Wed, Jan 11, 2017 2:44 AM
Post didn't make the mailing-list, copied below.
c.levastre wrote
Graphscad generate source code for OpenScad and provide advanced features
- Single node evaluation with double clicking makes debugging is pretty
easy.
- Several advanced nodes like Gears and Pulley, Box, LookAt
- No more headache with rotations and translations order : transfom nodes
can work in 'World' space like usual, but it's possible to create
transfoms in 'Local' space and 'Object' Space.
- Graphscad datas are embedded in created .scad files (in comment
section). So a .scad file created with graphscad can be be directly used
by Openscad, and shared
- Source code of all nodes is provided, you can create and share your own
nodes with basic python knowledge.
Let me know if u like graphscad.
View this message in context: http://forum.openscad.org/Graphscad-A-New-Nodal-editor-for-Openscad-tp20016p20020.html
c.levastre wrote
> Hi all.
> I like and use openscad for my 3D designs. But scripting is sometime a
> little boring (this remain me the work ;-))
> So i created a 'Nodal graph editor'
> This tool is a beta and is released at
> http://graphscad.blogspot.fr <http://graphscad.blogspot.fr>
<http://forum.openscad.org/file/n20016/demo1.jpg>
> easy.
Wed, Jan 11, 2017 12:56 PM
Very interesting.
I ALWAYS have a list of named values at the top of each script (like
"id" for inner diameter, "od" for outer diameter, etc) which describe
the object I am creating, so that I can tweak the design through use of
those values. In the demos that I saw, you typed in numerical values
for things like cube X. Is there a way to create a named value and use
that instead of the typed numerical value?
I can see things getting pretty big/complex pretty quickly. Can one
create a "module", and either show all of the internals for the module,
or not, so as to hide the code inside the modules?
easy.
Very interesting.
> c.levastre wrote
>> Hi all.
>> easy.
> Admin - PM me if you need anything, or if I've done something stupid...
> Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above.
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2016.0.7996 / Virus Database: 4749/13742 - Release Date: 01/10/17
CL
c.levastre@gmail.com
Wed, Jan 11, 2017 1:59 PM
Hi.
Varia
variable names :
Yes. look at the example 'hexacopter...' with attention. On the top left of
the graph, there are linked nodes named 'param'
You can change the name of the param node (right clic mouse button on the
node) , and enter a value or expression. then a variable with the name of
the node will be declared declared at the beginning of generated script.
this variable can be used in any input expression of the graph.
In future version, i will provide module encapsulation functionality.
Thinking of that to find the best method to do this.
2017-01-11 13:56 GMT+01:00 jon jon@jonbondy.com:
Very interesting.
I ALWAYS have a list of named values at the top of each script (like "id"
for inner diameter, "od" for outer diameter, etc) which describe the object
I am creating, so that I can tweak the design through use of those values.
In the demos that I saw, you typed in numerical values for things like cube
X. Is there a way to create a named value and use that instead of the
create a "module", and either show all of the internals for the module, or
features
easy.
nodes
own
Hi.
Varia
variable names :
2017-01-11 13:56 GMT+01:00 jon <jon@jonbondy.com>:
> Very interesting.
> Jon
>> c.levastre wrote
>>> Hi all.
>>> features
>>> easy.
>>> nodes
>>> own
AG
Alex Gibson
Sun, Jan 15, 2017 2:56 PM
This looks very interesting. Is there a way (programmed in or just described) to take an existing, complex Openscad file and display and edit it with Graphscad?
Thanks, Alex
From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of c.levastre@gmail.com
Sent: 11 January 2017 13:59
Subject: Re: [OpenSCAD] Graphscad : A New Nodal editor for Openscad
Hi.
Varia
variable names :
Yes. look at the example 'hexacopter...' with attention. On the top left of the graph, there are linked nodes named 'param'
You can change the name of the param node (right clic mouse button on the node) , and enter a value or expression. then a variable with the name of the node will be declared declared at the beginning of generated script. this variable can be used in any input expression of the graph.
In future version, i will provide module encapsulation functionality. Thinking of that to find the best method to do this.
Very interesting.
I ALWAYS have a list of named values at the top of each script (like "id" for inner diameter, "od" for outer diameter, etc) which describe the object I am creating, so that I can tweak the design through use of those values. In the demos that I saw, you typed in numerical values for things like cube X. Is there a way to create a named value and use that instead of the typed numerical value?
I can see things getting pretty big/complex pretty quickly. Can one create a "module", and either show all of the internals for the module, or not, so as to hide the code inside the modules?
c.levastre wrote
Hi all.
http://graphscad.blogspot.fr http://graphscad.blogspot.fr
easy.
Thanks, Alex
Hi.
Varia
variable names :
Very interesting.
c.levastre wrote
Hi all.
easy.
Jerry Davis
Sun, Jan 15, 2017 5:44 PM
I did everything it said to do, and I get nothing.
I am running latest version of wine, on osx El Capitan
I get a small box with a red X in it. That's all.
Extra Ham Operator: K7AZJ
Registered Linux User: 275424
it with Graphscad?
Thanks, Alex
*c.levastre@gmail.com
Hi.
Varia
variable names :
Very interesting.
c.levastre wrote
Hi all.
easy.
*The most exciting phrase to hear in science - the one that heralds new
discoveries - is not "Eureka!" but "That's funny...".*- Isaac. Asimov
> it with Graphscad?
> Thanks, Alex
> *From:* Discuss [mailto:discuss-bounces@lists.openscad.org] *On Behalf Of
> *Sent:* 11 January 2017 13:59
> *To:* OpenSCAD general discussion
> *Subject:* Re: [OpenSCAD] Graphscad : A New Nodal editor for Openscad
> Hi.
> Varia
> variable names :
> Very interesting.
> Jon
> c.levastre wrote
> Hi all.
> easy.
WA
William Adams
Thu, Apr 18, 2019 3:29 PM
Somehow I missed this --- seems very, very cool!
The interface is interesting --- if I understand correctly you design the
model as a series of connected objects / transformations, and then
parameterize it by setting up a separate set of math features which
instantiate variables which you then reference --- does that seem like a
correct understanding?
it with Graphscad?
Thanks, Alex
From: Discuss [mailto:discuss-bounces@lists.openscad.org] *On Behalf
Of *c.levastre@gmail.com
Hi.
Varia
variable names :
Very interesting.
c.levastre wrote
Hi all.
features
easy.
nodes
own
Somehow I missed this --- seems _very_, _very_ cool!
>> it with Graphscad?
>> Thanks, Alex
>> Hi.
>> Varia
>> variable names :
>> Very interesting.
>> Jon
>> c.levastre wrote
>> Hi all.
>> features
>> easy.
>> nodes
>> own
WA
William Adams
Tue, Apr 23, 2019 6:26 PM
I've worked with this a bit, and find it very nice.
The thing I find odd is that it doesn't seem to wire up the parameters so
that they will work in the OpenSCAD Customizer --- they seem to be
scattered throughout the file.
and if I open up a graphscad created .scad file for a simple cube it
generates an error:
WARNING: Too many unnamed arguments supplied, in file cube.scad, line 23
WARNING: variable center not specified as parameter, in file cube.scad,
line 23
which seems odd since line 23 is just:
cube([width,length,height],center=false);
(attached)
The odd thing is, I'm pretty sure I've been able to open other
graphscad-generated files in versions of OpenSCAD other than the one
bundled with it.
On Thu, Apr 18, 2019 at 11:29 AM William Adams will.adams@frycomm.com
it with Graphscad?
Thanks, Alex
Hi.
Varia
variable names :
Very interesting.
c.levastre wrote
Hi all.
features
easy.
nodes
own
01/10/17
generates an error:
line 23
(attached)
bundled with it.
On Thu, Apr 18, 2019 at 11:29 AM William Adams <will.adams@frycomm.com>
> William
>>> it with Graphscad?
>>> Thanks, Alex
>>> Hi.
>>> Varia
>>> variable names :
>>> Very interesting.
>>> Jon
>>> c.levastre wrote
>>> Hi all.
>>> features
>>> easy.
>>> nodes
>>> own
>>> 01/10/17
Tue, Apr 23, 2019 10:54 PM
WARNING: variable center not specified as parameter, in file cube.scad, line 23
It's because the script redefines "cube".
