https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Text talks about
adding a new font.
Is includes the example of "use"
It does not explain what the contents inside the bracket actually
represent nor where the ttf file needs to be.
use <ttf/paratype-serif/PTF55F.ttf>
It also does not explain that you only need to add the "use" if you do
NOT install the font as a system font.
Later is shows how to list the system fonts that are available but
choses a different font family
This is less helpful than it could be and does not discuss what happens
with the font included with the "use"
$ fc-list -f"%-60{{%{family[0]}%{:style[0]=}}}%{file}\n" | sort
Liberation Mono:style=Bold Italic /usr/share/fonts/truetype/liberation2/LiberationMono-BoldItalic.ttf
Liberation Mono:style=Bold /usr/share/fonts/truetype/liberation2/LiberationMono-Bold.ttf
Liberation Mono:style=Italic /usr/share/fonts/truetype/liberation2/LiberationMono-Italic.ttf
Liberation Mono:style=Regular /usr/share/fonts/truetype/liberation2/LiberationMono-Regular.ttf
It also fails to mention that if you add the font to the system fonts
while OpenSCAD is running, you need to restart OpenSCAD before the font
will show up in "Help>Font List"
My case:
I am trying to use the NHL Bruin font to make something for a Bruins fan.
I have installed the font in /user/share/fonts/ so that fc-list shows
NanumGothicExtraBold:style=Regular
/usr/share/fonts/nhn-nanum/NanumGothicExtraBold.ttf
NanumGothic:style=Bold /usr/share/fonts/nhn-nanum/NanumGothicBold.ttf
NanumGothic:style=Regular /usr/share/fonts/nhn-nanum/NanumGothic.ttf
NHL Bruins:style=Regular /usr/share/fonts/NHL/NHL_Bruins.ttf
Nimbus Mono PS:style=Bold Italic
/usr/share/fonts/urw-base35/NimbusMonoPS-BoldItalic.otf
/usr/share/fonts/urw-base35/NimbusMonoPS-BoldItalic.t1
And it shows up in the OpenSCAD font list as font 193 with Font Name NHL
Bruins font style Regular with Filename /run/host/fonts/NHL/NHL_Bruins.ttf.
which seems to be in line with the other fonts.
Not sure where /run/host/fonts comes from.
If I have
use <NHL/NHL_Bruins.ttf>
I get
WARNING: Can't open library 'NHL/NHL_Bruins.ttf'.
Removing the "use" makes it work.
Ron Wheeler
Artifact Software
438-345-3369
