How to combine long path and file for import()
PR
Peter Ragosch
Fri, Aug 2, 2019 3:14 PM
Hallo everyone,
long time ago I could feed a long path into variable path="/long/path/"
and the file name into variable file="myFile.dxf" for contaminated use
in import{_dxf}(). But I can't remember how I did that.
Any help is highly appreciated.
Mit freundlichen Grüßen
Best Regards
Peter Ragosch
Hallo everyone, long time ago I could feed a long path into variable path="/long/path/" and the file name into variable file="myFile.dxf" for contaminated use in import{_dxf}(). But I can't remember how I did that. Any help is highly appreciated. -- Mit freundlichen Grüßen Best Regards Peter Ragosch
Fri, Aug 2, 2019 4:15 PM
This should work.
import(str(path, file));
On Fri, 2 Aug 2019 at 16:15, Peter Ragosch peter.ragosch@kabelmail.de
Hallo everyone,
Best Regards
Peter Ragosch
This should work. import(str(path, file)); On Fri, 2 Aug 2019 at 16:15, Peter Ragosch <peter.ragosch@kabelmail.de> wrote: > Hallo everyone, > > long time ago I could feed a long path into variable path="/long/path/" > and the file name into variable file="myFile.dxf" for contaminated use > in import{_dxf}(). But I can't remember how I did that. > > Any help is highly appreciated. > > -- > Mit freundlichen Grüßen > Best Regards > > Peter Ragosch > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
PR
Peter Ragosch
Fri, Aug 2, 2019 4:22 PM
Indeed!
Thank you very much.
Am Fri, 2 Aug 2019 17:15:14 +0100
schrieb nop head nop.head@gmail.com:
This should work.
peter.ragosch@kabelmail.de wrote:
Hallo everyone,
Best Regards
Peter Ragosch
Best Regards
Peter Ragosch
Indeed! Thank you very much. Am Fri, 2 Aug 2019 17:15:14 +0100 schrieb nop head <nop.head@gmail.com>: > This should work. > > import(str(path, file)); > > On Fri, 2 Aug 2019 at 16:15, Peter Ragosch > <peter.ragosch@kabelmail.de> wrote: > > > Hallo everyone, > > > > long time ago I could feed a long path into variable > > path="/long/path/" and the file name into variable > > file="myFile.dxf" for contaminated use in import{_dxf}(). But I > > can't remember how I did that. > > > > Any help is highly appreciated. > > > > -- > > Mit freundlichen Grüßen > > Best Regards > > > > Peter Ragosch > > > > > > _______________________________________________ > > OpenSCAD mailing list > > Discuss@lists.openscad.org > > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > -- Mit freundlichen Grüßen Best Regards Peter Ragosch
