lar3ry
Sat, May 8, 2021 3:46 PM
I'm working on a project that requires passing 6 values to a module, and
those 6 values must be passed on to another module, then those same values
must be passed on to 18 more modules.
I just figure that a global variable that is assignable at run time would
simplify things a lot.
If that can't be done, does anyone have an idea about how best to implement
something like it?
something like it?
Sat, May 8, 2021 4:08 PM
There is no "run time" as it is a description, not an executable program,
so I don't understand what you mean.
You can set a global constant and use it in all functions and modules
defined in the same file. If you prefix it with $ then it will also be seen
by all functions and modules called from the file it is defined in.
If you are passing a lot of variables around perhaps it is better to put
them in a list and just pass that. For example when I define something like
a parametric box I put the properties in a list and pass it to all
functions and modules that draw the box.
See
https://github.com/nophead/NopSCADlib/blob/master/printed/printed_box.scad
for an example.
implement something like it?
at Nabble.com.
See
for an example.
> at Nabble.com.
Sat, May 8, 2021 8:18 PM
Alternatively, you can create a module that contains a function that
returns your six values. For example, put:
function mySixValues() = [ 1, 2, 3, 5, 6, 7 ];
...in a file called myGlobalValues.scad
Then, in each module that needs those value, put:
use <myGlobalValues.scad>;
myValues = mySixValues();
echo( myValues );
See
for an example.
at Nabble.com.
echo( myValues );
> See
> for an example.
>> at Nabble.com.
lar3ry
Sat, May 8, 2021 8:50 PM
OK. I really didn't think it could be done, but thought I'd ask anyway.
So I decided to pass the variables as a list, and that's acceptable.
However, I have a problem, related to the whole "variables aren't" thing.
When I test for a valid formula, I can detect whether or not it's valid, but
I can't figure out how to pass it out of the for, so I can check for it in
the assert(), and use it in the call to calc(formula,given);
Is there some way I can store the true or false externally to the for loop,
so I can fetch it later?
Or is there perhaps some way I can break out of the for loop if I find a
match?
valid_formula = ([13,23,43,15,25,45,16,26,46,31,32,
34,51,52,54,61,62,64,71,72,74]);
triangle (20,30,0,50,0,0); //generates formula 64
module triangle(A,B,C,a,b,c) {
given = [A,B,C,a,b,c];
angflag = ((A>0 ? 4 :0) + (B>0 ? 2 :0) + (C>0 ? 1 :0)) * 10;
sideflag = ((a>0 ? 4 :0) + (b>0 ? 2 :0) + (c>0 ? 1 :0));
formula = angflag+sideflag;
for (f = [0:20]) {
if (formula == valid_formula[f]) {
echo ("formula: ", formula, " is valid");
// assert(valid==true, "Invalid input. Must have 2 angles and 1 side, two
sides and 1 angle, or three angles and 1 side");
echo (given);
// Note that in we only need to solve for side b and side c because once we
have those, we can simply close the path
// calc(formula,given);
like
match?
for (f = [0:20]) {
echo (given);
> like
lar3ry
Sat, May 8, 2021 8:53 PM
Hmmm... and how would I go about saving the values in a separate file?
use
echo( myValues );
> use
> echo( myValues );
Sat, May 8, 2021 9:11 PM
You just want to know if formula is in the list valid_formula? Why not use
search?
Something like search([formula], valid_formula)[0] != []. Might double
check syntax, or use BOSL2 in_list() instead to avoid idiotic search()
syntax.
If you really wanted to do it your way (or if the conditional was something
else):
match = [for(f=valid_formula) if (f==formula) f];
assert(match != []);
but
loop,
match?
for (f = [0:20]) {
echo (given);
we
like
search?
syntax.
else):
> but
> loop,
> match?
> for (f = [0:20]) {
> echo (given);
> we
>> like
> discuss-leave@.openscad
lar3ry
Sun, May 9, 2021 4:11 AM
use
search?
Ahh. Never have used search. That will do it, but...
Might double check syntax, or use BOSL2 in_list() instead to avoid idiotic
search()
syntax.
That sounds even better.
Thanks Adrian!
oops. forgot to send this.
As you might surmise by my code snippet, I am trying to make an OpenSCAD
library that will solve triangle's sides and angles, given three pieces of
data. One angle and two sides, or two angles and one side.
I ended up using BOSL2 to error check before passing the given data to a
formula. Not knowing anything about trig, I am using the triangle calculator
at http://cossincalc.com/
After putting in values of C=50, b=30, and c=60, I got a triangle annotated
with angles and sides.
Scrolling down a bit to the Formulae section, and looking at the formula
used to calculate B, I run into my first trouble.
What the heck does the '-1' in that formula mean?
> use
> search?
> search()
> syntax.
Thanks Adrian!
Sun, May 9, 2021 8:11 AM
If you mean sin to the -1 it means arcsine, which is asin() in openscad.
I.e. the inverse of sin.
On Sun, 9 May 2021 at 05:11, lar3ry lar3ry@sasktel.net wrote:
use
search?
search()
syntax.
Thanks Adrian!
calculator at http://cossincalc.com/
annotated with angles and sides.
at Nabble.com.
On Sun, 9 May 2021 at 05:11, lar3ry <lar3ry@sasktel.net> wrote:
> use
> search?
> search()
> syntax.
> Thanks Adrian!
> at Nabble.com.
lar3ry
Mon, May 10, 2021 9:11 PM
Thanks! Got another problem with a formula. Here's a snippet
if (formula==43) {
A=given[0]; // 30
b=given[4]; // 25
c=given[5]; // 40
a =sqr(b^2 + c^2 - 2 * b * cos(A));
echo ("line 56 ",A,B,C,a,b,c);
and the result of the echo is:
ECHO: "line 56 ", 30, 0, 0, 4.75981e+6, 25, 40
The answer should be 22.20 according to the http://cossincalc.com site.
if (formula==43) {
A=given[0]; // 30
b=given[4]; // 25
c=given[5]; // 40
lar3ry
Mon, May 10, 2021 9:20 PM
if (formula==43) {
A=given[0]; // 30
b=given[4]; // 25
c=given[5]; // 40
a =sqr(b^2 + c^2 - 2 * b * c * cos(A));
ECHO: "line 56 ", 30, 0, 0, 242999, 25, 40
if (formula==43) {
A=given[0]; // 30
b=given[4]; // 25
c=given[5]; // 40
