This is also happening on the Nabble support forum, so hopefully it will get
fixed quickly.
If you 'insert image', the result, in both emails & the final thread post
shows it without the required prefix.
e.g.
</file/t359/Capture-key-oem-netfabb.jpg>
If you need to see the image, in you browser, just prepend it with:
http://forum.openscad.org
i.e. getting:
http://forum.openscad.org/file/t359/Capture-key-oem-netfabb.jpg
Interesting development
http://support.nabble.com/Nabble-is-now-open-source-td7603082.html
Note: You can join Bitbucket, and complain in commits, no issue tracker tho.
e.g.
https://bitbucket.org/frschmidt/nabble/commits/b741393880336c1c73b2c9d741da6e00e719b813
Some progress "You are right. I will fix this when I get back from vacation
next week."
"Hello MichaelAtOz,
The bug correction will be released in a few days. I'll let you know when
it's ok."
The incomplete link issue has now been fixed by Nabble.
So 'Insert Image' on Forum posts now works. This results in a clickable url
on the final post and email; not, as previously, an actual in-line image,
this is still being investigated.
Emails sent to the Mailing-list with in-line images works normally.
