Does someone achieved to get a list of OpenSCAD modules and functions in
Geany's 'symbol table' or in Notepad++ 'function list' windows? I'm using
the OpenSCAD configuration files for those editors found in Thingiverse but
I only get a list of symbols if define the .scad file as a C, C++ or C#
types file. It would be very handy to have this functionality. I tried to
change some configuration files in those editors without success. I'm not a
programming expert. Any help is welcome.
Thanks a lot.
View this message in context: http://forum.openscad.org/OpenSCAD-modules-and-functions-list-in-editors-Geany-or-Notepad-tp14042.html
There is this: http://www.thingiverse.com/thing:167899 for Notepad++ and
a couple of others on Thingiverse. I was in the midst of a significant
upgrade to the tooltips and keywords, but got sidetracked by a trip to the
hospital. I'll try to get that update finished and posted this weekend.
Thanks a lot.
Gary A. Crowell Sr., P.E. http://www.ipels.idaho.gov/, CID+
http://dc.ipc.org/html/default.htm
Linkedin http://www.linkedin.com/in/garyacrowellsr Elance
http://www.linkedin.com/redirect?url=http%3A%2F%2Fgaryacrowellsr%2Eelance%2Ecom&urlhash=kJm9
KE7FIZ http://www.arrl.org Things
http://www.thingiverse.com/garyacrowellsr/designs RocketryCNC
https://www.etsy.com/shop/RocketryCNC?ref=l2-shopheader-name
Thanks for your reply. It seems to me that we have to make a new parser
section in "functionList.xml" for notepad++ to work. For Geany I have no
idea. I tried to modify one of the existing parser sections to detect the
words "module" and "function" but I had no success. I tried with this code:
<association ext=".scad" id="OpenSCAD"/>
<parser id="OpenSCAD" displayName="OpenSCAD Module"
commentExpr="((/\*.*?\*)/|(//.*?$))">
<function
mainExpr="^[\t ]*(module|function)\w+"
displayMode="$functionName">
<functionName>
<nameExpr expr="[^\t(module|function)]+[\w]+"/>
</functionName>
</function>
</parser>
Best regards.
View this message in context: http://forum.openscad.org/OpenSCAD-modules-and-functions-list-in-editors-Geany-or-Notepad-tp14042p14047.html
On 10/02/2015 11:15 PM, jpmendes wrote:
For Geany I have no idea. I tried to modify one of the existing parser
sections to detect the words "module" and "function" but I had no success.
Is the one listed in the Manual not working anymore?
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_an_external_Editor_with_OpenSCAD
If that's the case, it would be better to remove it there or add a note
if it's only working for older versions.
Hello,
Yes, it does it does syntax highlight and color and auto completion. I'm
referring to navigation of modules and functions in the symbols windows.
That functionality is missing in the OpenSCAD config files for both
Notepad++ and Geany. I'm using 64 bit Windows 7 OS.
Regards
View this message in context: http://forum.openscad.org/OpenSCAD-modules-and-functions-list-in-editors-Geany-or-Notepad-tp14042p14052.html
