which formats does OpenSCAD support?
CB
c.buhtz@posteo.jp
Sun, Jan 24, 2016 11:19 AM
I am interested in that model
http://www.3dcontentcentral.de/secure/download-model.aspx?catalogid=171&id=587075.
The download section offers a lot of file formates but nothing like
"OpenSCAD". So I think about which one I should use here to reuse that
model in OpenSCAD.
I don't want to modify it. I just want to use it as a placeholder to
build my own model around it.
thank you for help
GnuPGP-Key ID 0751A8EC
Hi, I am interested in that model <http://www.3dcontentcentral.de/secure/download-model.aspx?catalogid=171&id=587075>. The download section offers a lot of file formates but nothing like "OpenSCAD". So I think about which one I should use here to reuse that model in OpenSCAD. I don't want to modify it. I just want to use it as a placeholder to build my own model around it. thank you for help -- GnuPGP-Key ID 0751A8EC
F
fred
Sun, Jan 24, 2016 11:29 AM
If one of the formats is .STL, there is an STL to OpenSCAD converter or two on Thingiverse. The output is a series of joined polygons, a huge amount of code for the more complex models, but it may do as you need.
On Sunday, January 24, 2016 6:21 AM, "c.buhtz@posteo.jp" <c.buhtz@posteo.jp> wrote:
model in OpenSCAD.
thank you for help
If one of the formats is .STL, there is an STL to OpenSCAD converter or two on Thingiverse. The output is a series of joined polygons, a huge amount of code for the more complex models, but it may do as you need. On Sunday, January 24, 2016 6:21 AM, "c.buhtz@posteo.jp" <c.buhtz@posteo.jp> wrote: Hi, I am interested in that model <http://www.3dcontentcentral.de/secure/download-model.aspx?catalogid=171&id=587075>. The download section offers a lot of file formates but nothing like "OpenSCAD". So I think about which one I should use here to reuse that model in OpenSCAD. I don't want to modify it. I just want to use it as a placeholder to build my own model around it. thank you for help -- GnuPGP-Key ID 0751A8EC _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Sun, Jan 24, 2016 11:54 AM
STL is the only 3D format you can import into OpenScad.
model in OpenSCAD.
thank you for help
STL is the only 3D format you can import into OpenScad. On 24 January 2016 at 11:19, <c.buhtz@posteo.jp> wrote: > Hi, > I am interested in that model > < > http://www.3dcontentcentral.de/secure/download-model.aspx?catalogid=171&id=587075 > >. > > The download section offers a lot of file formates but nothing like > "OpenSCAD". So I think about which one I should use here to reuse that > model in OpenSCAD. > > I don't want to modify it. I just want to use it as a placeholder to > build my own model around it. > > thank you for help > -- > GnuPGP-Key ID 0751A8EC > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
YA
Yona Appletree
Sun, Jan 24, 2016 7:29 PM
FreeCAD can be very useful in cases like this. You can import most
formats into it, use it to simplify things, and then export as STL for
importing into OpenSCAD.
nop head mailto:nop.head@gmail.com
January 24, 2016 at 03:54
c.buhtz@posteo.jp mailto:c.buhtz@posteo.jp
January 24, 2016 at 03:19
model in OpenSCAD.
thank you for help
FreeCAD can be very useful in cases like this. You can import most formats into it, use it to simplify things, and then export as STL for importing into OpenSCAD. > nop head <mailto:nop.head@gmail.com> > January 24, 2016 at 03:54 > STL is the only 3D format you can import into OpenScad. > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > c.buhtz@posteo.jp <mailto:c.buhtz@posteo.jp> > January 24, 2016 at 03:19 > Hi, > I am interested in that model > <http://www.3dcontentcentral.de/secure/download-model.aspx?catalogid=171&id=587075>. > > The download section offers a lot of file formates but nothing like > "OpenSCAD". So I think about which one I should use here to reuse that > model in OpenSCAD. > > I don't want to modify it. I just want to use it as a placeholder to > build my own model around it. > > thank you for help > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
