I am trying to manipulate an STL file and I started by using the difference
command.
At the moment, I am using a cube to 'take away' material from the STL file.
The cube is of a temporary size and position.
Here is the code ( from
https://drive.google.com/file/d/1qkBsjmyGhAaEsH8V1E1WoS5jOCYzfPzB/view?usp=sharing
import("Squirrel_Picnic_Table_-_topbracket a.stl");
cube([10,10,10]);
What happens is there are all sorts of 'ghosting' with gaps/holes in the
model, an image that shows this is
https://drive.google.com/file/d/1Wh_Uh-ojot5LHmzwKCcwSS9K6OASkzCH/view?usp=sharing
If I take the cube away, it looks fine
https://drive.google.com/file/d/1Tvj065N9BHBMK4lgl6VBnUS-7ROQqTTH/view?usp=sharing
The STL file I am importing is
https://drive.google.com/file/d/1lvmfqu2qTnOG4KcGboypfI8srrJFfGuu/view?usp=sharing
Does anyone know why this happens and how I can resolve this ghosting
effect please?
Thanks,
Richard.
You need to set the convexity parameter in the import statement, ss
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/STL_Import_and_Export#import
difference command.
cube([10,10,10]);
effect please?
Thanks,
Richard.
As was said very recently, we need to increase the default values of the
convexity parameters. This is wasting everyone's time, and has for years.
difference command.
Thanks for that, I read up about convexity and set it to 10, as I found
this "Setting it to 10 should work fine for most cases.".
That did the trick.
I also vote that the default value gets increased :)
Thanks for your help.
Richard.
difference command.
