$fn offsets cylinders...?
N
naviathan
Thu, Oct 12, 2017 4:42 PM
Code posted below.
Notice when rendered that the holes are not evenly spaced even though the
translates are. I've figured out that if I get rid of the $fn=30 on the
cylinders the holes line up evenly. My understanding is that $fn creates a
more rounded cylinder, but why would it offset them in relation to the
translate coordinates?
module base(){
cube([168,55,5]);
module mountHoles(){
translate( [ (168 - 16.5) , 3.4 , -0.5 ] ) cylinder( h = 5, r = 1.6,
$fn=30);
translate( [ (168 - 110.5) , 4.4 , -0.5 ] ) cylinder( h = 5, r = 1.6,
$fn=30);
translate( [ (168 - 16.5) , 3.4 , 2.5 ] ) cylinder( h = 3, r = 3,
$fn=30);
translate( [ (168 - 110.5) , 4.4 , 2.5 ] ) cylinder( h = 3, r = 3,
$fn=30);
translate( [ (168 - 16.5) , (3.4 + 43.22) , -0.5 ] ) cylinder( h = 5, r
= 1.6, $fn=30);
translate( [ (168 - 110.5) , (4.4 + 43.22) , -0.5 ] ) cylinder( h = 5, r
= 1.6, $fn=30);
translate( [ (168 - 16.5) , (3.4 + 43.22) , 2.5 ] ) cylinder( h = 3, r =
3, $fn=30);
translate( [ (168 - 110.5) , (4.4 + 43.22) , 2.5 ] ) cylinder( h = 3, r
= 3, $fn=30);
base();
mountHoles();
Code posted below. Notice when rendered that the holes are not evenly spaced even though the translates are. I've figured out that if I get rid of the $fn=30 on the cylinders the holes line up evenly. My understanding is that $fn creates a more rounded cylinder, but why would it offset them in relation to the translate coordinates? module base(){ cube([168,55,5]); } module mountHoles(){ translate( [ (168 - 16.5) , 3.4 , -0.5 ] ) cylinder( h = 5, r = 1.6, $fn=30); translate( [ (168 - 110.5) , 4.4 , -0.5 ] ) cylinder( h = 5, r = 1.6, $fn=30); translate( [ (168 - 16.5) , 3.4 , 2.5 ] ) cylinder( h = 3, r = 3, $fn=30); translate( [ (168 - 110.5) , 4.4 , 2.5 ] ) cylinder( h = 3, r = 3, $fn=30); translate( [ (168 - 16.5) , (3.4 + 43.22) , -0.5 ] ) cylinder( h = 5, r = 1.6, $fn=30); translate( [ (168 - 110.5) , (4.4 + 43.22) , -0.5 ] ) cylinder( h = 5, r = 1.6, $fn=30); translate( [ (168 - 16.5) , (3.4 + 43.22) , 2.5 ] ) cylinder( h = 3, r = 3, $fn=30); translate( [ (168 - 110.5) , (4.4 + 43.22) , 2.5 ] ) cylinder( h = 3, r = 3, $fn=30); } difference(){ base(); mountHoles(); } -- Sent from: http://forum.openscad.org/
Thu, Oct 12, 2017 5:12 PM
$fn doesn't affect the position of the hole centre but you want to keep it
a multiple of 4 to get symmetrical holes.
On 12 October 2017 at 17:42, naviathan naviathan@gmail.com wrote:
Code posted below.
module base(){
cube([168,55,5]);
$fn=30);
$fn=30);
$fn=30);
$fn=30);
= 1.6, $fn=30);
r
= 1.6, $fn=30);
3, $fn=30);
= 3, $fn=30);
base();
mountHoles();
$fn doesn't affect the position of the hole centre but you want to keep it a multiple of 4 to get symmetrical holes. On 12 October 2017 at 17:42, naviathan <naviathan@gmail.com> wrote: > Code posted below. > > Notice when rendered that the holes are not evenly spaced even though the > translates are. I've figured out that if I get rid of the $fn=30 on the > cylinders the holes line up evenly. My understanding is that $fn creates a > more rounded cylinder, but why would it offset them in relation to the > translate coordinates? > > module base(){ > cube([168,55,5]); > } > > module mountHoles(){ > translate( [ (168 - 16.5) , 3.4 , -0.5 ] ) cylinder( h = 5, r = 1.6, > $fn=30); > translate( [ (168 - 110.5) , 4.4 , -0.5 ] ) cylinder( h = 5, r = 1.6, > $fn=30); > translate( [ (168 - 16.5) , 3.4 , 2.5 ] ) cylinder( h = 3, r = 3, > $fn=30); > translate( [ (168 - 110.5) , 4.4 , 2.5 ] ) cylinder( h = 3, r = 3, > $fn=30); > > translate( [ (168 - 16.5) , (3.4 + 43.22) , -0.5 ] ) cylinder( h = 5, r > = 1.6, $fn=30); > translate( [ (168 - 110.5) , (4.4 + 43.22) , -0.5 ] ) cylinder( h = 5, > r > = 1.6, $fn=30); > translate( [ (168 - 16.5) , (3.4 + 43.22) , 2.5 ] ) cylinder( h = 3, r > = > 3, $fn=30); > translate( [ (168 - 110.5) , (4.4 + 43.22) , 2.5 ] ) cylinder( h = 3, r > = 3, $fn=30); > } > > > > > difference(){ > base(); > mountHoles(); > } > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Jeremy Buseman
Thu, Oct 12, 2017 5:18 PM
Ok, I figured out where the issues was. I apologize. I pulled the code from
Josef Prusa's Rambo case for the MK2 (I'm just making a plate to adapt the
case to 2020 extrusion). His cylinders are set strangely for some reason.
Although the hinges and mounts on the case appear square, they must not be.
Code posted below.
module base(){
cube([168,55,5]);
$fn=30);
$fn=30);
$fn=30);
$fn=30);
r
= 1.6, $fn=30);
5, r
= 1.6, $fn=30);
r =
3, $fn=30);
r
= 3, $fn=30);
base();
mountHoles();
Ok, I figured out where the issues was. I apologize. I pulled the code from Josef Prusa's Rambo case for the MK2 (I'm just making a plate to adapt the case to 2020 extrusion). His cylinders are set strangely for some reason. Although the hinges and mounts on the case appear square, they must not be. On Thu, Oct 12, 2017 at 1:12 PM, nop head <nop.head@gmail.com> wrote: > $fn doesn't affect the position of the hole centre but you want to keep it > a multiple of 4 to get symmetrical holes. > > On 12 October 2017 at 17:42, naviathan <naviathan@gmail.com> wrote: > >> Code posted below. >> >> Notice when rendered that the holes are not evenly spaced even though the >> translates are. I've figured out that if I get rid of the $fn=30 on the >> cylinders the holes line up evenly. My understanding is that $fn creates a >> more rounded cylinder, but why would it offset them in relation to the >> translate coordinates? >> >> module base(){ >> cube([168,55,5]); >> } >> >> module mountHoles(){ >> translate( [ (168 - 16.5) , 3.4 , -0.5 ] ) cylinder( h = 5, r = 1.6, >> $fn=30); >> translate( [ (168 - 110.5) , 4.4 , -0.5 ] ) cylinder( h = 5, r = 1.6, >> $fn=30); >> translate( [ (168 - 16.5) , 3.4 , 2.5 ] ) cylinder( h = 3, r = 3, >> $fn=30); >> translate( [ (168 - 110.5) , 4.4 , 2.5 ] ) cylinder( h = 3, r = 3, >> $fn=30); >> >> translate( [ (168 - 16.5) , (3.4 + 43.22) , -0.5 ] ) cylinder( h = 5, >> r >> = 1.6, $fn=30); >> translate( [ (168 - 110.5) , (4.4 + 43.22) , -0.5 ] ) cylinder( h = >> 5, r >> = 1.6, $fn=30); >> translate( [ (168 - 16.5) , (3.4 + 43.22) , 2.5 ] ) cylinder( h = 3, >> r = >> 3, $fn=30); >> translate( [ (168 - 110.5) , (4.4 + 43.22) , 2.5 ] ) cylinder( h = 3, >> r >> = 3, $fn=30); >> } >> >> >> >> >> difference(){ >> base(); >> mountHoles(); >> } >> >> >> >> -- >> Sent from: http://forum.openscad.org/ >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Thu, Oct 12, 2017 5:50 PM
If you are going to 3D print it you probably don't want to set $fn so high
on small holes if you want them to come out the right size. See
http://hydraraptor.blogspot.co.uk/2011/02/polyholes.html
not be.
Code posted below.
a
module base(){
cube([168,55,5]);
$fn=30);
$fn=30);
$fn=30);
$fn=30);
5, r
= 1.6, $fn=30);
5, r
= 1.6, $fn=30);
r =
3, $fn=30);
3, r
= 3, $fn=30);
base();
mountHoles();
If you are going to 3D print it you probably don't want to set $fn so high on small holes if you want them to come out the right size. See http://hydraraptor.blogspot.co.uk/2011/02/polyholes.html On 12 October 2017 at 18:18, Jeremy Buseman <naviathan@gmail.com> wrote: > Ok, I figured out where the issues was. I apologize. I pulled the code > from Josef Prusa's Rambo case for the MK2 (I'm just making a plate to adapt > the case to 2020 extrusion). His cylinders are set strangely for some > reason. Although the hinges and mounts on the case appear square, they must > not be. > > On Thu, Oct 12, 2017 at 1:12 PM, nop head <nop.head@gmail.com> wrote: > >> $fn doesn't affect the position of the hole centre but you want to keep >> it a multiple of 4 to get symmetrical holes. >> >> On 12 October 2017 at 17:42, naviathan <naviathan@gmail.com> wrote: >> >>> Code posted below. >>> >>> Notice when rendered that the holes are not evenly spaced even though the >>> translates are. I've figured out that if I get rid of the $fn=30 on the >>> cylinders the holes line up evenly. My understanding is that $fn creates >>> a >>> more rounded cylinder, but why would it offset them in relation to the >>> translate coordinates? >>> >>> module base(){ >>> cube([168,55,5]); >>> } >>> >>> module mountHoles(){ >>> translate( [ (168 - 16.5) , 3.4 , -0.5 ] ) cylinder( h = 5, r = 1.6, >>> $fn=30); >>> translate( [ (168 - 110.5) , 4.4 , -0.5 ] ) cylinder( h = 5, r = 1.6, >>> $fn=30); >>> translate( [ (168 - 16.5) , 3.4 , 2.5 ] ) cylinder( h = 3, r = 3, >>> $fn=30); >>> translate( [ (168 - 110.5) , 4.4 , 2.5 ] ) cylinder( h = 3, r = 3, >>> $fn=30); >>> >>> translate( [ (168 - 16.5) , (3.4 + 43.22) , -0.5 ] ) cylinder( h = >>> 5, r >>> = 1.6, $fn=30); >>> translate( [ (168 - 110.5) , (4.4 + 43.22) , -0.5 ] ) cylinder( h = >>> 5, r >>> = 1.6, $fn=30); >>> translate( [ (168 - 16.5) , (3.4 + 43.22) , 2.5 ] ) cylinder( h = 3, >>> r = >>> 3, $fn=30); >>> translate( [ (168 - 110.5) , (4.4 + 43.22) , 2.5 ] ) cylinder( h = >>> 3, r >>> = 3, $fn=30); >>> } >>> >>> >>> >>> >>> difference(){ >>> base(); >>> mountHoles(); >>> } >>> >>> >>> >>> -- >>> Sent from: http://forum.openscad.org/ >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Jeremy Buseman
Thu, Oct 12, 2017 6:13 PM
Thanks nop head. Nice blog.
not be.
Code posted below.
creates a
module base(){
cube([168,55,5]);
$fn=30);
1.6,
$fn=30);
$fn=30);
$fn=30);
5, r
= 1.6, $fn=30);
5, r
= 1.6, $fn=30);
3, r =
3, $fn=30);
3, r
= 3, $fn=30);
base();
mountHoles();
Thanks nop head. Nice blog. On Oct 12, 2017 13:51, "nop head" <nop.head@gmail.com> wrote: > If you are going to 3D print it you probably don't want to set $fn so high > on small holes if you want them to come out the right size. See > http://hydraraptor.blogspot.co.uk/2011/02/polyholes.html > > On 12 October 2017 at 18:18, Jeremy Buseman <naviathan@gmail.com> wrote: > >> Ok, I figured out where the issues was. I apologize. I pulled the code >> from Josef Prusa's Rambo case for the MK2 (I'm just making a plate to adapt >> the case to 2020 extrusion). His cylinders are set strangely for some >> reason. Although the hinges and mounts on the case appear square, they must >> not be. >> >> On Thu, Oct 12, 2017 at 1:12 PM, nop head <nop.head@gmail.com> wrote: >> >>> $fn doesn't affect the position of the hole centre but you want to keep >>> it a multiple of 4 to get symmetrical holes. >>> >>> On 12 October 2017 at 17:42, naviathan <naviathan@gmail.com> wrote: >>> >>>> Code posted below. >>>> >>>> Notice when rendered that the holes are not evenly spaced even though >>>> the >>>> translates are. I've figured out that if I get rid of the $fn=30 on the >>>> cylinders the holes line up evenly. My understanding is that $fn >>>> creates a >>>> more rounded cylinder, but why would it offset them in relation to the >>>> translate coordinates? >>>> >>>> module base(){ >>>> cube([168,55,5]); >>>> } >>>> >>>> module mountHoles(){ >>>> translate( [ (168 - 16.5) , 3.4 , -0.5 ] ) cylinder( h = 5, r = 1.6, >>>> $fn=30); >>>> translate( [ (168 - 110.5) , 4.4 , -0.5 ] ) cylinder( h = 5, r = >>>> 1.6, >>>> $fn=30); >>>> translate( [ (168 - 16.5) , 3.4 , 2.5 ] ) cylinder( h = 3, r = 3, >>>> $fn=30); >>>> translate( [ (168 - 110.5) , 4.4 , 2.5 ] ) cylinder( h = 3, r = 3, >>>> $fn=30); >>>> >>>> translate( [ (168 - 16.5) , (3.4 + 43.22) , -0.5 ] ) cylinder( h = >>>> 5, r >>>> = 1.6, $fn=30); >>>> translate( [ (168 - 110.5) , (4.4 + 43.22) , -0.5 ] ) cylinder( h = >>>> 5, r >>>> = 1.6, $fn=30); >>>> translate( [ (168 - 16.5) , (3.4 + 43.22) , 2.5 ] ) cylinder( h = >>>> 3, r = >>>> 3, $fn=30); >>>> translate( [ (168 - 110.5) , (4.4 + 43.22) , 2.5 ] ) cylinder( h = >>>> 3, r >>>> = 3, $fn=30); >>>> } >>>> >>>> >>>> >>>> >>>> difference(){ >>>> base(); >>>> mountHoles(); >>>> } >>>> >>>> >>>> >>>> -- >>>> Sent from: http://forum.openscad.org/ >>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>> >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Rob Ward
Thu, Oct 12, 2017 10:04 PM
Excellent article! Something about nothing, holes!! Thank you NopHead.
On 13 October 2017 5:13:38 am AEDT, Jeremy Buseman naviathan@gmail.com wrote:
high
code
to adapt
some
they must
not be.
keep
Code posted below.
though
on the
creates a
module base(){
cube([168,55,5]);
= 1.6,
$fn=30);
1.6,
$fn=30);
3,
$fn=30);
= 3,
$fn=30);
h =
5, r
= 1.6, $fn=30);
cylinder( h =
5, r
= 1.6, $fn=30);
h =
3, r =
3, $fn=30);
h =
3, r
= 3, $fn=30);
base();
mountHoles();
Sent from my Android device with K-9 Mail. Please excuse my brevity.
Excellent article! Something about nothing, holes!! Thank you NopHead. On 13 October 2017 5:13:38 am AEDT, Jeremy Buseman <naviathan@gmail.com> wrote: >Thanks nop head. Nice blog. > >On Oct 12, 2017 13:51, "nop head" <nop.head@gmail.com> wrote: > >> If you are going to 3D print it you probably don't want to set $fn so >high >> on small holes if you want them to come out the right size. See >> http://hydraraptor.blogspot.co.uk/2011/02/polyholes.html >> >> On 12 October 2017 at 18:18, Jeremy Buseman <naviathan@gmail.com> >wrote: >> >>> Ok, I figured out where the issues was. I apologize. I pulled the >code >>> from Josef Prusa's Rambo case for the MK2 (I'm just making a plate >to adapt >>> the case to 2020 extrusion). His cylinders are set strangely for >some >>> reason. Although the hinges and mounts on the case appear square, >they must >>> not be. >>> >>> On Thu, Oct 12, 2017 at 1:12 PM, nop head <nop.head@gmail.com> >wrote: >>> >>>> $fn doesn't affect the position of the hole centre but you want to >keep >>>> it a multiple of 4 to get symmetrical holes. >>>> >>>> On 12 October 2017 at 17:42, naviathan <naviathan@gmail.com> wrote: >>>> >>>>> Code posted below. >>>>> >>>>> Notice when rendered that the holes are not evenly spaced even >though >>>>> the >>>>> translates are. I've figured out that if I get rid of the $fn=30 >on the >>>>> cylinders the holes line up evenly. My understanding is that $fn >>>>> creates a >>>>> more rounded cylinder, but why would it offset them in relation to >the >>>>> translate coordinates? >>>>> >>>>> module base(){ >>>>> cube([168,55,5]); >>>>> } >>>>> >>>>> module mountHoles(){ >>>>> translate( [ (168 - 16.5) , 3.4 , -0.5 ] ) cylinder( h = 5, r >= 1.6, >>>>> $fn=30); >>>>> translate( [ (168 - 110.5) , 4.4 , -0.5 ] ) cylinder( h = 5, r >= >>>>> 1.6, >>>>> $fn=30); >>>>> translate( [ (168 - 16.5) , 3.4 , 2.5 ] ) cylinder( h = 3, r = >3, >>>>> $fn=30); >>>>> translate( [ (168 - 110.5) , 4.4 , 2.5 ] ) cylinder( h = 3, r >= 3, >>>>> $fn=30); >>>>> >>>>> translate( [ (168 - 16.5) , (3.4 + 43.22) , -0.5 ] ) cylinder( >h = >>>>> 5, r >>>>> = 1.6, $fn=30); >>>>> translate( [ (168 - 110.5) , (4.4 + 43.22) , -0.5 ] ) >cylinder( h = >>>>> 5, r >>>>> = 1.6, $fn=30); >>>>> translate( [ (168 - 16.5) , (3.4 + 43.22) , 2.5 ] ) cylinder( >h = >>>>> 3, r = >>>>> 3, $fn=30); >>>>> translate( [ (168 - 110.5) , (4.4 + 43.22) , 2.5 ] ) cylinder( >h = >>>>> 3, r >>>>> = 3, $fn=30); >>>>> } >>>>> >>>>> >>>>> >>>>> >>>>> difference(){ >>>>> base(); >>>>> mountHoles(); >>>>> } >>>>> >>>>> >>>>> >>>>> -- >>>>> Sent from: http://forum.openscad.org/ >>>>> >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> Discuss@lists.openscad.org >>>>> >http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>> >>>> >>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> >http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>>> >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> >http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> -- Sent from my Android device with K-9 Mail. Please excuse my brevity.
Thu, Oct 12, 2017 10:53 PM
Thanks.
not be.
Code posted below.
creates a
module base(){
cube([168,55,5]);
1.6,
$fn=30);
1.6,
$fn=30);
$fn=30);
$fn=30);
= 5, r
= 1.6, $fn=30);
= 5, r
= 1.6, $fn=30);
3, r =
3, $fn=30);
= 3, r
= 3, $fn=30);
base();
mountHoles();
Thanks. On 12 October 2017 at 23:04, Rob Ward <rl.ward@bigpond.com> wrote: > Excellent article! Something about nothing, holes!! Thank you NopHead. > > On 13 October 2017 5:13:38 am AEDT, Jeremy Buseman <naviathan@gmail.com> > wrote: >> >> Thanks nop head. Nice blog. >> >> On Oct 12, 2017 13:51, "nop head" <nop.head@gmail.com> wrote: >> >>> If you are going to 3D print it you probably don't want to set $fn so >>> high on small holes if you want them to come out the right size. See >>> http://hydraraptor.blogspot.co.uk/2011/02/polyholes.html >>> >>> On 12 October 2017 at 18:18, Jeremy Buseman <naviathan@gmail.com> wrote: >>> >>>> Ok, I figured out where the issues was. I apologize. I pulled the code >>>> from Josef Prusa's Rambo case for the MK2 (I'm just making a plate to adapt >>>> the case to 2020 extrusion). His cylinders are set strangely for some >>>> reason. Although the hinges and mounts on the case appear square, they must >>>> not be. >>>> >>>> On Thu, Oct 12, 2017 at 1:12 PM, nop head <nop.head@gmail.com> wrote: >>>> >>>>> $fn doesn't affect the position of the hole centre but you want to >>>>> keep it a multiple of 4 to get symmetrical holes. >>>>> >>>>> On 12 October 2017 at 17:42, naviathan <naviathan@gmail.com> wrote: >>>>> >>>>>> Code posted below. >>>>>> >>>>>> Notice when rendered that the holes are not evenly spaced even though >>>>>> the >>>>>> translates are. I've figured out that if I get rid of the $fn=30 on >>>>>> the >>>>>> cylinders the holes line up evenly. My understanding is that $fn >>>>>> creates a >>>>>> more rounded cylinder, but why would it offset them in relation to the >>>>>> translate coordinates? >>>>>> >>>>>> module base(){ >>>>>> cube([168,55,5]); >>>>>> } >>>>>> >>>>>> module mountHoles(){ >>>>>> translate( [ (168 - 16.5) , 3.4 , -0.5 ] ) cylinder( h = 5, r = >>>>>> 1.6, >>>>>> $fn=30); >>>>>> translate( [ (168 - 110.5) , 4.4 , -0.5 ] ) cylinder( h = 5, r = >>>>>> 1.6, >>>>>> $fn=30); >>>>>> translate( [ (168 - 16.5) , 3.4 , 2.5 ] ) cylinder( h = 3, r = 3, >>>>>> $fn=30); >>>>>> translate( [ (168 - 110.5) , 4.4 , 2.5 ] ) cylinder( h = 3, r = 3, >>>>>> $fn=30); >>>>>> >>>>>> translate( [ (168 - 16.5) , (3.4 + 43.22) , -0.5 ] ) cylinder( h >>>>>> = 5, r >>>>>> = 1.6, $fn=30); >>>>>> translate( [ (168 - 110.5) , (4.4 + 43.22) , -0.5 ] ) cylinder( h >>>>>> = 5, r >>>>>> = 1.6, $fn=30); >>>>>> translate( [ (168 - 16.5) , (3.4 + 43.22) , 2.5 ] ) cylinder( h = >>>>>> 3, r = >>>>>> 3, $fn=30); >>>>>> translate( [ (168 - 110.5) , (4.4 + 43.22) , 2.5 ] ) cylinder( h >>>>>> = 3, r >>>>>> = 3, $fn=30); >>>>>> } >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> difference(){ >>>>>> base(); >>>>>> mountHoles(); >>>>>> } >>>>>> >>>>>> >>>>>> >>>>>> -- >>>>>> Sent from: http://forum.openscad.org/ >>>>>> >>>>>> _______________________________________________ >>>>>> OpenSCAD mailing list >>>>>> Discuss@lists.openscad.org >>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>> >>>>> >>>>> >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> Discuss@lists.openscad.org >>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>> >>>>> >>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>>> >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> > -- > Sent from my Android device with K-9 Mail. Please excuse my brevity. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
K
KarijnWessing
Sat, Oct 14, 2017 9:54 AM
You make a module for the base, but not for the mounthole, funny
I would make it like this:
plateHeight = 5;
plateWidth  = 168;
plateLength = 55;
// uncomment next line when defining the mountHole
// mountHole();
base();
mountHoles();
module base() {
cube([plateWidth,plateLength, plateHeight]);
module mountHole() {
translate( [0 ,0 , 2.5 ] ) cylinder( h=3, r=3, $fn=30);
translate( [0 ,0 ,-0.5 ] ) cylinder( h=5, r=1.6, $fn=30);
module mountHoles() {
// maybe define some constants for 16.5, (110.5 - 16.5), ...
for(t = [ [(plateWidth - 16.5) , 3.4 , 0],
[(plateWidth - 110.5) , 4.4, 0],
[(plateWidth - 16.5) , (3.4 + 43.22), 0],
[(plateWidth - 110.5) , (4.4 + 43.22), 0]])
translate(t) mountHole();
You make a module for the base, but not for the mounthole, funny I would make it like this: plateHeight = 5; plateWidth = 168; plateLength = 55; // uncomment next line when defining the mountHole // mountHole(); difference() { base(); mountHoles(); } module base() { cube([plateWidth,plateLength, plateHeight]); } module mountHole() { translate( [0 ,0 , 2.5 ] ) cylinder( h=3, r=3, $fn=30); translate( [0 ,0 ,-0.5 ] ) cylinder( h=5, r=1.6, $fn=30); } module mountHoles() { // maybe define some constants for 16.5, (110.5 - 16.5), ... for(t = [ [(plateWidth - 16.5) , 3.4 , 0], [(plateWidth - 110.5) , 4.4, 0], [(plateWidth - 16.5) , (3.4 + 43.22), 0], [(plateWidth - 110.5) , (4.4 + 43.22), 0]]) translate(t) mountHole(); } -- Sent from: http://forum.openscad.org/
