Is there a way to script exporting of models to STL files? I have created
some modules where I can pass parameters to the modules to create a bunch of
different shapes of various sizes and between the number of modules and the
parameters that can be passed to the modules there are over 200 different
STL files to be generated. I would REALLY rather not do this manually if at
all possible.
View this message in context: http://forum.openscad.org/Scripting-Export-to-STL-tp15358.html
See the command-line usage documentation:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_OpenSCAD_in_a_command_line_environment https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_OpenSCAD_in_a_command_line_environment
Andrew.
all possible.
"The future is already here. It's just not very evenly distributed" -- William Gibson
Perfect, that is exactly what I need.
Thank You!!!
View this message in context: http://forum.openscad.org/Scripting-Export-to-STL-tp15358p15360.html
