Well for me I can use my CMS and export all of my design data as json files instead of hand coding or having to generate scad files from the CMS. This will save me a TON of time for what I am doing. Also having structured data will make things way easier for me. I will have to rewrite some code but it will definitely be worth the time.
On Friday, November 25, 2022 at 01:32:09 PM PST, William Lugg via Discuss discuss@lists.openscad.org wrote:
Please help a beginner understand...
How does putting the data in a json file improve the situation?
Thanks
Bill Lugg
On 11/25/22 13:18, Torsten Paul wrote:
You can't include/use with a variable.
However if you don't mind using an experimental feature from
the dev snapshot, you can put the data into json files and
use something like:
file =3D "a.json";
data =3D import(file);
echo(data.a);
a.json
=09"a": 10
b.json
=09"a": 12
On Friday, November 25, 2022 at 01:32:09 PM PST, William Lugg via Discuss <discuss@lists.openscad.org> wrote:
Thanks
Bill Lugg
> use something like:
> file =3D "a.json";
> echo(data.a);
> a.json
> =09"a": 10
> b.json
> =09"a": 12
> ciao,
> Torsten.
