hi everybody,
try this code:
difference () {
cube([3,60,60]);
translate([0,30,30])
rotate([0,90,0])
cylinder(r=15,h=3);
You will see that the rotated cylinder is "strange"...
is there a bug in OpenSCAD ?
thanx and congrat for OpenScad, it's a wonderful software !!!
easycure
View this message in context: http://forum.openscad.org/bug-with-rotatie-and-cylinder-tp13001.html
Try
difference () {
cube([3,60,60]);
translate([-0.005,30,30])
rotate([0,90,0])
cylinder(r=15,h=3.01);
You need to think about boundaries.
My $0.02 contribution,
Jean-Paul
AC9GH
On Jul 3, 2015, at 8:22 AM, easycure easycure@easycure.fr wrote:
hi everybody,
try this code:
difference () {
cube([3,60,60]);
rotate([0,90,0])
cylinder(r=15,h=3);
easycure
thanx for your answer, and I don't want to bother you but, what do you mean
about boundaries ? (sorry i'm a noob)
and the problem doesn't occur whitout the rotate function:
difference () {
cube([60,60,3]);
translate([30,30,00])
cylinder(r=15,h=3);
cheers
easycure
View this message in context: http://forum.openscad.org/bug-with-rotate-and-cylinder-tp13001p13004.html
This is a well known problem, which I think is caused by OpenSCAD using
floating point transformation matrices.
Try this as a workaround:
epsilon = 0.01;
difference () {
cube([3,60,60]);
translate([-epsilon,30,30])
rotate([0,90,0])
cylinder(r=15,h=3+2*epsilon);
On 3 July 2015 at 08:22, easycure easycure@easycure.fr wrote:
hi everybody,
try this code:
difference () {
cube([3,60,60]);
rotate([0,90,0])
cylinder(r=15,h=3);
easycure
You expect the end faces of the rotated cylinder to exactly match up with
the faces of the cuboid, but they don't match due to floating point
roundoff in the rotate. So you include a fudge factor, "epsilon", make the
cylinder slightly taller than 3mm, and make sure the cylinder sticks out
past the cuboid faces on both sides.
difference () {
cube([60,60,3]);
cylinder(r=15,h=3);
cheers
easycure
Rotation is done internally using trigonometry. In order for the original
code to work, it would be necessary for sin(90) == 1 and cos(90) == 0. In
the version of OpenSCAD I'm using, cos(90) != 0, so your model doesn't work
as expected.
mean
difference () {
cube([60,60,3]);
cylinder(r=15,h=3);
cheers
easycure
It's just dependent on how the graphics driver does the actual
display. I'm getting this even for
cube(10, center = true);
cylinder(h = 10, r = 4, center = true);
No transformation involved at all, just the difference painting
triangles of different color in one plane.
See https://en.wikipedia.org/wiki/Z-fighting
Hi Torsten. You are reporting an F5 bug, whereas I was analyzing an F6 bug.
I think they are two different issues. I can reproduce both.
I think Easycure was also using F6, since his problem goes away with no
rotation.
an F6 bug. I think they are two different issues. I can reproduce both.
Right, there was never said what to look at exactly, so I stopped
at the first issue I saw.
Hmm, there's code trying to handle sin() and cos() special cases but
that's not active for rotation(). I guess it's worth a try to catch
those too.
In the meantime you can clean up the picture by have the cylinder protrude
beyond the the cube on both sides.
difference () {
cube([3,60,60]);
translate([-1,30,30])
rotate([0,90,0])
cylinder(r=15,h=5);
Just as you would do if making the hole with you drill press, going past to
make a clean hole.
View this message in context: http://forum.openscad.org/bug-with-rotate-and-cylinder-tp13001p13044.html
