How do you perform a boolean difference between a shape and a block of text?
I'm trying to model an "N" cutout of a cube.
Since OpenSCAD doesn't natively support text, I'm using Write.scad
(http://www.spolearninglab.com/curriculum/lessonPlans/hacking/resources/software/3d/openscad/openscad_write.html)
to create the "N" shape. This is simply:
use <Write.scad>
write("N");
and of course adding a cube makes it:
use <Write.scad>
cube(1);
write("N");
From how I understand the difference operation, differencing these two
should be simply:
use <Write.scad>
difference{
cube(1);
write("N");
However, when I run this, the view pane turns black and nothing renders.
What am I doing wrong?
View this message in context: http://forum.openscad.org/How-to-difference-shape-with-text-tp10724.html
Try "difference()", but have a look at just the write so you know the size
and orientation of the N v's the cube.
View this message in context: http://forum.openscad.org/How-to-difference-shape-with-text-tp10724p10725.html
BTW if you are using the dev snapshot see text()
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Text . It is 2D, if
you want to use it for 3D you need to linear_extrude() it.
View this message in context: http://forum.openscad.org/How-to-difference-shape-with-text-tp10724p10726.html
I'm using 2014.03, not the dev version. Is this not possible with the
stable version? I am using difference(), so I'm not sure what you mean by
"try difference()". I did have a typo in my original email, I meant to
include the parens. To keep it simple, I excluded the transformations. The
full code is:
use <Write.scad>
translate([-1, -1, -1]) {
cube(6);
translate([0, 0, -3]) {
scale([1.5, 1, 10]){
write("N");
Commenting out the difference shows an N stretching out of the top of a
cube.
On Fri, Dec 26, 2014 at 1:09 AM, MichaelAtOz [via OpenSCAD] <
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Text. It is 2D, if
Public Domain; To the extent possible under law, I have waived all
copyright and related or neighbouring rights to this work. This work is
published globally via the internet. :)
Inclusion of works of previous authors is not included in the above.
http://www.ourfairdeal.org/
below:
To unsubscribe from How to difference shape with text?, click here
http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=10724&code=Y2hyaXNzcGVuQGdtYWlsLmNvbXwxMDcyNHwxMjg4NzkwNjM4
NAML
View this message in context: http://forum.openscad.org/How-to-difference-shape-with-text-tp10724p10727.html
That works for me on 2014.03 (W7/64).
http://forum.openscad.org/file/n10728/write.jpg
(I have the '!' as I had ther code in the editor too)
What is it doing for you?
View this message in context: http://forum.openscad.org/How-to-difference-shape-with-text-tp10724p10728.html
