AK
Arne Koehn
Fri, Feb 24, 2023 6:09 AM
I am trying to understand the impact of $slop and I am not sure whether
I misunderstand how $ variables work, how slop in BOSL2 works, or
possibly both.
Here is my minimal example where I expect to see a difference between
slop values:
| difference() {
| $slop=0.0;
| threaded_rod(d=20, l=20, pitch=2, $fa=1, $fs=1, internal=true);
| $slop=1.0;
This renders as empty, the three alternatives (internal=false and
swapping slop values from first and second) do as well.
Where am I misunderstanding things?
Best
Arne
possibly both.
slop values:
| difference() {
| $slop=0.0;
| $slop=1.0;
Best
Arne
Fri, Feb 24, 2023 7:24 AM
I don't think surplus braces create a new scope.
Try:
let($slop = 0)
let($slop = 1)
possibly both.
slop values:
| difference() {
| $slop=0.0;
| $slop=1.0;
Best
Arne
Try:
let($slop = 0)
let($slop = 1)
On Fri, 24 Feb 2023 at 06:16, Arne Koehn <arne@chark.eu> wrote:
> Hi,
> possibly both.
> slop values:
> | difference() {
> | $slop=0.0;
> | $slop=1.0;
> Best
> Arne
AK
Arne Koehn
Fri, Feb 24, 2023 7:31 AM
Try:
let($slop = 0)
let($slop = 1)
Thx, that works! (the first one needs $slop=1 and the second $slop=0)
Seems like I am too much used to scoping rules from other languages.
Now on to reading up on how the special variables work and doing test
prints.
nop head <nop.head@gmail.com> writes:
> Try:
> difference() {
> let($slop = 0)
> let($slop = 1)
prints.
Fri, Feb 24, 2023 1:43 PM
Micheal just reminded me you can also pass $variables as parameters, even
if the module doesn't list it in the parameter list,
E.g.
threaded_rod(d=20, l=20, pitch=2, $fa=1, $fs=1, internal=true, $slop = 0);
Try:
let($slop = 0)
let($slop = 1)
prints.
E.g.
> > Try:
> > difference() {
> > let($slop = 0)
> > let($slop = 1)
> prints.
Fri, Feb 24, 2023 7:28 PM
They do not. (That was what I remembered, and I just confirmed it.)
Does anybody know why that is? Is there any reason that they should
not create a new scope?
If they don't create a new scope, I don't come up with anything that
they do do.
Here we are talking about braces not associated with a module
invocation. That is:
xxx = 1;
not
translate([1,1,1]) {
xxx = 1;
I can't say that there are a lot of use cases for creating a new scope
in the middle of things, but there are a few, and if there's no use
cases for braces that don't create a scope, maybe we could and should
change OpenSCAD so that they do.
*not* create a new scope?
they *do* do.
xxx = 1;
not
xxx = 1;
cases for braces that *don't* create a scope, maybe we could and should
BC
Bob Carlson
Fri, Feb 24, 2023 7:35 PM
Related: I assumed at first that braces would imply union(). Why isn’t his the case?
-Bob
Tucson AZ
Does anybody know why that is? Is there any reason that they should not create a new scope?
If they don't create a new scope, I don't come up with anything that they do do.
Here we are talking about braces not associated with a module invocation. That is:
xxx = 1;
not
xxx = 1;
I can't say that there are a lot of use cases for creating a new scope in the middle of things, but there are a few, and if there's no use cases for braces that don't create a scope, maybe we could and should change OpenSCAD so that they do.
-Bob
Tucson AZ
On Feb 24, 2023, at 12:28, Jordan Brown <openscad@jordan.maileater.net> wrote:
Does anybody know why that is? Is there any reason that they should *not* create a new scope?
If they don't create a new scope, I don't come up with anything that they *do* do.
xxx = 1;
not
xxx = 1;
I can't say that there are a lot of use cases for creating a new scope in the middle of things, but there are a few, and if there's no use cases for braces that *don't* create a scope, maybe we could and should change OpenSCAD so that they do.
Fri, Feb 24, 2023 8:19 PM
his the case?
Indeed.
The results here seem surprising:
cube(1.3,center=true);
sphere();
cube();
> his the case?
Indeed.
sphere();
cube();
Fri, Feb 24, 2023 9:28 PM
Quoting a 2016 forum post:
The anonymous scopes was a design mistake in early OpenSCAD, where
scopes didn’t have a function. I don’t know how often people use that
feature to group variables, so I haven’t dared changing that yet, but
I do agree that ideally this should be a true scope.
FH
Father Horton
Fri, Feb 24, 2023 9:52 PM
I assume this would be a breaking change, though I doubt much code uses
apparently pointless braces.
> ciao,
> Torsten.
Fri, Feb 24, 2023 10:00 PM
IIRC people used braces to allow code folding in the editor without any
other meaning, so making them introduce a new scope would be a breaking
change.
change.
>> ciao,
>> Torsten.
