Using children with let
JS
John Savage
Wed, Sep 12, 2018 2:06 PM
I would like to be able to write a single let() statement and use it on
multiple modules. A simple example is
module leta(){
let(a=23)
leta() cylinder(h=a, d=a); // Doesn't work, a is unknown here.
However this does work:
module move(x){
translate([x,0,0])
module cone_rod(){
cylinder(h=10,d=5);
cylinder(h=5,d1=15,d2=0);
move(0) cone_rod();      // Works as expected
move(20) cone_rod();    // Works as expected
What's the difference and why doesn't the first example work?
Thanks,
John
I would like to be able to write a single let() statement and use it on multiple modules. A simple example is module leta(){ let(a=23) children(); } leta() cylinder(h=a, d=a); // Doesn't work, a is unknown here. However this does work: module move(x){ translate([x,0,0]) children(); } module cone_rod(){ cylinder(h=10,d=5); cylinder(h=5,d1=15,d2=0); } move(0) cone_rod(); // Works as expected move(20) cone_rod(); // Works as expected What's the difference and why doesn't the first example work? Thanks, John
Wed, Sep 12, 2018 3:05 PM
OpenSCAD variables have lexical scope by default, so they can only be seen
in the block they are defined in. So you could do children(a) to access the
23rd child but a is not visible outside leta() and more specifically only
under the let().
However, if you use $a it will have dynamic scope and be accessible in all
the modules and functions called from the block it is defined in.
module leta(){
let(a=23)
module move(x){
translate([x,0,0])
module cone_rod(){
cylinder(h=10,d=5);
What’s the difference and why doesn’t the first example work?
Thanks,
John
OpenSCAD variables have lexical scope by default, so they can only be seen in the block they are defined in. So you could do children(a) to access the 23rd child but a is not visible outside leta() and more specifically only under the let(). However, if you use $a it will have dynamic scope and be accessible in all the modules and functions called from the block it is defined in. On 12 September 2018 at 15:06, John Savage <john@jegsav.com> wrote: > I would like to be able to write a single let() statement and use it on > multiple modules. A simple example is > > > > module leta(){ > > let(a=23) > > children(); > > } > > > > leta() cylinder(h=a, d=a); // Doesn't work, a is unknown here. > > > > However this does work: > > > > module move(x){ > > translate([x,0,0]) > > children(); > > } > > > > module cone_rod(){ > > cylinder(h=10,d=5); > > cylinder(h=5,d1=15,d2=0); > > } > > > > move(0) cone_rod(); // Works as expected > > move(20) cone_rod(); // Works as expected > > > > What’s the difference and why doesn’t the first example work? > > Thanks, > > John > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
JS
John Savage
Wed, Sep 12, 2018 5:30 PM
Hi Nop Head(?) Thanks for your reply. I get it now. John
Sent: 12 Sep 2018 04:05
To: john@jegsav.com; OpenSCAD general discussion
Subject: Re: [OpenSCAD] Using children with let
module leta(){
let(a=23)
module move(x){
translate([x,0,0])
module cone_rod(){
cylinder(h=10,d=5);
Thanks,
John
Image removed by sender.
Hi Nop Head(?) Thanks for your reply. I get it now. John From: nop head [mailto:nop.head@gmail.com] Sent: 12 Sep 2018 04:05 To: john@jegsav.com; OpenSCAD general discussion Subject: Re: [OpenSCAD] Using children with let OpenSCAD variables have lexical scope by default, so they can only be seen in the block they are defined in. So you could do children(a) to access the 23rd child but a is not visible outside leta() and more specifically only under the let(). However, if you use $a it will have dynamic scope and be accessible in all the modules and functions called from the block it is defined in. On 12 September 2018 at 15:06, John Savage <john@jegsav.com> wrote: I would like to be able to write a single let() statement and use it on multiple modules. A simple example is module leta(){ let(a=23) children(); } leta() cylinder(h=a, d=a); // Doesn't work, a is unknown here. However this does work: module move(x){ translate([x,0,0]) children(); } module cone_rod(){ cylinder(h=10,d=5); cylinder(h=5,d1=15,d2=0); } move(0) cone_rod(); // Works as expected move(20) cone_rod(); // Works as expected What’s the difference and why doesn’t the first example work? Thanks, John Image removed by sender. _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
