Font size resetting in editor
LT
Laura Taalman
Thu, Mar 12, 2015 1:34 AM
Hello,
I tend to work with the font size turned up pretty high in the editor.  In
the new release, when I close and then re-open a document the font is reset
to the small size again.  I believe the old behavior was to keep the size
used previously, which I would prefer so I don't have to keep resetting the
font size.
Thank you for releasing all the great features in OpenSCAD 2015.03!
Laura
View this message in context: http://forum.openscad.org/Font-size-resetting-in-editor-tp11976.html
Hello, I tend to work with the font size turned up pretty high in the editor. In the new release, when I close and then re-open a document the font is reset to the small size again. I believe the old behavior was to keep the size used previously, which I would prefer so I don't have to keep resetting the font size. Thank you for releasing all the great features in OpenSCAD 2015.03! Laura -- View this message in context: http://forum.openscad.org/Font-size-resetting-in-editor-tp11976.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Mar 12, 2015 3:57 AM
It should remember the font size and it does so here.
Which OS are you on?
Could you describe a step-by-step recipe for how to reproduce this?
On Mar 11, 2015, at 21:34 PM, Laura Taalman <laurataalman@gmail.com> wrote: > In the new release, when I close and then re-open a document the font is reset > to the small size again. It should remember the font size and it does so here. Which OS are you on? Could you describe a step-by-step recipe for how to reproduce this? -Marius
LT
Laura Taalman
Thu, Mar 12, 2015 4:33 AM
I'm using three computers, but the one here at home is running OS 10.9.5.
Step-by-step is:
  • working in file, font is very tiny
  • increase font size by pressing command-shift-plus a few times
  • work in file, save file
  • quit OpenSCAD
  • reopen OpenSCAD
  • open the same file (either from the recent files list or by pressing
    "Open" and then navigating to file)
  • file opens but in very tiny font again
Thanks for asking :)
Laura/mathgrrl
On Wed, Mar 11, 2015 at 11:58 PM, kintel [via OpenSCAD] <
ml-node+s1091067n11977h83@n5.nabble.com> wrote:
On Mar 11, 2015, at 21:34 PM, Laura Taalman <[hidden email]
reset
[hidden email] http:///user/SendEmail.jtp?type=node&node=11977&i=1
below:
http://forum.openscad.org/Font-size-resetting-in-editor-tp11976p11977.html
To unsubscribe from Font size resetting in editor, click here
http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=11976&code=bGF1cmF0YWFsbWFuQGdtYWlsLmNvbXwxMTk3NnwtMjA3OTc2OTAzMg==
NAML
Dr. Laura Taalman
JMU Mathematics Department
educ.jmu.edu/~taalmala
www.mathgrrl.com/hacktastic
@mathgrrl http://www.twitter.com/mathgrrl
View this message in context: http://forum.openscad.org/Font-size-resetting-in-editor-tp11976p11978.html
I'm using three computers, but the one here at home is running OS 10.9.5. Step-by-step is: * working in file, font is very tiny * increase font size by pressing command-shift-plus a few times * work in file, save file * quit OpenSCAD * reopen OpenSCAD * open the same file (either from the recent files list or by pressing "Open" and then navigating to file) * file opens but in very tiny font again Thanks for asking :) Laura/mathgrrl On Wed, Mar 11, 2015 at 11:58 PM, kintel [via OpenSCAD] < ml-node+s1091067n11977h83@n5.nabble.com> wrote: > On Mar 11, 2015, at 21:34 PM, Laura Taalman <[hidden email] > <http:///user/SendEmail.jtp?type=node&node=11977&i=0>> wrote: > > > In the new release, when I close and then re-open a document the font is > reset > > to the small size again. > > It should remember the font size and it does so here. > Which OS are you on? > Could you describe a step-by-step recipe for how to reproduce this? > > -Marius > > > _______________________________________________ > OpenSCAD mailing list > [hidden email] <http:///user/SendEmail.jtp?type=node&node=11977&i=1> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > ------------------------------ > If you reply to this email, your message will be added to the discussion > below: > http://forum.openscad.org/Font-size-resetting-in-editor-tp11976p11977.html > To unsubscribe from Font size resetting in editor, click here > <http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=11976&code=bGF1cmF0YWFsbWFuQGdtYWlsLmNvbXwxMTk3NnwtMjA3OTc2OTAzMg==> > . > NAML > <http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> > -- Dr. Laura Taalman JMU Mathematics Department educ.jmu.edu/~taalmala www.mathgrrl.com/hacktastic @mathgrrl <http://www.twitter.com/mathgrrl> -- View this message in context: http://forum.openscad.org/Font-size-resetting-in-editor-tp11976p11978.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Mar 12, 2015 4:51 AM
Oh.
The remember font size feature only works when setting the font size from Preferences.
On Mar 12, 2015, at 00:33 AM, Laura Taalman <laurataalman@gmail.com> wrote: > * increase font size by pressing command-shift-plus a few times Oh. The remember font size feature only works when setting the font size from Preferences. -Marius
LT
Laura Taalman
Thu, Mar 12, 2015 4:58 AM
Ah, I will do it that way, then!
Have a great night,
Laura
Oh.
Preferences.
Dr. Laura Taalman
Ah, I will do it that way, then! Have a great night, Laura On Thu, Mar 12, 2015 at 12:51 AM, Marius Kintel <marius@kintel.net> wrote: > On Mar 12, 2015, at 00:33 AM, Laura Taalman <laurataalman@gmail.com> > wrote: > > > * increase font size by pressing command-shift-plus a few times > > Oh. > The remember font size feature only works when setting the font size from > Preferences. > > -Marius > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > -- Dr. Laura Taalman JMU Mathematics Department educ.jmu.edu/~taalmala www.mathgrrl.com/hacktastic @mathgrrl <http://www.twitter.com/mathgrrl>
