I have a model that seems to be taking a long time to render (and sometimes preview), so I obviously need to figure out where the problem is, so I am using the debug symbols (* and !). However, even when I have everything other than a couple simple elements (for example, polygon with linear_extrude), it still takes a lot longer than it should. I am wondering if elements marked with the * are still "rendered in memory" just not included in the result, causing the long amount of rendering time. Do I need to actually comment out (using // instead of *) the elements to do my debugging? To put it simply, does OpenSCAD attempt to think about elements with * at all, or does it think about them and just not display them?
Nathan Sokalski
Yes, OpenSCAD will still evaluate all the code even if you use debugging symbols to isolate rendering.
Only the visible code needs to be actually rendered, but you could be running into performance issues related to language evaluation, not rendering.
It would be easier to diagnose if you could share an example.
On Mar 15, 2024, at 15:38, Nathan Sokalski via Discuss discuss@lists.openscad.org wrote:
Nathan Sokalski
njsokalski@hotmail.com mailto:njsokalski@hotmail.com
First let's get some terminology straight. Not that I would claim that
anybody else uses this particular terminology, but I'd say that there
are approximately four phases in the execution of an OpenSCAD program:
then either
For most models, the only part of that that takes a long time is the
"render" step. That step is much faster with Manifold than it is with CGAL.
For some models, the "execution" step can take a long time. As a data
point, "for (i=[0:1000], j=[0:1000], k=[0:10]);", a
ten-million-iteration loop, takes about 3 seconds on my system.
So the question is when the debug modifiers are processed.
The debug modifiers do not block parsing. (Comments, of course, do.)
If you have a syntax error, you have a syntax error.
The * modifier blocks execution. If I put a * in front of that "for"
loop, the execution time goes away. Notably, "*echo(whatever);" will
not be executed.
To my surprise, the % modifier blocks its subtree from being part of the
model, but mostly does not block it from being processed during the
"render" phase. My test program (500 partially overlapping cubes, plus
a sphere) takes 6s to render, but 5s to render with a % in front of the
for loop, only a ~15% reduction.
The # modifier doesn't block anything.
The ! modifier blocks rendering of other elements, but does not block
execution of those elements. Notably, echo() calls are executed.
Here's my test program. Mark lines with modifiers and/or comment out to
construct test cases. Note that I was using CGAL; if you have Manifold
enabled you probably need more cubes to get to a run time that you can
reasonably measure and compare. (5000 got me a 2s render time.)
echo("hello");
for (i=[1:1000], j=[1:1000], k=[1:10]);
for (i=[1:500]) translate([i,i,i]) cube(10);
sphere(20);
