JW
Joe Weinpert
Sat, Apr 2, 2022 1:00 AM
An STL file is imported, previewed, and rendered without a problem but
when I import it twice, offsetting the 2nd one to add to the first one
(just a duplicated pattern) then the error pops up when rendering.
Why can I render when it is only imported once?
violation! Expr: e_below != SHalfedge_handle() File:
/mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_3/SNC_FM_decorator.h
Line: 426
Line: 426
Sat, Apr 2, 2022 2:29 AM
but when I import it twice, offsetting the 2nd one to add to the
first one (just a duplicated pattern) then the error pops up when
rendering.
As a general rule, a single import or a single polyhedron() will never
get an error like this, because if there's only just that one object
then it's not necessary to run the fancy processing over it.
You'll probably find that you'll get an error no matter what the second
object is - even a lowly cube().
I think we'd be better off if we forced that processing, so that a
single malformed object would get the error. I don't know how hard that
would be.
> rendering.
Your STL is malformed.
would be.
JW
Joe Weinpert
Sat, Apr 2, 2022 3:36 AM
As a general rule, a single import or a single polyhedron() will never get
an error like this, because if there's only just that one object then it's
I think we'd be better off if we forced that processing, so that a single
malformed object would get the error. I don't know how hard that would be.
Ok, thanks.
On Fri, Apr 1, 2022 at 10:29 PM Jordan Brown <openscad@jordan.maileater.net>
Sat, Apr 2, 2022 10:41 AM
"I think we'd be better off if we forced that processing, so that a
single malformed object would get the error."
I agree with Jordan. We see a lot of these crop up with users who
import STLs for the first time.
rendering.
second object is - even a lowly cube().
that would be.
>> rendering.
> that would be.
Sat, Apr 2, 2022 12:10 PM
I think it should be a warning message, and one that is persistent until
the object is corrected. the message should be visible every time you
do an f5 or f6. If the software knows there is an error, would it also
know what the error is and where it is? Even with a malformed stl, you
can still scale it in openscad, whereas I believe an error message
allows nothing until the error is corrected.
rendering.
never get an error like this, because if there's only just that one
object then it's not necessary to run the fancy processing over it.
that would be.
>>> rendering.
>> that would be.
Sat, Apr 2, 2022 1:42 PM
On Sat, Apr 02, 2022 at 06:41:29AM -0400, jon wrote:
"I think we'd be better off if we forced that processing, so that a single
I agree with Jordan. We see a lot of these crop up with users who import
We see lots of broken STLs that get accepted in other programs.
Would it be an idea to add a simple filter?
for all points:
after snapping-to-grid:
If it is a duplcate:
note that vertex-X maps to vertex-Y.
For all triangles:
if a vertex-reference
refers to a vertex on the duplicates list, use the linked vertex.
if a triangle has two the same vertex references: remove it.
This solves only one of the possible problems with an STL.
Maybe other filters can be added later.
Another option is to allow for an external program to process incoming
STLs. And then to promote using an external STL-fixer in that spot.
rendering.
would be.
1)
for all points:
2) For all triangles:
> > > rendering.
> > would be.
Sat, Apr 2, 2022 1:58 PM
The difficult thing to fix is self-intersections.
for all points:
For all triangles:
rendering.
> single
> 1)
> for all points:
> Roger.
> > > > rendering.
> that
> > > would be.
> ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110
> f equals m times a. When your f is steady, and your m is going down
Sat, Apr 2, 2022 6:05 PM
Interesting side thought: if the geom = render() … changes ever get into mainline, it’d be possible to validate and/or repair imported meshes in user-space. BOSL2 already has the validation code. Would get slow for complex meshes though.
-Revar
On Apr 1, 2022, at 7:29 PM, Jordan Brown openscad@jordan.maileater.net wrote:
An STL file is imported, previewed, and rendered without a problem but when I import it twice, offsetting the 2nd one to add to the first one (just a duplicated pattern) then the error pops up when rendering.
As a general rule, a single import or a single polyhedron() will never get an error like this, because if there's only just that one object then it's not necessary to run the fancy processing over it.
You'll probably find that you'll get an error no matter what the second object is - even a lowly cube().
I think we'd be better off if we forced that processing, so that a single malformed object would get the error. I don't know how hard that would be.
Interesting side thought: if the `geom = render() …` changes ever get into mainline, it’d be possible to validate and/or repair imported meshes in user-space. BOSL2 already has the validation code. Would get slow for complex meshes though.
-Revar
> On Apr 1, 2022, at 7:29 PM, Jordan Brown <openscad@jordan.maileater.net> wrote:
Sat, Apr 2, 2022 7:22 PM
Yes. So
don't have the ambition to fix them.
maybe later someone can find a simple algorithm.
Maybe that doesn't happen often? What would be the common
STL-error?
for all points:
For all triangles:
rendering.
Yes. So
1) don't have the ambition to fix them.
2) maybe later someone can find a simple algorithm.
3) Maybe that doesn't happen often? What would be the common
STL-error?
> > single
> > 1)
> > for all points:
> > Roger.
> > > > > rendering.
> > that
> > > > would be.
Sat, Apr 2, 2022 8:05 PM
The free Netfabb studio I have will fix holes, degenerate triangles, etc.
You have to pay to fix self intersections though and OpenSCAD will produce
those itself. Most STLs in the wild are broken in my experience.
Yes. So
STL-error?
for all points:
For all triangles:
rendering.
> Yes. So
> STL-error?
> Roger.
> > > single
> import
> > > 1)
> > > for all points:
> vertex.
> > > Roger.
> problem
> > > > > > rendering.
> never
> object
> second
> > > that
> > > > > would be.
> +31-15-2049110
> shuttle.
