Hi all;
Trying to get into production on another harminic drive version, and am having
2 or 3 problems.
PETG on the hanger, H2 head on a BIQU BX printer, 235C nozzle, 70C bed.
!: Excessive stringing of the inside of a tube, where it doesn't stick and
stretches across 20 degrees or so in a straight line, In largely random
locations. What can I change to alleviate that?
Thanks for any hints.
If you haven't yet tried it, consider to place your filament spool in a food dehydrator for up to fifteen hours. There's a few videos and photos of before and after prints and one of the consistent aspects is substantially reduced stringing and improved surface finish.
Original message from gene heskett gheskett@shentel.net
end of original message (constructively edited, of course)
In Cura, top rh corner - market place - community plugins- parts for
calibration. Get a new reel of pet, run the temperature tower, then
retraction towers then other tests that you may want. Under 'travel',
learn how those settings work, retraction, combing, etc. Community
plugins have detailed settings guide, that will also help with setting
up support roof, etc. Do a web search, plenty of suggestion wrt printing
petg, etc., but they will give you a starting point. Your printer's
temperature will not be accurate, your filament will be different, you
need to tune it all in. If you can't do that you will be wasting your
time and filament.
Best wishes,
Ray
On 23/12/2021 20:26, gene heskett wrote:
Hi all;
2 or 3 problems.
Cheers, Gene Heskett.
