                      Quick summary:
2025.07.11 adds the the object() function, which creates an object
(in the style returned by textmetrics(), fontmetrics(), and import()
of a JSON file).
It accumulates the object by processing the arguments left to right,
with later settings for a particular member replacing earlier settings.
There are three forms for an argument:
o /name/=/value/ - sets that name (a constant identifier) to that
value.
o A vector with a list of [/name/, /value/] vectors, or [/name/]
to remove a member, where the names can be any string expression.
o An object has its members copied.
There is a new function has_key(/obj/, /name/) that returns true if
the object contains the named key.
These functions are currently experimental and so must be enabled
before you can use them.
Overview:
An "object" is a collection of names and associated values.  In other
languages this data structure might be called an object (JavaScript), a
dictionary (Python), an associative array (some UNIX shells, awk), or a
structure (C, sort of),
This change adds a function that creates an object from a series of
names, values, and other objects, and a function that queries whether a
particular member is present.  These are mostly-normal functions; there
is no new syntax introduced.
  Background:
OpenSCAD has had an internal implementation of objects for several
years, added to support the textmetrics() and fontmetrics() functions,
and later import() of a JSON file.  This existing mechanism includes
mechanisms for accessing the members of the object and for walking
through the entries.  It does not include a mechanism for the user's
program to create an object.
Given an object /o/, the current operations are:
/o/./name/ yields the value of the /name/ member, where /name/ must
be an identifier (alphabetic, numeric, underscore, starting with
alphabetic or underscore).  This syntax is very "clean", but does
not allow for names that are derived from expressions or for names
that are not suitable for use as identifiers.  An undefined name is
not an error; it yields undefined.
/o/[/name/] also yields the value of the /name/ member, but /name/
can be an any string expression.  This syntax is a bit more awkward
than the /o/./name/ syntax, but allows for dynamically-created names
and for names that are not suitable as identifiers.  Again, and
undefined name yields undefined.
for (/name/ = /o/) ... is the object equivalent of the vector
for(...).  It walks the object, setting /name/ to each member name
in sequence.  This mechanism is usable as both a normal statement
and as a list comprehension element.  Note that it yields only the
name; the value is accessible as /o/[/name/].  Formally the entries
should be assumed to be in no specific order, but for aesthetic
reasons they are reported in the order they were added to the object.
is_object(/v/) returns true if /v/ is an object.
echo(/o/) and str(/o/) produce textual representations of objects.
(Note:  the textual form looks sort of like syntax, but is not legal
OpenSCAD syntax.  It is likely to change in the future; see Future
Directions below.)
Details:
The object() function constructs a new object, processing each argument
in sequence from left to right, with later settings replacing earlier
settings.  There are three variations of arguments; they can be mixed in
any way.
The values contained in an object can (of course) be of any data type:
numbers, strings, vectors, function references, objects, et cetera.
There is also a new function has_key(/o/, /name/) that returns true if
the object has a member with the specified name.
  Examples:
Create an object; access its members:
o = object(a=1, b=2);
echo(o.a, o["b"]);
Create an object with varying names, and access them:
names = [ "apple", "banana", "string bean" ];
o = object([ for (name=names) [name, 123] ]);
for (name=names) echo(name, o[name]);
Create an object, then create modified copies of that object:
// Ancient planets
planets = object(mercury=1, venus=2, earth=3, mars=4, jupiter=5,
saturn=6);
planets1781 = object(planets, uranus=7);        // Uranus discovered
planets1846 = object(planets1781, neptune=8);   // Neptune discovered
planets1930 = object(planets1846, pluto=9);     // Pluto discovered
planets2006 = object(planets1930, [["pluto"]]); // Pluto un-planeted
Check whether a member is present:
echo(has_key(planets1846, "neptune")); // true
echo(has_key(planets2006, "pluto"));   // false
Future Directions and Related Projects:
This is the second phase (after the textmetrics() work) of a longer-term
plan to introduce "object" features into OpenSCAD.
Object literals, object comprehension:  OEP8a
https://github.com/openscad/openscad/wiki/OEP8a:--Objects-(dictionaries%3F)
adds a syntax for creating objects, including object comprehensions,
roughly modeled on JavaScript object syntax, so that { a: 1, b: 2 } is
equivalent to object(a=1, b=2). Changes echo() and str() to represent
objects using this syntax.
OEP8
https://github.com/openscad/openscad/wiki/OEP8%3A-Objects-%28dictionaries%3F%29%2C-Geometry-as-data%2C-and-Module-References
further adds geometry as data and module references.
No formal proposals:
Methods: If a function reference comes from an object or a vector, it
should see a special variable $this that refers to the containing object
or vector.  Note that although there's no inheritance per se, making a
modified copy of an object is a lot like the prototype-based OO
https://en.wikipedia.org/wiki/Prototype-based_programming.
Variable parameter lists:  a syntax for a parameter lists that says
"return the rest of the parameters in this variable", as a vector (for
positional arguments) or an object (for named arguments).
Spread syntax:  a syntax for adding a vector to an argument list as
positional arguments, or adding an object to an argument list as named
arguments.
Sets:  Some kind of syntactic sugar to make it easy to create an object
containing boolean "true", to make it easy to define a set (in the
mathematical sense) and query whether particular items are present in it.
  Questions:
What should these things be called?
o They're modeled on JavaScript objects, but to a Python person
they look more like dictionaries and to a C person they look
more like structures.
o Are they really "objects", when they don't have OO features?
See Future Directions about methods.
o In OpenSCAD, doesn't "object" already mean a geometric figure?
Credits / History:
I did the original textmetrics() work.
Revar Desmera did the original implementation of object().
Peter Kriens drove this final integration, cleaning up the
implementation, fixing a bug, and writing test cases.
Here's a program that I threw together that exercises the new object
features.
It provides a framework for doing a general animation - at this time, do
this, at that time, do that.  For an example of doing that without a
framework like this, look at https://openscad.org/advent-calendar-2023/
at day 24.
Remember that this requires 2025.07.11. Zoom as desired.
// Best view is looking straight down at the origin.
$vpr = [0,0,0];
$vpt = [0,0,0];
// Demonstration animation.  Use FPS=10 and steps=100.
// Zoom as desired.
// This vector is a description of everything that happens
// during the animation. You want a wide window to read it.
// The only thing that's defined is "t", the timestamp for that
// particular entry.  The rest are up to your program.
// For this animation:
// pos1, pos2: the {red, green} stick man's position
// arm1, arm2: the {red, green} stick man's arm angle
// says1, says2: what the {red, green} stick man is saying
timeline = [
object(t=0,  pos1=[-50,0,0], arm1=-30, says1="",              pos2=[50,0], arm2=-30, says2=""            ),
object(t=2.5,                arm1=-30        ),
object(t=3,                  arm1=50,  says1="Hey, George!"                                              ),
object(t=3.5,                arm1=-30        ),
object(t=5,                            says1=""                                                          ),
object(t=5.5,                                                              arm2=-30,                     ),
object(t=6,        arm2=50,  says2="Hey, Fred!"  ),
object(t=6.5,                                                              arm2=-30                      ),
object(t=7,        says2=""            ),
object(t=12, pos1=[-5,0,0],                                   pos2=[5,0]                                 ),
object(t=13,                           says1="Can I go past?"                                            ),
object(t=14,                           says1=""                                                          ),
object(t=15,        says2="Sorry, no."  ),
object(t=16,        says2=""            ),
object(t=17,                           says1="I hate living on a number line!"                           ),
object(t=19,                           says1=""                                                          ),
object(t=19.5,        says2="Me too!"     ),
object(t=20.5,        says2=""            ),
object(t=22, pos1=[-5,0,0], arm2=-30,  says1="",              pos2=[5,0],  arm2=-30, says2=""            ),
// Now, create the current frame of the animation.
// Get the current values of all of the timeline columns.
a = animate(timeline);
// Using those values, create the model at this moment.  There are two stick men.
translate(a.pos1) {
color("red") stickman(a.says1, a.arm1);
translate(a.pos2) {
color("green") stickman(a.says2, a.arm2);
// Create a stick man, holding his arms at the specified angle and saying what's specified.
module stickman(says, arm) {
square([1,8], center=true);
translate([0,5]) circle(2);
translate([0,2])
rotate(arm)
translate([0,-0.5])
square([4,1]);
translate([0,2])
rotate(180-arm)
translate([0,-0.5])
square([4,1]);
translate([0,-4])
rotate(200)
translate([-0.5,0])
square([1,5]);
translate([0,-4])
rotate(160)
translate([-0.5,0])
square([1,5]);
translate([0, 8]) text(says, halign="center", valign="baseline", size=3);
// The rest is generic support for using a timeline like that.
// Extract one column from an animation timeline, extracting only
// those entries where that column is present.
function animate_extract(list, key) = [
for (e = list) if (!is_undef(e[key])) [ e.t, e[key] ]
// Get the duration of the timeline, the timestamp of the
// last entry in the timeline.
function animate_duration(list) = list[len(list)-1].t;
// Given $t, a timeline and a key, interpolate the current value
// of the key.
function animate_interpolate(list, key) =
xlookup($t * animate_duration(list), animate_extract(list, key));
// Get a list of all keys used in the timeline.
function animate_keys(list) =
let (o = object(
for (e = list)
for (k = e)
[ k, true ]
[ for (k = o) k ];
// Given $t and a timeline, return an aggregated object with the
// current values of all of the columns of the timeline.
function animate(timeline) =
let(keys = animate_keys(timeline))
object(
for (k = keys) [ k, animate_interpolate(timeline, k) ]
// lookup() on steroids.  Given a value and a lookup-like list,
// do the lookup and interpolation that lookup() does... but have
// it also work for strings, booleans, and identical-length lists
// of numbers.
function xlookup(val, list) =
is_num(list[0][1]) ? lookup(val, list)
: is_string(list[0][1]) ? lookup_string(val, list)
: is_bool(list[0][1]) ? lookup_bool(val, list)
: is_list(list[0][1]) ? lookup_list(val, list)
: assert(false, "don't know how to lookup that type");
// Given a value and a lookup list, return the index of the entry
// before (or matching) the value.
function lookup_prev(val, list) =
let (tmp = [ for (i = [0:1:len(list)-1]) [ list[i][0], i ] ])
floor(lookup(val, tmp));
//Given a value and a lookup list, return the index of the entry
// after (or matching) the value.
function lookup_next(val, list) =
ceil(lookup(val, tmp));
// Given a value and a lookup list containing strings, return the
// string before (or matching) the value.
function lookup_string(val, list) = list[lookup_prev(val, list)][1];
// Given a value and a lookup list containing booleans, return the
// boolean before (or matching) the value.
function lookup_bool(val, list) = list[lookup_prev(val, list)][1];
// Given a value and a lookup list containing same-length lists of
// numbers, interpolate values for the list.  Note that because
// lookup_prev() and lookup_next() return the same entry on an exact
// match, and that leads to 0*0/0, that case has to be handled
// specially.
function lookup_list(val, list) =
let(
p = lookup_prev(val, list),
n = lookup_next(val, list)
p == n
? list[p][1]
: list[p][1]
+ (list[n][1]-list[p][1])
* (val - list[p][0]) / (list[n][0] - list[p][0]);
I think this is a great step, it will definitely be great when creating libraries, especially ones with values that would be the equivalent of enumerations in other languages. I have created multiple libraries, but it was always inappropriate to use the "include" command, because so many libraries had variables with similar names, this will definitely improve the organization of shared libraries. Even though this is currently in the experimental stage, is there anywhere that the current [planned] syntax is available? I did not see the object() function on the Cheat Sheet (which is understandable)? Thanks again!
Nathan Sokalski
From: Jordan Brown via Discuss discuss@lists.openscad.org
Sent: Sunday, July 13, 2025 6:20 PM
To: OpenSCAD discuss@lists.openscad.org
Cc: Jordan Brown openscad@jordan.maileater.net
Subject: [OpenSCAD] New feature in 2025.07.11: the object() function
Quick summary:
Overview:
An "object" is a collection of names and associated values. In other languages this data structure might be called an object (JavaScript), a dictionary (Python), an associative array (some UNIX shells, awk), or a structure (C, sort of),
This change adds a function that creates an object from a series of names, values, and other objects, and a function that queries whether a particular member is present. These are mostly-normal functions; there is no new syntax introduced.
Background:
OpenSCAD has had an internal implementation of objects for several years, added to support the
textmetrics()
and
fontmetrics()
functions, and later
import()
of a JSON file.  This existing mechanism includes mechanisms for accessing the members of the object and for walking through the entries.  It does not include a mechanism for the user's program to create an object.
Given an object
o
o.name
name
member, where
name
must be an identifier (alphabetic, numeric, underscore, starting with alphabetic or underscore).  This syntax is very "clean", but does not allow for names that are derived from expressions or for names that are not suitable for use as identifiers.  An undefined name is not an error; it yields
undefined
o[name]
name
member, but
name
can be an any string expression.  This syntax is a bit more awkward than the
o.name
syntax, but allows for dynamically-created names and for names that are not suitable as identifiers.  Again, and undefined name yields
undefined
for (name = o) ...
for(...)
name
to each member name in sequence.  This mechanism is usable as both a normal statement and as a list comprehension element.  Note that it yields only the name; the value is accessible as
o[name]
.  Formally the entries should be assumed to be in no specific order, but for aesthetic reasons they are reported in the order they were added to the object.
is_object(v)
returns true if
v
is an object.
echo(
o
and
str(o)
produce textual representations of objects.  (Note:  the textual form looks sort of like syntax, but is not legal OpenSCAD syntax.  It is likely to change in the future; see Future Directions below.)
Details:
The
object()
function constructs a new object, processing each argument in sequence from left to right, with later settings replacing earlier settings.  There are three variations of arguments; they can be mixed in any way.
The values contained in an object can (of course) be of any data type: numbers, strings, vectors, function references, objects, et cetera.
has_key(o, name)
that returns true if the object has a member with the specified name.
Examples:
echo(o.a, o["b"]);
textmetrics()
work) of a longer-term plan to introduce "object" features into OpenSCAD.
Object literals, object comprehension: OEP8ahttps://github.com/openscad/openscad/wiki/OEP8a:--Objects-(dictionaries%3F) adds a syntax for creating objects, including object comprehensions, roughly modeled on JavaScript object syntax, so that
{ a: 1, b: 2 }
is equivalent to
object(a=1, b=2)
. Changes
echo()
and
str()
to represent objects using this syntax.
OEP8https://github.com/openscad/openscad/wiki/OEP8%3A-Objects-%28dictionaries%3F%29%2C-Geometry-as-data%2C-and-Module-References further adds geometry as data and module references.
Methods: If a function reference comes from an object or a vector, it should see a special variable
$this
that refers to the containing object or vector.  Note that although there's no inheritance per se, making a modified copy of an object is a lot like the prototype-based OOhttps://en.wikipedia.org/wiki/Prototype-based_programming.
Variable parameter lists: a syntax for a parameter lists that says "return the rest of the parameters in this variable", as a vector (for positional arguments) or an object (for named arguments).
Spread syntax: a syntax for adding a vector to an argument list as positional arguments, or adding an object to an argument list as named arguments.
Sets: Some kind of syntactic sugar to make it easy to create an object containing boolean "true", to make it easy to define a set (in the mathematical sense) and query whether particular items are present in it.
Questions:
Credits / History:
This is definitely a great step, and will be a great help for libraries and
more complicated code, but my thinking was more in code clarity and
simplification, and cleaner interfaces to (library) functions that need to
return multiple values.   Right now such functions have to return a list
which has arbitrary index values.
Were you thinking that libraries would be constructed so that the entire
library is inside an object?
On Sun, Jul 13, 2025 at 9:21 PM Nathan Sokalski via Discuss <
Nathan Sokalski
Quick summary:
- 2025.07.11 adds the the
object()
 function, which creates an object (in the style returned by
textmetrics()
fontmetrics()
, and
import()
 of a JSON file).
- It accumulates the object by processing the arguments left to right,
- There are three forms for an argument:
   - *name*=*value*
    - sets that name (a constant identifier) to that value.
   - A vector with a list of
   [*name*, *value*]
    vectors, or
   [*name*]
   - An object has its members copied.
- There is a new function
has_key(*obj*, *name*)
 that returns true if the object contains the named key.
- These functions are currently experimental and so must be enabled
Overview:
syntax introduced.
Background:
textmetrics()
and
fontmetrics()
import()
object.
Given an object
o
- *o*.*name*
*name*
 member, where
*name*
yields
undefined
- *o*[*name*]
*name*
 member, but
*name*
than the
*o*.*name*
undefined
- for (*name* = *o*) ...
for(...)
*name*
*o*[*name*]
the object.
- is_object(*v*)
 returns true if
*v*
 is an object.
- echo(
* o *
 and
str(*o*)
to change in the future; see *Future Directions* below.)
Details:
The
object()
- A named parameter
*name*=*value*
- Sets the specified name to the specified value.  As with all named
   arguments to functions, the name must be an identifier.
- a vector
[ *v1*, *v2*, ... ]
- *v1*
   , *v2*
   , ... are each two- or one-element vectors
   - [*name*, *value*]
   - Sets the specified name to the specified value.  The name can be
   - [*name*]
   - Removes the specified name from the object being accumulated.
      (Note that this is subtly different from setting it to
      undefined
      , in that it will not be reported for
      has_key()
       or when walking the names of the object.)
      - an object
*o*
- An object has each of its members copied into the new object.
has_key(o, name)
Examples:
- Create an object; access its members:
echo(o.a, o["b"]);
- Create an object with varying names, and access them:
- Create an object, then create modified copies of that object:
// Ancient planets
saturn=6);
- Check whether a member is present:
textmetrics()
{ a: 1, b: 2 }
is equivalent to
object(a=1, b=2)
. Changes
echo()
and
str()
OEP8
$this
arguments.
Questions:
- What should these things be called?
   - They're modeled on JavaScript objects, but to a Python person
   they look more like dictionaries and to a C person they look more like
   structures.
   - Are they really "objects", when they don't have OO features?  See *Future
   Directions* about methods.
   - In OpenSCAD, doesn't "object" already mean a geometric figure?
Credits / History:
- I did the original textmetrics() work.
- Revar Desmera did the original implementation of
object()
- Peter Kriens drove this final integration, cleaning up the
I've got it in a PR, but that PR is now several years stale and I'm
pretty sure it no longer builds.  (It's also got some other stuff that I
think is cool; see PR#4478
https://github.com/openscad/openscad/pull/4478 / OEP8
https://github.com/openscad/openscad/wiki/OEP8%3A-Objects-%28dictionaries%3F%29%2C-Geometry-as-data%2C-and-Module-References.)
understandable)?
Peter's got a draft of updating the cheat sheet, and one of us will add
these two functions to the manual.
entire library is inside an object?
Entirely plausible.  You can't really do it today because we don't have
module references.
I forgot to mention in the Futures section that I want to figure out how
to have a function - call it use(), for discussion purposes, though it
would be enough different from the "use" directive that I'd probably
call it something else.  You would say something like "foo =
use("foo.scad");" and foo would get a single object with all of the
global variables, modules, and functions from foo.scad.  (Handwave on
namespace issues; quite possibly just declare that for this style of
library you must not have the same names for functions, modules, and
variables.)  That would reduce namespace problems to (a) file names and
(b) special variable names.  And we'd define it to evaluate the
variables exactly once, at use() time :-)
♫ PARTY-TIME! ♬
On Jul 13, 2025, at 3:20 PM, Jordan Brown via Discuss discuss@lists.openscad.org wrote:
Quick summary:
2025.07.11 adds the the object() function, which creates an object (in the style returned by textmetrics(), fontmetrics(), and import() of a JSON file).
It accumulates the object by processing the arguments left to right, with later settings for a particular member replacing earlier settings.
name=value - sets that name (a constant identifier) to that value.
A vector with a list of [name, value] vectors, or [name] to remove a member, where the names can be any string expression.
There is a new function has_key(obj, name) that returns true if the object contains the named key.
These functions are currently experimental and so must be enabled before you can use them.
Overview:
Background:
OpenSCAD has had an internal implementation of objects for several years, added to support the textmetrics() and fontmetrics() functions, and later import() of a JSON file. This existing mechanism includes mechanisms for accessing the members of the object and for walking through the entries. It does not include a mechanism for the user's program to create an object.
Given an object o, the current operations are:
o.name yields the value of the name member, where name must be an identifier (alphabetic, numeric, underscore, starting with alphabetic or underscore).  This syntax is very "clean", but does not allow for names that are derived from expressions or for names that are not suitable for use as identifiers.  An undefined name is not an error; it yields undefined.
o[name] also yields the value of the name member, but name can be an any string expression.  This syntax is a bit more awkward than the o.name syntax, but allows for dynamically-created names and for names that are not suitable as identifiers.  Again, and undefined name yields undefined.
for (name = o) ... is the object equivalent of the vector for(...).  It walks the object, setting name to each member name in sequence.  This mechanism is usable as both a normal statement and as a list comprehension element.  Note that it yields only the name; the value is accessible as o[name].  Formally the entries should be assumed to be in no specific order, but for aesthetic reasons they are reported in the order they were added to the object.
is_object(v) returns true if v is an object.
echo(o) and str(o) produce textual representations of objects.  (Note:  the textual form looks sort of like syntax, but is not legal OpenSCAD syntax.  It is likely to change in the future; see Future Directions below.)
Details:
The object() function constructs a new object, processing each argument in sequence from left to right, with later settings replacing earlier settings. There are three variations of arguments; they can be mixed in any way.
A named parameter name=value
Sets the specified name to the specified value.  As with all named arguments to functions, the name must be an identifier.
a vector [ v1, v2, ... ]
v1, v2, ... are each two- or one-element vectors
[name, value]
Sets the specified name to the specified value.  The name can be any string expression.
[name]
Removes the specified name from the object being accumulated.  (Note that this is subtly different from setting it to undefined, in that it will not be reported for has_key() or when walking the names of the object.)
an object o
There is also a new function has_key(o, name) that returns true if the object has a member with the specified name.
Examples:
echo(o.a, o["b"]);
// Ancient planets
planets = object(mercury=1, venus=2, earth=3, mars=4, jupiter=5, saturn=6);
This is the second phase (after the textmetrics() work) of a longer-term plan to introduce "object" features into OpenSCAD.
Object literals, object comprehension: OEP8a https://github.com/openscad/openscad/wiki/OEP8a:--Objects-(dictionaries%3F) adds a syntax for creating objects, including object comprehensions, roughly modeled on JavaScript object syntax, so that { a: 1, b: 2 } is equivalent to object(a=1, b=2). Changes echo() and str() to represent objects using this syntax.
OEP8 https://github.com/openscad/openscad/wiki/OEP8%3A-Objects-%28dictionaries%3F%29%2C-Geometry-as-data%2C-and-Module-References further adds geometry as data and module references.
Methods: If a function reference comes from an object or a vector, it should see a special variable $this that refers to the containing object or vector. Note that although there's no inheritance per se, making a modified copy of an object is a lot like the prototype-based OO https://en.wikipedia.org/wiki/Prototype-based_programming.
Questions:
They're modeled on JavaScript objects, but to a Python person they look more like dictionaries and to a C person they look more like structures.
Are they really "objects", when they don't have OO features?  See Future Directions about methods.
Credits / History:
Peter Kriens drove this final integration, cleaning up the implementation, fixing a bug, and writing test cases.
I would welcome a few simple examples, to get my feet wet.  I used
Pascal for decades, so I am, trying to map this new feature to what I am
familiar with.
What I see looks like a table with named parameters for each row.  I
have used a similar technique using plain OpenSCAD for many years.  I
simply create a series of named vectors as a dictionary, select a
specific vector at run-time, and then transfer the vector elements into
local variables.
features.
do this, at that time, do that.  For an example of doing that without
a framework like this, look at
https://openscad.org/advent-calendar-2023/ at day 24.
$vpr = [0,0,0];
$vpt = [0,0,0];
// Zoom as desired.
timeline = [
translate(a.pos1) {
translate(a.pos2) {
translate([0,2])
rotate(arm)
translate([0,-0.5])
square([4,1]);
translate([0,2])
rotate(180-arm)
translate([0,-0.5])
square([4,1]);
translate([0,-4])
rotate(200)
translate([-0.5,0])
square([1,5]);
translate([0,-4])
rotate(160)
translate([-0.5,0])
square([1,5]);
// of the key.
let (o = object(
for (e = list)
for (k = e)
[ k, true ]
[ for (k = o) k ];
object(
// of numbers.
// specially.
let(
p == n
? list[p][1]
: list[p][1]
I am working on an example in the build source code tree. I can share the current incarnation. Feel free to comment, ask questions so I can elucidate them, or provide suggestions.
// examples with objects.
// Objects are immutable. Once an object is created, its values
// can not be changed.
// Construct a simple object
rectangle = object( w = 100, h= 20 );
echo(rectangle); // { w = 100; h = 20; }
// Access is via identifier
echo( rectangle.w, rectangle.h ); // 100, 20
// Or access is via string key
echo( rectangle["w"], rectangle["h"] ); // 100, 20
// You can test if a key is present
echo( has_key(rectangle,"w"), has_key(rectangle,"y")); // true, false
// You can use an object as a list of keys, where keys
// are always strings. For example, you can use them include
// in comprehension
values = [ for (k = rectangle) rectangle[k] ];
echo( values ); // [100, 20]
// To test if a parameter is an object, there is_bool
// an is_object function:
echo( is_object( rectangle )); // true
echo( is_object( [] )); // false
// You can use any type as value, key is
// always a string.
echo( object( name = "OpenSCAD.object", array=[1,2], bool=false) );
// { name = "OpenSCAD.object"; array = [1, 2]; bool = false; }
// Create a new object based on another object
volume = object( rectangle, d=10);
echo(volume); // { w = 100; h = 20; d = 10 }
// If you replace a field, it will take its original
// position
echo( object( volume, w=10) ); // { w = 10; h = 20; d = 10 }
// You can copy from multiple objects. This will
// be assigned in order, later objects override the early ones
echo( object(rectangle, volume) ); // { w = 100; h = 20; d = 10; }
// Keys can also be created dynamically. For this reason
// the object() function accepts a list with edit instructions.
// An element in this list is either ["k"] for a delete
// or ["k",v] for a new/override key.
echo( object( rectangle, [ ["w"], ["h"]] )); // {}
echo( object( [ ["w",10], ["h",10]] )); //  { w = 10; h = 10; }
echo( object( rectangle, [ ["z",20]])); //   { w = 100; h = 20; z = 20; }
// copy, deletes and set can be combined in one call.
echo( object( rectangle, [ ["z",20], ["w"]], h=10)); //   { h = 10; z = 20; }
// This works for large number of calculated entries
entries = [for ( i = [1:10000] ) [ str("_",floor(i)), floor(i) ] ];
large = object( entries );
echo( large._3012 );
// Functions. You can store functions in objects. However,
// the function can not have access to the object's fields
// due to OpenSCAD's architecture. To mimic object oriented
// behavior, often a function that acts as context is
// useful.
function rect( w =0, h=0) = object( w=w, h=h, area = function() w*h );
echo( rect(10,10).area()); // 100
On 14 Jul 2025, at 13:55, Jon Bondy via Discuss discuss@lists.openscad.org wrote:
I would welcome a few simple examples, to get my feet wet. I used Pascal for decades, so I am, trying to map this new feature to what I am familiar with.
What I see looks like a table with named parameters for each row. I have used a similar technique using plain OpenSCAD for many years. I simply create a series of named vectors as a dictionary, select a specific vector at run-time, and then transfer the vector elements into local variables.
Here's a program that I threw together that exercises the new object features.
It provides a framework for doing a general animation - at this time, do this, at that time, do that. For an example of doing that without a framework like this, look at https://openscad.org/advent-calendar-2023/ at day 24.
$vpr = [0,0,0];
$vpt = [0,0,0];
// Zoom as desired.
timeline = [
translate(a.pos1) {
translate(a.pos2) {
translate([0,2])
rotate(arm)
translate([0,-0.5])
square([4,1]);
translate([0,2])
rotate(180-arm)
translate([0,-0.5])
square([4,1]);
translate([0,-4])
rotate(200)
translate([-0.5,0])
square([1,5]);
translate([0,-4])
rotate(160)
translate([-0.5,0])
square([1,5]);
// of the key.
let (o = object(
for (e = list)
for (k = e)
[ k, true ]
[ for (k = o) k ];
object(
// of numbers.
// specially.
let(
p == n
? list[p][1]
: list[p][1]
http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient	Virus-free.www.avg.com http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient x-msg://58/#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2_______________________________________________
am familiar with.
It's been forty years since I wrote Pascal, so I'm a tad rusty... but
Wikipedia to the rescue:  it's roughly equivalent to a Pascal "record" -
that is, a data structure with named elements, each of any type.
That is indeed the data structure that this example uses.  Its big data
structure is a vector (list, array, nothing new there) of objects
(dictionaries, records, associative arrays), each of which has some
number of named members.
Before this addition, there are a number of techniques for creating a
data structure with named elements.  The most obvious is probably the
vector-of-vectors approach that is one of the forms that object()
accepts as an input:
[[ "a", 1 ], [ "b", 2 ]].
Primarily, the difference is in how concise the representation is.
Contrast:
v = [ [ "a", 1 ], [ "b", 2 ] ];
echo(find(v, "a"));
echo(o.a);
and of course that difference multiplies as you build more complex data
structures:
vperson = [
        "name", [
            [ "given", "Jordan" ],
            [ "family", "Brown" ]
        "birth", [
            [ "year", 1961 ],
            [ "month", 7 ],
            [ "day", 26 ],
operson = object(
    name = object(given = "Jordan", family="Brown"),
    birth = object(year=1961, month=7, day=26)
vbirthyear = find(find(vperson, "birth"), "year");
obirthyear = operson.birth.year;
Some of that difference is of course in how I've chosen to lay out the
two examples, but with four levels of brackets I feel a need for
indentation to keep them straight.
Another approach is to use a vector with named elements, something like:
NAME = 0;
NAME_GIVEN = 0;
NAME_FAMILY = 1;
BIRTH = 1;
BIRTH_YEAR = 0;
BIRTH_MONTH = 1;
BIRTH_DAY = 2;
v2person = [ [ "Jordan", "Brown" ], [ 1961, 7, 26 ] ];
v2birthyear = v2person[BIRTH][BIRTH_YEAR];
but then it's awkward to have the data be sparse (what if I only have a
family name, no given name?), and construction is awkward because you
have to make sure you mentioned all of the elements, in the right order.
Future: when and if we move forward with the next step, OEP8a
https://github.com/openscad/openscad/wiki/OEP8a:--Objects-(dictionaries%3F),
this form becomes available:
operson = {
    name: { first: "Jordan", last:"Brown" },
    birth: { year: 1961, month: 7, day: 26}
