making threaded holes with OpenScad?
EF
Eric Frank
Wed, Feb 16, 2022 12:37 PM
Is it possible to make threaded  holes with OpenScad? I am trying to make a 2 mm threaded hole, about 2.4 mm in diameter. Is there a command in OpenScad that makes threaded holes in plastic.
Thanks,
Eric
Is it possible to make threaded holes with OpenScad? I am trying to make a 2 mm threaded hole, about 2.4 mm in diameter. Is there a command in OpenScad that makes threaded holes in plastic. Thanks, Eric
