Hi,I want to model a curved surface and create a hole in it (around the middle of it)I have the code that should create this, but instead of difference, it seems to combine the objects.
Here is the code:the module curvedBase does create a curved surface and rotate it in the horizontal planethe module main should cut a cylinder from the surface generated by the curved moduleThe result I get are the 2 combined objects, not the difference
Any help is welcomed.
---=======$fn= 360;
w = 40; // width of rectangleh = 2; // height of rectanglel = 90; // length of chord of the curvedh = 4; // delta height of the curve
main();
module main(){ difference(){ curvedBase(); translate([0,20,0]) cylinder( 20,r1=10, d2=20, center=true); }}
module curve(width, height, length, dh) { r = (pow(length/2, 2) + pow(dh, 2))/(2dh); a = 2asin((length/2)/r); translate([-(r -dh), 0, -width/2]) rotate([0, 0, -a/2]) rotate_extrude(angle = a) translate([r, 0, 0]) square(size = [height, width], center = true);}
module curvedBase(){ rotate([0,-90,90]) curve(w, h, l, dh);}
