B
ben
Mon, Jul 23, 2018 4:29 AM
Hello OpenSCAD community! :)
When using OpenSCAD, I find myself missing things from other standard
languages:
- The ability to throw exceptions, and be informed where in the code the
exception occurred (like a stack trace)
- Modularity: the ability to tie things together (data for sure, but also
functions) in objects.
- Type safety, a compiler or type checker could prevent me from making lots
of mistakes.
I wrote some stuff (https://github.com/ben-horner/scad-primitives), and was
planning to try to get run-time type checking into OpenSCAD. It includes:
- Hacky way of throwing exceptions (using infinite recursion) which echos a
string which you can search for in the source.
- Full featured map (aka dictionary) functionality (can't speak to
performance...) through global functions.
I've iterated a few times using (nested) maps to define the data members of
objects, and tried to get type checking working, but what I have to work
with seems too thin. I've started writing some Scala code, which could turn
into a DSL (domain specific language) which compiles to OpenSCAD for
rendering.
My question(s) are:
Are there other things out there that can give me some of what I want
already?
Development complexity versus performance: If I continue down my current
path, would it be necessary to support all of OpenSCAD's current syntax?
i.e. "intersect_for()"? I could build code which produces an
intersect_for() statement, but I could also write code which produces one
big "intersect()" with all of the intersected elements explicitly present.
Could there be a render-time benefit to keeping things more concise with
intersect_for()? There are many other cases where if you were writing in
OpenSCAD you'd want to write for reuse (modules and functions), but is there
any performance benefit to doing it that way? It would be easier to write
my Scala code to just write sprawling huge OpenSCAD files, is there a
downside to this?
languages:
* The ability to throw exceptions, and be informed where in the code the
* Modularity: the ability to tie things together (data for sure, but also
* Type safety, a compiler or type checker could prevent me from making lots
of mistakes.
* Hacky way of throwing exceptions (using infinite recursion) which echos a
* Full featured map (aka dictionary) functionality (can't speak to
rendering.
My question(s) are:
* Are there other things out there that can give me some of what I want
already?
* Development complexity versus performance: If I continue down my current
downside to this?
runsun
Sat, Jul 28, 2018 12:03 AM
lots
I've tried to construct some data structures to represent objects, packed
with all object properties and steps required to move/modify it, then use a
Make(data) module to draw it. The packaging makes it feel like
a class in OOP obj and allows it to be passed around, but since everything
is packed, it's extremely difficult to debug. The codes are still there:
https://bitbucket.org/runsun/scadx/src/master/scadx_make.scad
but I've walked away from it.
I do applied some data "packaging" (in a hash) to represent func/mod
arguments. This allow users to design a mod:
module Mymod( len,w, opt ) { ... }
then use it anyway like:
Mymod( len=3, w=4 );
Mymod( opt=["len", 3, "w",4] );
Mymod( w=5, opt=["len", 3, "w",4] ); // 5 would replace 4
and the opt can be passed around and updated at RT:
Mymod1( opt );
Mymod2( w=8, opt );
Mymod3( len=10, opt );
It also allows users to set/modify the properties of a sub-unit of an
object:
module Arm( len, d, opt ) { ... };
Arm( len=10, d=1 );
module Body( leg, arm, opt ) { ... } ;
Body( arm = arm_opt ); // where arm_opt = ["len",10, "d",1]
In this case, you can't do Arm( len=10, d=1) any more because Arm is inside
the Body.
The code :
https://bitbucket.org/runsun/scadx/src/master/scadx_args.scad
The following are parts of my lib Scadx :
A hash based on search() could be very efficient:
https://github.com/runsun/OpenSCAD_Tips/blob/master/snippets.md#hash
This hash is heavily used though out the entire lib. For more hash-related
functions, see:
https://bitbucket.org/runsun/scadx/src/master/scadx_hash.scad
>>> lots
of mistakes
A lot of type-checking functions (including geometric type like point etc):
https://bitbucket.org/runsun/scadx/src/master/scadx_inspect.scad
I haven't visited this file for a long time:
https://bitbucket.org/runsun/scadx/src/master/scadx_error.scad
The stack tracing doesn't seem to be possible in OpenSCAD. But, a
tree-structure logging system might help:
https://bitbucket.org/runsun/scadx/src/master/scadx_log.scad
Check this out for demo:
https://bitbucket.org/runsun/scadx/src/master/demos/demo_log.scad
Also check these for your other interests:
https://bitbucket.org/runsun/scadx/src/master/scadx_array.scad
https://bitbucket.org/runsun/scadx/src/master/scadx_range.scad
Mymod1( opt );
Mymod2( w=8, opt );
object:
Arm( len=10, d=1 );
the Body.
The code :
runsun
Sat, Jul 28, 2018 12:30 AM
The logging system in action:
<http://forum.openscad.org/file/t602/2018-07-27_19_25_46-Planter_Bench_187q.png>
BH
Benjamin Hill
Sat, Jul 28, 2018 12:39 AM
Heretical question: why not use JavaScript/ES6 with an import of OpenSCAD
functions?
import { scad } from '/modules/openscad.js';
[1,5,7,8]
.filter(x => x>2)
.forEach(x => {
scad.translate(x, x*100, 0);
scad.circle(x);
languages:
of mistakes.
was
turn
rendering.
My question(s) are:
already?
there
downside to this?
functions?
[1,5,7,8]
.filter(x => x>2)
.forEach(x => {
scad.circle(x);
> languages:
> of mistakes.
> was
> turn
> rendering.
> My question(s) are:
> already?
> there
> downside to this?
N
NateTG
Sat, Jul 28, 2018 5:36 AM
functions?
I've been musing on writing an OpenSCAD interpreter for blender since it
seems to have a more suitable interaction with the geometry engine than
OpenSCAD does.
functions?
OpenSCAD does.
Mon, Jul 30, 2018 11:52 PM
I think your approach to create a DSL in Scala is a good one.
You can't get very far by trying to "fix" OpenSCAD using libraries.
There are too many limitations in the language.
If I were you, I would try to use the smallest possible subset of OpenSCAD
for your code generator. The language is full of weird, inconvenient
behaviour,
and this minimizes the pain of dealing with the mismatch between Scala and
OpenSCAD semantics.
Do not output variable definitions, function definitions, module
definitions,
if statements, or for statements. Do all of this in Scala code, and just
output
nested calls to primitive modules like cube, union, etc.
If you are worried about performance, try measuring it. My guess is that
it will be fine. The OpenSCAD interpreter is slow, so by doing as much
computation
as possible in Scala, you will more likely be speeding things up.
You are reinventing the wheel -- SolidPython is occasionally mentioned on
the list,
and probably already does what you want, if you are okay with using Python.
But that's okay, because building these kinds of systems is fun.
languages:
of mistakes.
was
turn
rendering.
My question(s) are:
already?
there
downside to this?
behaviour,
OpenSCAD semantics.
definitions,
output
computation
the list,
> languages:
> of mistakes.
> was
> turn
> rendering.
> My question(s) are:
> already?
> there
> downside to this?
Tue, Jul 31, 2018 12:31 AM
Or just another crazy thought...
Help improving OpenSCAD itself
Some features that are mentioned in the initial post
are already implemented, like assert().
B
ben
Wed, Aug 1, 2018 5:33 AM
I don't know if it's heretical, but I wouldn't be able to lean on the
language for type checking right?
I'd have to implement type checking myself, like I tried to in pure
OpenSCAD.
Were you describing a javascript library that already exists?
OpenSCAD.
B
ben
Wed, Aug 1, 2018 5:51 AM
I got the version with assert on my Mac, but it died, now on my linux box I
think it wasn't available. I did like having it though.
I thought that trying to make a large change to a program that people depend
on would take a lot of bullet-proofing, and corner-case coverage than
writing something separate. I guess I could check out the actual OpenSCAD
code to see about adding a type system, do you really think that's a good
path to take?
path to take?
B
ben
Wed, Aug 1, 2018 5:57 AM
I just looked at SolidPython a bit, and will look some more. (Seeing the
word 'right' used for positive X made me think there could be lots of stuff
I didn't like in there.) Being based on python would mean no static type
safety right?
safety right?
