Hi
I haven't been able to get a for loop working in a function. I'm trying to
add the values in a vector from a start point to an end point.
Something like this:
AVector = [2,5,3,11,4];
start = 1;
end = 3;
//addVector would return 19
function addVector (aVector,start,end)
Any help would be great. Thanks!
From the manual:
// recursion - find the sum of the values in a vector (array) by calling itself
// from the start (or s'th element) to the i'th element - remember
elements are zero based
function sumv(v,i,s=0) = (i==s ? v[i] : v[i] + sumv(v,i-1,s));
vec=[ 10, 20, 30, 40 ];
echo("sum vec=", sumv(vec,2,1)); // calculates 20+30=50
On Wed, Apr 11, 2018 at 11:34 AM, Mint86 eric23b@gmail.com wrote:
Hi
start = 1;
end = 3;
And just for fun, a non-recursive version using the c-style
for loop (needs to be enabled as experimental feature in
the dev snapshots)...
function addVector(aVector, start, end) = [ for (i = end, a = aVector[i];i >= start;i = i - 1, a = a + aVector[i]) a ][end - start];
I guess it's more a puzzle kind of solution as I think the
recursive one is more obvious and due to the tail-recursion
elimination maybe even faster than the one above :).
function sumv(v,i,s=0) = (i==s ? v[i] : v[i] + sumv(v,i-1,s));Depending on
the application, you might want something like:
function sumv(list,start,end) = start>=end? 0 :
list[start]+sumv(list,start+1,end);
so that it terminates on bad input. Of course that version doesn't take
advantage of the overloading on + the way that the one above does.
Awesome! Thanks for the quick replies.
They both are what I was looking for.
Good tip NateTG.
Thank you so much. I'm going to take a look at them.
Good tip NateTG.
On Wed, Apr 11, 2018 at 12:17:22PM +1200, Frank van der Hulst wrote:
From the manual:
I'd write
function sumv(v,i,s=0) = (i<s ? 0 : v[i] + sumv(v,i-1,s));
this won't infinitely recurse and just return zero if you accidentally
reverse the arguments. (it'd make sense to think of it as taking
the sum of elements 5 to 8, and write sumv (vect, 5, 8); )
This also works better when you hit the corner case:
// Take the sum from n elements starting at s.
function sumve(v,s,n=0) = sumv (v, s+n-1, s);
Now the "n=0" case really SHOULD return a value...
