Hello,
Say we import an .SVG file containing a single curved line.
Is there some way to get a y position for any x?
The idea is to use a .svg as a kind of path to position shapes and solids.
How is the curve defined in the svg?
If it is a path of points, you can look for the X value and get the Y or
find the 2 points between which your target X lies and then do a simple
interpolation.
This means parsing the svg but if it is simple enough, it should not be
too hard. If you want to do a better interpolation then I thnk that you
are into creating a Bezier with more points and figuring how to apply
your X to the formula.
If it is some other definition of a curve likeĀ circle, you can get the
center and radius and calculate the 2 possible Ys
Interesting problem. You might want to explain a bit more about the
application to see if anyone has already solved the larger problem.
Ron
On 2020-06-17 3:52 p.m., amundsen wrote:
Hello,
Ron Wheeler
Artifact Software
438-345-3369
Only way I know to do this is to parse the file yourself, except I don't
think openscad has a read function
On Wed, 17 Jun 2020, 17:03 Ron Wheeler via Discuss, <
interpolation.
too hard. If you want to do a better interpolation then I thnk that you are
into creating a Bezier with more points and figuring how to apply your X to
the formula.
If it is some other definition of a curve like circle, you can get the
Ron
Hello,
Ron Wheeler
Artifact Software
438-345-3369rwheeler@artifact-software.com
Currently it's just a theoretical question but the idea is to draw a curve in
Inkscape and save it into a .svg file then use this curve to position
objects. However in between I've seen there's a library with splines, maybe
it might be a better function. Still parsing some data from an svg might be
of some interest.
Splines sounds a lot easier.
Have you looked at an Inkscape file to see how a simple curve is
represented?
I suspect that the way the curve is defined in Inkscape makes a
difference in how the SVG is structured.
SVG is XML so there are a lot of tools to help in parsing it.
As long as the curve has only direction along the X axis it might not be
too bad.
Ron
of some interest.
Ron Wheeler
Artifact Software
438-345-3369
