Alan's approach for testing equality within a tolerance is the recommended
approach. It lets you specify a tolerance, and can (in principle) be
compiled into fast code (once we have a proper JIT compiler).
Nophead's approach is not recommended. It will break once we fix the
float->string conversion, as is being discussed elsewhere in the forum. You
can't specify a tolerance, and it will be slower in compiled code.
On 13 November 2015 at 17:44, runsun runsun@gmail.com wrote:
Alan Cox wrote
The usual approach would be
abs(a - b) < ACCEPTABLE_ERROR
nophead wrote
Perhaps runsun could convert to strings with str to compare them. E.g.
x = 0.1 + 0.02;
echo(x == 0.12);
echo(str(x) == "0.12");
ECHO: false
ECHO: true
Thx to Alan and nophead. Both approaches are in fact used in my doctest lib
already. It's just that after months of success, something tickling (or
breaking) my brain cells, let me start suspecting that it is not quite
right
yet.
I now see that Openscad uses 17 significant digits for the internal
operations, and 6 digits for display. I'll have to think about if my lib
needs to change based on this findings.
$ Runsun Pan, PhD
$ libs: doctest , faces ( git ), offline doc ( git ),runscad.py( 1 , 2 ,
git );
View this message in context:
http://forum.openscad.org/Simple-addition-of-numbers-introduces-error-tp14408p14464.html
// so... should the following makes 25 or 26 balls?
for (i=[0:0.2:5]) {
translate([0,i*10,0]) sphere(1.5);
fails to give the desired 26 balls because 0.2 can not be represented
exactly in floating point. Whole numbers can be, but most decimal fractions
don't translate exactly into binary.
However this does exactly what you want:
for (i=[0:0.2:5.001) translate([0,i*10,0]) sphere(1.5);
or even better:
for (i=[0:2:50) translate([0,i,0]) sphere(1.5);
View this message in context: http://forum.openscad.org/Simple-addition-of-numbers-introduces-error-tp14408p14483.html
x = 0.1 + 0.02;
echo(x == 0.12);
ECHO: false
ECHO: true
lib already. It's just that after months of success, something tickling
(or breaking) my brain cells, let me start suspecting that it is not quite
right yet.
Found a 3rd way to solve this. This potentially eliminates the error caused
by binary rounding:
echo( 0.1+0.02 == 0.12 ); // false
f = pow(10,10);
echo( (0.1f+0.02f)/f == 0.12 ); // true
I.e., multiply it by a big number to kind of raise it up some order, do the
addition/subtraction, then bring it back down to the original order.
$ Runsun Pan, PhD
$ libs:
doctest ,
faces ( git ),
runscad.py( 1 , 2 , git );
$ tips:
hash( 1 , 2 ),
sweep ,
var( 1 , 2 ),
lerp ,
animGif ,
precision
View this message in context: http://forum.openscad.org/Simple-addition-of-numbers-introduces-error-tp14408p14676.html
