I don’t use iCloud but I always get the pop up on first loading OpenScad M1 only or Universal despite having given OpenScad Files and Folder access.
I can then operate as normal until I close OpenScad.
The rosetta version works OK but is significantly slower. Big Sur 11.6.4
On 18 Mar 2022, at 00:55, Whosawhatsis whosawhatsis@gmail.com wrote:
Are you using a local documents folder, or one synced to iCloud? That could be the difference.
Then again, I also get the popup when working with .scad files in my downloads folder, which is similarly protected but not part of iCloud sync. I get it when opening a .scad file located in my downloads folder, and again any time I try to preview/render/export that file without making any modifications.
On Mar 17, 2022, 17:34 -0700, Marius Kintel marius@kintel.net, wrote:
My main laptop is on the latest macOS on Apple Silicon. I’ve also set up a few UTM (https://getutm.app/ https://getutm.app/) VMs, without being able to reproduce.
My Intel Mac running 11.6.2 also doesn’t see this problem, neither does any VMs I run on that one.
I’ve tried universal builds, Intel builds, Apple Silicon-only builds.
..so it’s puzzling indeed.
Any signal showing where this behaviour starts of stops would be helpful.
On Mar 16, 2022, at 00:10, David Schooley <dcschooley@gmail.com mailto:dcschooley@gmail.com> wrote:
Are you running on Apple Silicon or Intel?
This never happened with my local M1 build, only with the universal build. Maybe it has something to do with how the universal build is generated?
Perhaps it is somewhat encouraging that it doesn’t happen to everyone. For me, it happens with each file I open and every file that gets included in a “use” statement. It appears to happen less to other people.
I’ll play around with things to see if I can make it stop.
On Mar 15, 2022, at 5:35 PM, Marius Kintel <marius@kintel.net mailto:marius@kintel.net> wrote:
It’s a known issue, but unfortunately I cannot seem to reproduce it, neither on my Mac or on a fresh VM install.
If anyone can find a way of reliably reproduce this on a fresh install, that would be really helpful.
Github issue: https://github.com/openscad/openscad/issues/4059 https://github.com/openscad/openscad/issues/4059
On Mar 15, 2022, at 12:29, David Schooley <dcschooley@gmail.com mailto:dcschooley@gmail.com> wrote:
Is anybody else still having the problem where the universal MacOS build keeps asking for permission to access the “Documents” folder. There was some discussion about this in January. All of my settings are correct. I’m running the latest development snapshot and I’ve deleted all of the other copies of OpenSCAD.
Thanks.
Just installed the latest Mac Universal build on my Intel Mac Mini. I did not seer the problem, but I never access the downloads folder.
Every bit of data that I care about is in a Dropbox folder.
-Bob
Tucson AZ
On 18 Mar 2022, at 00:55, Whosawhatsis <whosawhatsis@gmail.com mailto:whosawhatsis@gmail.com> wrote:
On Mar 17, 2022, 17:34 -0700, Marius Kintel <marius@kintel.net mailto:marius@kintel.net>, wrote:
Thanks.
You would probably still see it asking for access to the documents folder in some circumstances, since the auto backup feature puts things there.
-Bob
Tucson AZ
My main laptop is on the latest macOS on Apple Silicon. I’ve also set up a few UTM (https://getutm.app/) VMs, without being able to reproduce.
Thanks.
I moved my Documents folder to iCloud to see if that made a difference. I still get lots of unnecessary requests.
-Bob
Tucson AZ
On Mar 18, 2022, at 10:00, Bob Carter <caggius@gmail.com mailto:caggius@gmail.com> wrote:
Thanks.
