It was discussed before, but not in extension and afaik without a solution so
far. Sometimes I want to rewrite built-in modules or functions in order to
e.g. extend their parameter list and functionality. The problem: "after" and
within that code I loose access to the built-in symbols. So particularly
there is no way back if the rewrite happens within a lib.
Say I want to rewrite cube() in a lib to get rid of the cumbersome brackets
and default it to center=true, e.g. by:
cube(10, 20, 1);
module cube(size=1, y=1, z=1, center = true, x=undef)
x = is_undef(x)?size:x;
if (is_undef(x[0])) cube([x, y, z], center=center); else cube(x, center);
This obviously results in a recursion error. So I have to use a naming
convention:
module cube_(size=1, y=1, z=1, center = true, x=undef)
I'd rather like to write something like
if (is_undef(x[0])) $cube([x, y, z], center=center); else $cube(x,
center);
and then if necessary be able to switch back to the built-in version by
module cube(size=1, center=false) $cube(size, center);
+1
I too have desired this for some time.
There is one significant downside, that being supportability, if cube() no
longer behaves as it seemingly should, possibly due to something berried in
a library three layers deep, it is going to drive people insane...
I wouldn't sign that default values and parameters for built-ins have been
established in a foresighted manner. A properly designed lib can take a lot
of clumsyness and burden from this and lead to a much richer standard lib.
BTW, current OpenSCAD does not prevent you from rewriting cube() in a lib
buried three layers deep. Your implementation just can't refer to the
built-in cube(). And there is no way back to built-in behaviour.
cube(10,20,30);
module cube(x,y,z, center = true) linear_extrude (z, center = center)
square([x,y], center = center);
longer behaves as it seemingly should, possibly due to something buried in
