this for a few days and came to the conclusion it
isn't practical to make the same code work on Python2 and Python3 once
unicode with non ascii characters is involved.
The way to do it in Python2 is with 8 bit str strings. The program then
doesn't care about encoding, it just handles 8 bits transparently. The OS
handles which characters the 8 bit codes represent. That all works fine
with Western languages as long we all sing from the same codepage. It
doesn't work well if you want more than one language at the same time or
more than 256 glyphs.
Python3 strings are unicode and it seems to automatically promote the args
from the OS encoding and be able to print unicode, automatically doing the
output encoding to match the output device.
In Python2 the args come in in latin1 and need to be presented to the
subprocess in latin1. This presumable is platform and language dependent.
You can reliably print unicode without encoding it to bytes but if you do
that in Python3 it prints the b" prefix. So the only way to make a program
work on both is with lots of conditional code, which is ugly and not easy
to maintain.
I took the plunge and updated my MSYS2 to Python3 with pacman -S python3.
The only issue with that is it installs it to /usr/bin but Python2 is in
/mingw64/bin and that is higher in the search order. I had to manually nuke
Python2, I don't know if there is a better way to do it.
After upgrading I found some bugs in test_pretty_print.py that I don't
think are anything to do with my platform. I have submitted a PR to fix
that: https://github.com/openscad/openscad/pull/2467.
Python2?
So I played around with this for a few days and came to the conclusion it isn't practical to make the same code work on Python2 and Python3 once unicode with non ascii characters is involved. The way to do it in Python2 is with 8 bit str strings. The program then doesn't care about encoding, it just handles 8 bits transparently. The OS handles which characters the 8 bit codes represent. That all works fine with Western languages as long we all sing from the same codepage. It doesn't work well if you want more than one language at the same time or more than 256 glyphs. Python3 strings are unicode and it seems to automatically promote the args from the OS encoding and be able to print unicode, automatically doing the output encoding to match the output device. In Python2 the args come in in latin1 and need to be presented to the subprocess in latin1. This presumable is platform and language dependent. You can reliably print unicode without encoding it to bytes but if you do that in Python3 it prints the b" prefix. So the only way to make a program work on both is with lots of conditional code, which is ugly and not easy to maintain. I took the plunge and updated my MSYS2 to Python3 with pacman -S python3. The only issue with that is it installs it to /usr/bin but Python2 is in /mingw64/bin and that is higher in the search order. I had to manually nuke Python2, I don't know if there is a better way to do it. After upgrading I found some bugs in test_pretty_print.py that I don't think are anything to do with my platform. I have submitted a PR to fix that: https://github.com/openscad/openscad/pull/2467. On 25 August 2018 at 13:55, Torsten Paul <Torsten.Paul@gmx.de> wrote: > On 08/25/2018 01:06 PM, nop head wrote: > >> So it looks like since I last used it mods have been made to >> make it Python3 compatible. Is it still supposed to work on >> Python2? >> >> I don't know if all the build environments that are in use > will support Python3. So Python2 support might still be > needed at this point. > > I guess going forward by getting rid of Python2 is the > better option. Making the MSYS2 env work with Python3 would > be a step into that direction. > > We don't have any automated builds for MSYS2, so issues > tend to be detected late. Are there any CI providers that > would allow running MSYS2 builds? > > ciao, > Torsten. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Wed, Aug 29, 2018 11:00 AM
4th paragraph should say "You can't reliably print unicode without
encoding it to bytes"
to maintain.
Python2?
4th paragraph should say "You *can't* reliably print unicode without encoding it to bytes" On 29 August 2018 at 11:58, nop head <nop.head@gmail.com> wrote: > So I played around with this for a few days and came to the conclusion it > isn't practical to make the same code work on Python2 and Python3 once > unicode with non ascii characters is involved. > > The way to do it in Python2 is with 8 bit str strings. The program then > doesn't care about encoding, it just handles 8 bits transparently. The OS > handles which characters the 8 bit codes represent. That all works fine > with Western languages as long we all sing from the same codepage. It > doesn't work well if you want more than one language at the same time or > more than 256 glyphs. > > Python3 strings are unicode and it seems to automatically promote the args > from the OS encoding and be able to print unicode, automatically doing the > output encoding to match the output device. > > In Python2 the args come in in latin1 and need to be presented to the > subprocess in latin1. This presumable is platform and language dependent. > You can reliably print unicode without encoding it to bytes but if you do > that in Python3 it prints the b" prefix. So the only way to make a program > work on both is with lots of conditional code, which is ugly and not easy > to maintain. > > I took the plunge and updated my MSYS2 to Python3 with pacman -S python3. > The only issue with that is it installs it to /usr/bin but Python2 is in > /mingw64/bin and that is higher in the search order. I had to manually nuke > Python2, I don't know if there is a better way to do it. > > After upgrading I found some bugs in test_pretty_print.py that I don't > think are anything to do with my platform. I have submitted a PR to fix > that: https://github.com/openscad/openscad/pull/2467. > > > > > > > On 25 August 2018 at 13:55, Torsten Paul <Torsten.Paul@gmx.de> wrote: > >> On 08/25/2018 01:06 PM, nop head wrote: >> >>> So it looks like since I last used it mods have been made to >>> make it Python3 compatible. Is it still supposed to work on >>> Python2? >>> >>> I don't know if all the build environments that are in use >> will support Python3. So Python2 support might still be >> needed at this point. >> >> I guess going forward by getting rid of Python2 is the >> better option. Making the MSYS2 env work with Python3 would >> be a step into that direction. >> >> We don't have any automated builds for MSYS2, so issues >> tend to be detected late. Are there any CI providers that >> would allow running MSYS2 builds? >> >> ciao, >> Torsten. >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > >
