is there a way to flush the cached echo statements?
John David
Fri, Feb 28, 2025 3:55 AM
I saw a feature request, but my googling did not come up with anything
obvious.
The issue is that I wasted several days trying to figure out where a
function was dying, and it turned out to be I had a bad argument count, but
if I got into the recursion at all it would go into an infinate loop...
EBo --
I saw a feature request, but my googling did not come up with anything obvious. The issue is that I wasted several days trying to figure out where a function was dying, and it turned out to be I had a bad argument count, but if I got into the recursion at all it would go into an infinate loop... EBo --
Fri, Feb 28, 2025 11:42 AM
Are you saying that you passed the wrong number of arguments to your
function?  That is easily caught if you enable "stop on first warning" in
the preferences.  There are a bunch of "warnings" that are actually fatal
errors and lead to a cascade of messages, so this option is basically
essential.
On Thu, Feb 27, 2025 at 10:56 PM John David via Discuss <
obvious.
EBo --
Are you saying that you passed the wrong number of arguments to your function? That is easily caught if you enable "stop on first warning" in the preferences. There are a bunch of "warnings" that are actually fatal errors and lead to a cascade of messages, so this option is basically essential. On Thu, Feb 27, 2025 at 10:56 PM John David via Discuss < discuss@lists.openscad.org> wrote: > I saw a feature request, but my googling did not come up with anything > obvious. > > The issue is that I wasted several days trying to figure out where a > function was dying, and it turned out to be I had a bad argument count, but > if I got into the recursion at all it would go into an infinate loop... > > EBo -- > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
John David
Fri, Feb 28, 2025 3:22 PM
Thanks.  I will set that.  But it would still be nice to be able to flush
the stdout...
EBo --
On Fri, Feb 28, 2025 at 6:43 AM Adrian Mariano via Discuss <
essential.
obvious.
EBo --
Thanks. I will set that. But it would still be nice to be able to flush the stdout... EBo -- On Fri, Feb 28, 2025 at 6:43 AM Adrian Mariano via Discuss < discuss@lists.openscad.org> wrote: > Are you saying that you passed the wrong number of arguments to your > function? That is easily caught if you enable "stop on first warning" in > the preferences. There are a bunch of "warnings" that are actually fatal > errors and lead to a cascade of messages, so this option is basically > essential. > > On Thu, Feb 27, 2025 at 10:56 PM John David via Discuss < > discuss@lists.openscad.org> wrote: > >> I saw a feature request, but my googling did not come up with anything >> obvious. >> >> The issue is that I wasted several days trying to figure out where a >> function was dying, and it turned out to be I had a bad argument count, but >> if I got into the recursion at all it would go into an infinate loop... >> >> EBo -- >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Fri, Feb 28, 2025 4:21 PM
Something changed a few years ago, and I haven't bothered to track down
what.  It used to be that output was visible immediately.
Something changed a few years ago, and I haven't bothered to track down what.  It used to be that output was visible immediately.
