Re: mistake
D
dpa
Thu, Oct 28, 2021 9:15 AM
this is just a glitch in the viewer. If you render it it's gone.
Am Do., 28. Okt. 2021 um 10:56 Uhr schrieb André Lefranc via Discuss <
discuss@lists.openscad.org>:
Cc:
Bcc:
Date: Thu, 28 Oct 2021 10:56:09 +0200
Subject: [OpenSCAD] Re: mistake
Thanks,  $fn=20; is good idea to have a speed vision..
if you get an screen, whithout visserie, vue générale, réparation  ( all=
"N")
you can have a better view of mystake...
Le 28/10/2021 à 10:40, dpa a écrit :
there was no definition for ContreAlesage() and alesage(). So I commented
this out.
Then I found that you drive "minkowski()", with $fn=120 which is pretty
much (regarding the extremely expensive algorithm). I got initially (on
macOS) a never ending spinning ball. I reduced it to $fn=20 and then it
(attached) worked like that:
[image: Bildschirmfoto 2021-10-28 um 10.34.27.png]
Am Do., 28. Okt. 2021 um 09:56 Uhr schrieb André Lefranc via Discuss <
To: OpenSCAD general discussion Discuss@lists.openscad.org
Cc:
Bcc:
Date: Thu, 28 Oct 2021 09:55:48 +0200
Subject: [OpenSCAD] mistake
hello, I don't understand where is the mystake .
on my computer this file make an white circle ... the mystake is in
module "affichage"
My apologise for my porr english language.
for your information it's a design for ETX 125 telescope.
DiamOTA =127;
visserie ="Y";//[Y: Présentation visserie fixation, N: pas d'affichage]
VueGenerale ="Y";//[Y: Présentation générale , N: pas d'affichage]
reparation ="Y"; //[Y: Présentation réparation , N: pas d'affichage]
// écartement
dec=1;//[1:5:30]
module tube ()
color ("Purple")
translate ([0,DiamOTA/2,0])
cylinder (r=DiamOTA/2, h=DiamOTA2,$fn=60);
// couvercle aliminium du tube
color ("Azure")
translate ([0,DiamOTA/2,1+DiamOTA
2])
cylinder (r=DiamOTA/2, h=3,$fn=60);
//end of tube ();
module  coqueBras ()
color ("LightBlue")
minkowski ()
$fn=120;
union ()
translate ([0,8,75        ])
cube ([50-10,30,70], center=true);
translate ([0,8,105        ])
rotate ([90,0,0])
cylinder (r=DiamOTA/5, h=50,$fn=120,center=true);
sphere (5);
                                             //ContreCoqueBras ();
module  ContreCoqueBras ()
color ("SkyBlue")
union ()
cube ([50-4,30,75], center=true);
translate ([0,-1,105        ])
rotate ([90,0,0])
cylinder (r=(DiamOTA/5)+3, h=35,$fn=120,center=true);
module affichage ()
{difference ()
coqueBras ();
union ()
ContreCoqueBras ();
alesage () ;
tube();
difference () {
color ("red")
ContreAlesage ();
alesage () ;
if (VueGenerale =="Y")
translate ([0,DiamOTA,0])
rotate ([0,0,180])
mirror ([1,0,0])
difference ()
coqueBras ();
union ()
ContreCoqueBras ();
alesage () ;
tube();
difference ()
color ("red")
ContreAlesage ();
alesage () ;
tube ();
affichage () ;
From: "André Lefranc via Discuss" discuss@lists.openscad.org
Cc: "André Lefranc" a.lefranc@laposte.net
Bcc:
Bcc:
this is just a glitch in the viewer. If you render it it's gone. Am Do., 28. Okt. 2021 um 10:56 Uhr schrieb André Lefranc via Discuss < discuss@lists.openscad.org>: > > > > ---------- Forwarded message ---------- > From: "André Lefranc" <a.lefranc@laposte.net> > To: discuss@lists.openscad.org > Cc: > Bcc: > Date: Thu, 28 Oct 2021 10:56:09 +0200 > Subject: [OpenSCAD] Re: mistake > > Thanks, $fn=20; is good idea to have a speed vision.. > > if you get an screen, whithout visserie, vue générale, réparation ( all= > "N") > > you can have a better view of mystake... > Le 28/10/2021 à 10:40, dpa a écrit : > > there was no definition for ContreAlesage() and alesage(). So I commented > this out. > > Then I found that you drive "minkowski()", with $fn=120 which is pretty > much (regarding the extremely expensive algorithm). I got initially (on > macOS) a never ending spinning ball. I reduced it to $fn=20 and then it > (attached) worked like that: > [image: Bildschirmfoto 2021-10-28 um 10.34.27.png] > > Am Do., 28. Okt. 2021 um 09:56 Uhr schrieb André Lefranc via Discuss < > discuss@lists.openscad.org>: > >> >> >> >> ---------- Forwarded message ---------- >> From: "André Lefranc" <a.lefranc@laposte.net> >> To: OpenSCAD general discussion <Discuss@lists.openscad.org> >> Cc: >> Bcc: >> Date: Thu, 28 Oct 2021 09:55:48 +0200 >> Subject: [OpenSCAD] mistake >> >> *hello, I don't understand where is the mystake .* >> >> >> *on my computer this file make an white circle ... the mystake is in >> module "affichage"* >> >> *My apologise for my porr english language.* >> >> *for your information it's a design for ETX 125 telescope.* >> >> DiamOTA =127; >> visserie ="Y";//[Y: Présentation visserie fixation, N: pas d'affichage] >> VueGenerale ="Y";//[Y: Présentation générale , N: pas d'affichage] >> reparation ="Y"; //[Y: Présentation réparation , N: pas d'affichage] >> // écartement >> dec=1;//[1:5:30] >> module tube () >> { >> color ("Purple") >> translate ([0,DiamOTA/2,0]) >> cylinder (r=DiamOTA/2, h=DiamOTA*2,$fn=60); >> // couvercle aliminium du tube >> color ("Azure") >> translate ([0,DiamOTA/2,1+DiamOTA*2]) >> cylinder (r=DiamOTA/2, h=3,$fn=60); >> } >> //end of tube (); >> module coqueBras () >> { >> color ("LightBlue") >> minkowski () >> { >> $fn=120; >> union () >> { >> translate ([0,8,75 ]) >> cube ([50-10,30,70], center=true); >> translate ([0,8,105 ]) >> rotate ([90,0,0]) >> cylinder (r=DiamOTA/5, h=50,$fn=120,center=true); >> } >> sphere (5); >> } >> } >> >> //ContreCoqueBras (); >> module ContreCoqueBras () >> { >> color ("SkyBlue") >> union () >> { >> translate ([0,8,75 ]) >> cube ([50-4,30,75], center=true); >> translate ([0,-1,105 ]) >> rotate ([90,0,0]) >> cylinder (r=(DiamOTA/5)+3, h=35,$fn=120,center=true); >> } >> } >> >> >> module affichage () >> {difference () >> { >> coqueBras (); >> union () >> { >> ContreCoqueBras (); >> alesage () ; >> tube(); >> } >> >> } >> difference () { >> color ("red") >> ContreAlesage (); >> alesage () ; >> >> } >> if (VueGenerale =="Y") >> { >> translate ([0,DiamOTA,0]) >> rotate ([0,0,180]) >> mirror ([1,0,0]) >> { >> difference () >> { >> coqueBras (); >> union () >> { >> ContreCoqueBras (); >> alesage () ; >> tube(); >> } >> } >> difference () >> { >> color ("red") >> ContreAlesage (); >> alesage () ; >> } >> } >> tube (); >> } >> } >> affichage () ; >> >> >> >> ---------- Forwarded message ---------- >> From: "André Lefranc via Discuss" <discuss@lists.openscad.org> >> To: OpenSCAD general discussion <Discuss@lists.openscad.org> >> Cc: "André Lefranc" <a.lefranc@laposte.net> >> Bcc: >> Date: Thu, 28 Oct 2021 09:55:48 +0200 >> Subject: [OpenSCAD] mistake >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > > > ---------- Forwarded message ---------- > From: "André Lefranc via Discuss" <discuss@lists.openscad.org> > To: discuss@lists.openscad.org > Cc: "André Lefranc" <a.lefranc@laposte.net> > Bcc: > Date: Thu, 28 Oct 2021 10:56:09 +0200 > Subject: [OpenSCAD] Re: mistake > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
AL
André Lefranc
Thu, Oct 28, 2021 10:15 AM
Yes,  Thanks !
discuss@lists.openscad.org:
 Cc:
 Bcc:
 ( all= "N")
 commented this out.
 pretty much (regarding the extremely expensive algorithm). I got
 initially (on macOS) a never ending spinning ball. I reduced it
 to $fn=20 and then it (attached) worked like that:
 Discuss <discuss@lists.openscad.org>:
     Cc:
     Bcc:
     /hello, I don't understand where is the mystake ./
     /on my computer this file make an white circle ...
     the mystake is in module "*affichage*"/
     /My apologise for my porr english language./
     /for your information it's a design for ETX 125 telescope./
     DiamOTA =127;
     d'affichage]
     d'affichage]
     d'affichage]
     // écartement
     dec=1;//[1:5:30]
     module tube ()
             color ("Purple")
         color ("Azure")
             //end of tube ();
      module  coqueBras ()
         color ("LightBlue")
         minkowski ()
             $fn=120;
             union ()
             rotate ([90,0,0])
             sphere (5);
     color ("SkyBlue")
                 union ()
             rotate ([90,0,0])
     module affichage ()
     {difference ()
         coqueBras ();
         union ()
         ContreCoqueBras ();
         alesage () ;
         tube();
     difference () {
     color ("red")
             ContreAlesage ();
             alesage () ;
     rotate ([0,0,180])
     mirror ([1,0,0])
         difference ()
         coqueBras ();
         union ()
             ContreCoqueBras ();
         alesage () ;
         tube();
         difference ()
                 color ("red")
                 ContreAlesage ();
                 alesage () ;
             tube ();
     affichage () ;
     Bcc:
 Bcc:
Yes,  Thanks ! Le 28/10/2021 à 11:15, dpa a écrit : > this is just a glitch in the viewer. If you render it it's gone. > > Am Do., 28. Okt. 2021 um 10:56 Uhr schrieb André Lefranc via Discuss > <discuss@lists.openscad.org>: > > > > > ---------- Forwarded message ---------- > From: "André Lefranc" <a.lefranc@laposte.net> > To: discuss@lists.openscad.org > Cc: > Bcc: > Date: Thu, 28 Oct 2021 10:56:09 +0200 > Subject: [OpenSCAD] Re: mistake > > Thanks,  $fn=20; is good idea to have a speed vision.. > > if you get an screen, whithout visserie, vue générale, réparation  > ( all= "N") > > you can have a better view of mystake... > > Le 28/10/2021 à 10:40, dpa a écrit : >> there was no definition for ContreAlesage() and alesage(). So I >> commented this out. >> >> Then I found that you drive "minkowski()", with $fn=120 which is >> pretty much (regarding the extremely expensive algorithm). I got >> initially (on macOS) a never ending spinning ball. I reduced it >> to $fn=20 and then it (attached) worked like that: >> >> >> Am Do., 28. Okt. 2021 um 09:56 Uhr schrieb André Lefranc via >> Discuss <discuss@lists.openscad.org>: >> >> >> >> >> ---------- Forwarded message ---------- >> From: "André Lefranc" <a.lefranc@laposte.net> >> To: OpenSCAD general discussion <Discuss@lists.openscad.org> >> Cc: >> Bcc: >> Date: Thu, 28 Oct 2021 09:55:48 +0200 >> Subject: [OpenSCAD] mistake >> >> /hello, I don't understand where is the mystake ./ >> >> /on my computer this file make an white circle ... >> the mystake is in module "*affichage*"/ >> >> /My apologise for my porr english language./ >> >> /for your information it's a design for ETX 125 telescope./ >> >> DiamOTA =127; >> visserie ="Y";//[Y: Présentation visserie fixation, N: pas >> d'affichage] >> VueGenerale ="Y";//[Y: Présentation générale , N: pas >> d'affichage] >> reparation ="Y"; //[Y: Présentation réparation , N: pas >> d'affichage] >> // écartement >> dec=1;//[1:5:30] >> module tube () >> { >>         color ("Purple") >> translate ([0,DiamOTA/2,0]) >> cylinder (r=DiamOTA/2, h=DiamOTA*2,$fn=60); >> // couvercle aliminium du tube >>     color ("Azure") >> translate ([0,DiamOTA/2,1+DiamOTA*2]) >> cylinder (r=DiamOTA/2, h=3,$fn=60); >> } >>         //end of tube (); >>  module  coqueBras () >> { >>     color ("LightBlue") >>     minkowski () >>         { >>         $fn=120; >>         union () >>                             { >>         translate ([0,8,75        ]) >>         cube ([50-10,30,70], center=true); >>         translate ([0,8,105        ]) >>         rotate ([90,0,0]) >>     cylinder (r=DiamOTA/5, h=50,$fn=120,center=true); >>                             } >>         sphere (5); >>         } >> } >> >> //ContreCoqueBras (); >> module  ContreCoqueBras () >> { >> color ("SkyBlue") >>             union () >>         { >>         translate ([0,8,75        ]) >>         cube ([50-4,30,75], center=true); >>         translate ([0,-1,105        ]) >>         rotate ([90,0,0]) >>     cylinder (r=(DiamOTA/5)+3, h=35,$fn=120,center=true); >>         } >> } >> >> >> module affichage () >> {difference () >>             { >>     coqueBras (); >>     union () >>             { >>     ContreCoqueBras (); >>     alesage () ; >>     tube(); >>             } >> >>                 } >> difference () { >> color ("red") >>         ContreAlesage (); >>         alesage () ; >> >>                     } >> if (VueGenerale =="Y") >>     { >> translate ([0,DiamOTA,0]) >> rotate ([0,0,180]) >> mirror ([1,0,0]) >>         { >>     difference () >>                                 { >>     coqueBras (); >>     union () >>                         { >>         ContreCoqueBras (); >>     alesage () ; >>     tube(); >>                         } >>                                 } >>     difference () >>                     { >>             color ("red") >>             ContreAlesage (); >>             alesage () ; >>                     } >>         } >>         tube (); >>     } >> } >> affichage () ; >> >> >> >> >> ---------- Forwarded message ---------- >> From: "André Lefranc via Discuss" <discuss@lists.openscad.org> >> To: OpenSCAD general discussion <Discuss@lists.openscad.org> >> Cc: "André Lefranc" <a.lefranc@laposte.net> >> Bcc: >> Date: Thu, 28 Oct 2021 09:55:48 +0200 >> Subject: [OpenSCAD] mistake >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> >> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email todiscuss-leave@lists.openscad.org > > > > ---------- Forwarded message ---------- > From: "André Lefranc via Discuss" <discuss@lists.openscad.org> > To: discuss@lists.openscad.org > Cc: "André Lefranc" <a.lefranc@laposte.net> > Bcc: > Date: Thu, 28 Oct 2021 10:56:09 +0200 > Subject: [OpenSCAD] Re: mistake > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org
