Mirror, linear_extrude and importing an stl
B
bedders
Sun, Oct 30, 2016 11:18 AM
Using the following code I've generated an stl, but if I import it along with
another stl, it displays with F5, but doesn't with F6. If I comment out the
mirror([0,0,m]) line, it displays in both. I'm using 2015.03
translate([-1.25,-25.375,0])
cube([5,11,89],center=true);
for(m=[0,1])
mirror([0,0,m])
translate([0.75,-30.75,14])
linear_extrude(height=4, center=true)
polygon(points= [
[0,0],
[0,48],
[0.5,48],
[3.5,47.5],
[4.5,28],
[4.5,0]
View this message in context: http://forum.openscad.org/Mirror-linear-extrude-and-importing-an-stl-tp18825.html
Using the following code I've generated an stl, but if I import it along with another stl, it displays with F5, but doesn't with F6. If I comment out the mirror([0,0,m]) line, it displays in both. I'm using 2015.03 translate([-1.25,-25.375,0]) cube([5,11,89],center=true); for(m=[0,1]) { mirror([0,0,m]) { translate([0.75,-30.75,14]) { linear_extrude(height=4, center=true) polygon(points= [ [0,0], [0,48], [0.5,48], [3.5,47.5], [4.5,28], [4.5,0] ]); } } } -- View this message in context: http://forum.openscad.org/Mirror-linear-extrude-and-importing-an-stl-tp18825.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Ronaldo
Sun, Oct 30, 2016 2:01 PM
I could not see anything wrong or inappropriate with your code (although I
would never use mirror([0,0,0])). It seems to be a bug in the stl
generation. I could generate a corrected stl by unifying duplicated vertices
with Meshlab.
View this message in context: http://forum.openscad.org/Mirror-linear-extrude-and-importing-an-stl-tp18825p18828.html
I could not see anything wrong or inappropriate with your code (although I would never use mirror([0,0,0])). It seems to be a bug in the stl generation. I could generate a corrected stl by unifying duplicated vertices with Meshlab. -- View this message in context: http://forum.openscad.org/Mirror-linear-extrude-and-importing-an-stl-tp18825p18828.html Sent from the OpenSCAD mailing list archive at Nabble.com.
RB
Richard Bedwell
Mon, Oct 31, 2016 9:10 AM
That doesn't seem to work for me, though I'm not very experienced with meshlab.  I've played about with the issue.
  1. issue exists if mirror is replaced by translate
  2. issue goes away if the intersecting cube is split into 2 separate cubes - as long as they don't touch or overlap.
From: Discuss discuss-bounces@lists.openscad.org on behalf of Ronaldo rcmpersiano@gmail.com
Sent: 30 October 2016 14:01:07
Subject: Re: [OpenSCAD] Mirror, linear_extrude and importing an stl
with Meshlab.
That doesn't seem to work for me, though I'm not very experienced with meshlab. I've played about with the issue. 1) issue exists if mirror is replaced by translate 2) issue goes away if the intersecting cube is split into 2 separate cubes - as long as they don't touch or overlap. ________________________________ From: Discuss <discuss-bounces@lists.openscad.org> on behalf of Ronaldo <rcmpersiano@gmail.com> Sent: 30 October 2016 14:01:07 To: discuss@lists.openscad.org Subject: Re: [OpenSCAD] Mirror, linear_extrude and importing an stl I could not see anything wrong or inappropriate with your code (although I would never use mirror([0,0,0])). It seems to be a bug in the stl generation. I could generate a corrected stl by unifying duplicated vertices with Meshlab. -- View this message in context: http://forum.openscad.org/Mirror-linear-extrude-and-importing-an-stl-tp18825p18828.html Sent from the OpenSCAD mailing list archive at Nabble.com. _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Mon, Oct 31, 2016 1:37 PM
This is definitively a bug. If you insert a translate([0,dy,0]) just before
the linear_extrude of your code, the issue is observed just for dy between
0 and 0.5.
2016-10-31 7:10 GMT-02:00 Richard Bedwell richard_bedwell@hotmail.com:
  • as long as they don't touch or overlap.
vertices
with Meshlab.
This is definitively a bug. If you insert a translate([0,dy,0]) just before the linear_extrude of your code, the issue is observed just for dy between 0 and 0.5. 2016-10-31 7:10 GMT-02:00 Richard Bedwell <richard_bedwell@hotmail.com>: > That doesn't seem to work for me, though I'm not very experienced with > meshlab. I've played about with the issue. > > > 1) issue exists if mirror is replaced by translate > > 2) issue goes away if the intersecting cube is split into 2 separate cubes > - as long as they don't touch or overlap. > > > ------------------------------ > *From:* Discuss <discuss-bounces@lists.openscad.org> on behalf of Ronaldo > <rcmpersiano@gmail.com> > *Sent:* 30 October 2016 14:01:07 > *To:* discuss@lists.openscad.org > *Subject:* Re: [OpenSCAD] Mirror, linear_extrude and importing an stl > > I could not see anything wrong or inappropriate with your code (although I > would never use mirror([0,0,0])). It seems to be a bug in the stl > generation. I could generate a corrected stl by unifying duplicated > vertices > with Meshlab. > > > > -- > View this message in context: http://forum.openscad.org/ > Mirror-linear-extrude-and-importing-an-stl-tp18825p18828.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
